On presario2100 where is the enter key - Office Equipment & Supplies
  • Grand Canyon Tech
    Grand Canyon Tech Nov 26, 2014
    Hi bob Elliott, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Sharp mx-m264n how to enter simulation mode
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
Sep 14, 2015 | Sharp Office Equipment & Supplies
HOW REMOVE IT FROM THIS Defective power supply ERROR
Reset C6400 ERROR
turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Select Service setting using
the up/down cursor keys.
While pressing the start key and the # key,
press the enter key..........Maintenance mode is entered.
Select Maintenance mode using
Press the enter key.
Enter the maintenance item
number U163 using the up/down keys.
Select Execute using the up/down cursor keys.
Press the enter key. The fusing problem data is initialized.
Apr 15, 2014 | Kyocera FS-1118MFP Laser Printer
On the display access cod
Enter in the User mode set menu screen 6/6,touch the Copy Track.Used to turn ON or OFF the copy track function per account.When ON is selected press the Enter key.Press the UP/DOWN key to acces the Account#to be administrated.Press the Acces#key and register the acces number corresponding to the above Account# from the 10-key pad(max.4digits)If the access number has been changed or the number entered is wrong,press the CLEAR key to clear the number and re-enter.Press the ENTER key to enter the access number.When the copy is to be made after the acces number has been entered,the access number must be entered and the access# key pressed to enter the copy mode.Factory initial setting to Copy track mode is OFF.
Jan 03, 2013 | Minolta EP4000/5000 CS/PRO Copier
Where is the battery placed in a compaq presario2100
If I'm thinking about the right laptop, it should be right next to the cd-rom. It should have a little screw undr the laptop that holds it in place. The battery itself slides into the side of the laptop.. Let me know if this solved the problem and good luck..
Sep 09, 2011 | Computers & Internet
Kyocera 1018 me sale error c6400
Zero-crossing signal problem
• The engine board (KP-5238) does not
detect the zero-crossing signal for the
time specified below.
At power-on: 3 s
Others: 5 s
Usually something wrong with electricity..
Try to clear this error:
Enter maintenance mode:
1. Press the system menu/counter key.
2. Select "Service setting" using
3. While pressing the start key and the # key,
4. Select "Maintenance mode" using
5. Press the enter key.
6. Enter the maintenance item
number using the up/down keys.
You need maintenance item 163
1. Press the enter key. A selection item appears.
2. Select "Execute" using the up/down cursor keys.
3. Press the enter key. The fixing problem data is initialized.
May 20, 2011 | Kyocera Mita LaserPrinter FS-1018MFP...
Enter bios password
If you want to add the BIOS password:
  1. Restart the computer.
  2. At the SONY screen, press the F2 key.
  3. In the Setup Utility window, press the RIGHT ARROW to select Security .
  4. On the Security menu, press the DOWN ARROW key to select Set Machine Password .
  5. Press the ENTER key.
  6. At the prompt, in the Enter New Password field, enter the desired password.
  7. Press the ENTER key.
  8. In the Confirm New Password field, retype the same password.
  9. Press the ENTER key.
  10. At the Setup Notice prompt, press the ENTER key. NOTE: To set a user password, repeat steps 4-10, selecting the Set User Password option.
  11. Press the F10 key.
  12. In the Setup Configuration window, press the ENTER key.
  13. Press the RIGHT ARROW to select Exit .
  14. Press the DOWN ARROW key to select Exit Setup .
  15. At the Exit Setup prompt, press the ENTER key.
If you want to remove the forgotten BIOS password:
Please call 888-476-6972 and speak directly to a Sony® support representative for further assistance. A resolution for this issue is available, but for security purposes, this resolution can only be provided by a support representative.
Jun 12, 2010 | Sony VAIO VGN-N385E/W Notebook
I have the code but only says on screen that it is waiting? on my kenwood kdc 6090r
• Security-related information
1. Forced Power ON mode (All models)
Even when the security (Mask key) is approved, resetting
the unit while holding the ATT and Preset 4 keys makes it
possible to turn the power ON for 30 minutes. After 30
minutes have elapsed, it is not possible to return to the
previous condition unless the unit is reset again.
