Sanyo 42 (maybe 46 or 47)" flat screen hdtv- ONLY during rainy weather- sound gets staticky, and gets to bad, it's unwatchable! Any ideas? When it's not raining, it's perfect! Do you think getting a soundbar would solve the problem?? Any ideas what I can do to fix it myself?
    Top Expert:
  • Televison & ... Master
  • 74,198 Answers
Contact any service technician. This type of fault can occur due to bad solder terminals at its audio output stage circuit inside. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 24, 2014
Where can i find a flat screen tv .replacement screen for a sanyo 42" model 42849-05 new or used.
This is a mistake more than you realize. Screen versions and models are different and quality varies. The QC can be different as well depending on the production lot. You may replace the unit but have an immediate failure or bad quality.
Jul 11, 2014 | Sanyo DP42849 42 in. HDTV
Can you replace a cracked lcd on a sanyo dp42849 42 inch tv
That's a good idea. Screen replacements are not easy to match with any TV. But boards are usually compatible with most TV's of the identical make. You should check that an identical board has the exact same version number too to be compatible.
Jun 06, 2014 | Sanyo DP42849 42 in. HDTV
New (2012) DP42841 Sanyo no sound
Check all the cable connections to audio board for any loose connection. During long term storage, this might have happen. Reset all that cables comes to go out from it. If it do not help you, check the speakers. If all found OK, replace the audio output card. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/Pull up older posts. Check the site in 'Mosaic' view.It will make search easy. Check its audio settings too. Whether it is muted or not.
Jan 05, 2014 | Sanyo DP42849 42 in. HDTV
Why my 42" sanyo DP42841 HDTV LCD SCREEN GOES BLACK ON THE LEFT SIDE?
That sounds like a faulty LCD panel tab. The only true fix is to replace the screen. This usually isn't cost effective.
Jan 19, 2013 | Sanyo DP46849 46 in. HDTV
Sanyo dp42848
That sounds like a Tcon board issue. You can get the Tcon board from www.tvrepairworld.com
Oct 19, 2012 | Sanyo DP42849 42 in. HDTV
My sanyo vison hdtv lost picture maybe a year ago then after sitting all this time i plugged it in and it worked like new then thismorning it lost picture again... screen is black with a little tint of...
This is most likely going to be a color wheel. I would recommend checking on the color wheel first. If this is a dlp tv it could also be a lamp that went out.
Jul 23, 2012 | Sanyo DP42849 42 in. HDTV
FXD-MP690R sanyo problems screen goes dim and no sound, when i bang it on the top it comes right, is there a sensor for heat or maybe loose connection?
Dear ryannaugh
Thats probably the loose connection in the main supply. You can check to make sure any cold solder has taken place. Check mainly in the supply connection and also do not forget to check if any wires are getting shorted together.
DO NOT FORGET TO RATE THE SOLUTION
Jun 27, 2011 | Sanyo DP42849 42 in. HDTV
Sanyo dp42849 tv blinks on then off has sound.was working fine?
If sound stays on and doesn't goes off then you need the video logic main board, if the audio goes out, it maybe the power supply
Dec 07, 2010 | Sanyo DP42849 42 in. HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
