Question about Proscan Televison & Video
I have a proscan PLED5529A 55 inch tv the picture just went off and no audio so i shut it off. I waited about 10 mins and tried to turn it back on but it just did this blinking thing and after a sort
Have tried unpluging and let all power drain and tried a hard reset but no good
    Top Expert:
  • Proscan Master
  • 74,377 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Posted on Nov 24, 2014
Testimonial: "It does not blink the red power indicator itvkinda flash blinks the screen like its trying to ignite the screen but no luck."
  • The Knight
    The Knight Nov 24, 2014
    That's what I stated here. The blinks to its red indicator itself. These blinks are fault code.
SOURCE: JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Posted on Jul 26, 2008
ginko
  • 19396 Answers
SOURCE: HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
SOURCE: 55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Posted on Sep 28, 2009
SOURCE: TV turns off by itself & won't turn back on til unplugged, then plugged back in
panasonic 50" th50 turned off and wiil not turn on again.
Posted on Sep 08, 2010
maatmartin7
  • 1212 Answers
SOURCE: Have a Magnavox 37mf321d LCD TV, one day, went to
Although a capacitor may look good, it may be weak or bad. Here is what you will have to do. Replace capacitor (location) 2074 which is a 25 volt 2200Mf at 105 degrees. Replace capacitor (location) 2081 which is a 35 volt 1200 Mf at 105 degrees. And you should change capacitor 2066 which is a 16 volt 10Mf at 105 degrees. Please be careful with the last cap mentioned. You can easily tear the PCB trace if you are not extremely careful. This should bring your TV back to life. Thanks for asking and show a few hands of support!
Posted on Dec 25, 2010
32 in proscan lcd tv just turned on tv and colours were all distorted
Try hard reset, unplug TV, wait 10 min. and plug back in.
. You may have to reset your setup configuration back to how you preferred. hope this works for you
Jan 14, 2016 | Proscan 32LB30QD 32 in. LCD TV
Proscan 39 inch led tv lost the picture
If only the picture is out, and audio is normal, the fault is with its back-light inverter board. If both picture and sound is absent, and the standby light is ON, the fault is with its main board. If set is fully dead; even there is no standby light at all; the fault is with its main power regulator [SMPS] board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 18, 2014 | Proscan Televison & Video
Seiki tv troubleshooting
its running hot try to see if its dirty inside and blow it out with air
Jul 29, 2014 | SEIKI Digital ki 55 Class 4K 120Hz LED...
I tried to program a universal remote to my Led Proscan tv and now it just flashes different colors. How do I get it to stop?
hi,
I think some how you have gone into service mode on the tv.
you may need to take it into a repair shop so the can re-set it back.
sounds like it to me.
hope this helps
May 21, 2014 | Proscan PLED5529A 55" LED TV 1920x1080,...
I've recently ordered a Proscan PLED5529A 55" 1080p 120Hz LED HDTV, However, a Proscan PLED5529A-B 55" 1080p 120Hz LED HDTV was sent. What is the difference? One difference i've noticed in the...
Same issue here. I'm debating to send it back as most specs are pointing to the A-B model as being 60Hz. I can't really tell of it's pushing 120 or 60 (ignoring the fact that the screen says 60Hz.) It almost "feels" like it's 120 but can't say for sure. Can anyone please confirm that the "A-B" version is indeed 120 or not? Thanks!
Mar 02, 2013 | Proscan Televison & Video
Zenith 52'' dlp tv won't turn on
after an hour tv shuts off and you have to wait to turn it back on
Jun 12, 2009 | Zenith Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Televison & Video Logo
97 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