2. Method of registration of the security code after EEPROM
(Tuner Unit ***'y) replacement
(Code security model)
(1) Enter the test mode. (See " 1. How to enter the test
mode")
(2) Press the CLK key to enter the security registration
mode.
(3) Enter the code using the Preset 1/2/3/4 keys.
Example: To enter "3510"
• Press the Preset 1 key 4 times.
• Press the Preset 2 key 6 times.
• Press the Preset 3 key twice.
• Press the Preset 4 key once.
(4) Press and hold the DISP key for 3 seconds until
"APPROVED" is displayed.
(5) Exit from the test mode. (See " 2. How to exit from the
test mode")
(Note) All Clear is not applicable to the security code of
this model.
3. Simplified method of clearing the security code (K Type
only)
(1) While the code entry is requested, press and hold the
VOL UP key for 3 seconds while holding the DISP
key pressed. (This should turn "----" off.)
(2) Enter "KCAR" from the remote. (Same way as the 00
model)
Press the 5 key on the remote twice, then press the
Track Up key. (This enters "K".)
Press the 2 key on the remote 3 times, then press the
Track Up key. (This enters "C".)
Press the 2 key on the remote once, then press the
Track Up key. (This enters "A".)
Press the 7 key on the remote twice, then press the
Track Up key. (This enters "R".)
(3) The security code is cleared and the unit enters the
ALL OFF mode.
(4) If you commit a mistake in the code entry, the unit
enters the code request mode again.
4. Method of writing the Mask key while the EEPROM is in
the initial status
mode")
(2) Press the CLK key to enter the Mask key registration
mode. "TRANSMIT1" should be displayed now. The
display at this time should show " < > " in place of " [ ]
(3) Point the Mask key remote toward the light sensor,
and press and hold its key for more than 0.5 second.
(4) When "TRANSMIT2" is displayed, press and hold the
key on the Mask key remote for more than 0.5 second
again. The first and second counter codes are not
compared at this time.
(5) When "APPROVED" is displayed, the write operation
is complete. Now the demonstration mode is initiated
and the test mode is terminated.
(Note) In the same way as previous models, if 30 minutes
have elapsed with no code written, an error occurs
and the power is turned OFF.
5. Method of initializing the Mask key
(How to reset the unit from the Mask key approved condition
to the factory condition)
mode")
(2) "TRANSMIT1" is displayed and the Mask key entry
request mode is initiated.
The display at this time should show " ∗ ∗ " in place of
(3) Press and hold the key on the Master key remote for
more than 3 seconds.
key on the Master key remote for more than 3 seconds
again.
(5) When "APPROVED" is displayed, the Mask key is
cleared, the demonstration mode is initiated, the test
mode is terminated and the unit returns to the factory
condition.
6. Method of clearing all Mask key-related data
mode")
(3) Point the Master key remote toward the light sensor,
and press and hold its key for more than 3 seconds
(until the level display shows the full condition).
(4) When "TRANSMIT2" is displayed, hold the key on the
Mask key remote for more than 3 seconds again.
If "TRANSMIT1" is displayed in place of "TRANSMIT2",
restart the procedure from step (3).
(5) When "APPROVED" is displayed, all security data is
cleared and the unit returns to the condition before
Mask key writing with the EEPROM in the initial status
Apr 05, 2010 | Kenwood KDC-6090R
Mu burner doesn't run
Hello!
You did not reply i have no idea about your problem.
melnavz
Feb 26, 2008 | Sony (CRX700E) CD-RW Burner
Wireless Switch
open it up, find the wire for the wireless switch dissconnect the wire and strip them and short them. this is only a temporary solution, you will need a new switch.
Nov 10, 2007 | HP Pavilion zd7000 zx5000 zv5000 presario...
jasbo
jasbo
