Question about Microwave Ovens
Have power noting seem to be working
Open panel clean and replace
  • 45 Answers
Sounds like a bad control panel. You're probably better off buying new oven.
Posted on Nov 26, 2014
Whirlpool Microwave WMH 1163 XVS-0 How do you change the stovetop lightbulb?
Under the stove top should be a small panel the light emits from. One side of it should have a regular Phillips screw. Unscrew it and the panel should open. It is not hinged so you have to carefully work it open. Once open you should be able to see and then unscrew the bulb, I was able to find a replacement at Home Depot. The installed bulb was 40w, but I was only able to find a 25w replacement. Seems to work just fine though. Once replaced, just work the panel back on and screw back in.
Nov 25, 2012 | Microwave Ovens
GE microwave oven not working
see this causes and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 10, 2012 | GE SpaceMaker Microwave Ovens
Microwave not working after fuse replacement
Test however +capacitor+Rectifier HV+Magnetron for open or faulty.Of course reset the c.breaker for tripped.+Test the power cord too for faulty or open
Sep 24, 2012 | Emerson Microwave Ovens
Kenmore microwave 911 41479791 no power?
Sep 24, 2012 | Microwave Ovens
We have magic chef Over the Range Microwave Oven Model: MCO153U. Microwave was dead and no power
The original problem, was probably caused by a bad door switch along with the fuse, now there is a good chance the control panel is damaged, you will need a professional to assess if the item is worth fixing.
Apr 21, 2012 | Magic Chef Microwave Ovens
Unit was arcing. Checked owners manual and cleaned sensor panel as directed. Stopped arcing. Worked ok for a week. Went to use last night and control panel would light and seemed ok but oven would not turn...
It is quite possible the magnetron has burned out, when it arcs it puts a tremendous strain and causes it to overheat very quickly. On top of that you found a burned mark behind the pad which is not good, so there are least two problems that must be addressed perhaps more. In any case it may be cheaper to replace the microwave oven at this point.
Mar 31, 2011 | Microwave Ovens
The MW died. No power or lites on panel.It will not work.Could this be a panel replacement like on the JennAire range?
Welcome to Fixya Support,
It seems to be problem with panel and before concluding make sure that your Micro Owen Power supply cables and power outlets are working or not. If all are working fine,it is deffinately problem with HV powersuply and Magnetron.
I think it helps.Let me know.
Dec 22, 2010 | Dacor DCM24 Convection/Microwave Oven
I need to replace the control panel on a GE spacemaker 2.0 microwave. Model is JVM2070SK01. How do I remove the power vent to gain access to the control panel?
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at
http://www.microwavedisplay.com and swing it down, but without disconnecting the wires.
If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward.
On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
They're our favorite supplier.
Aug 22, 2010 | GE JVM2070 Microwave Oven
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The panel doesnt work at all.
check the power fuse /if open replace it.
the door micro switch are open/ if open replace new
Jan 03, 2008 | Samsung MW1030WA Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
