Question about Sewing Machines
My machine won't sew because the up and down button isn't working when I press it, it says stop for safety purposes. What happened and how can I fix it.
  • Jimmie Sill Nov 24, 2014
    Hi Jordan , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? ESPECIALLY THE MODEL NUMBER AND ANY OTHER INFO THAT YOU MIGHT THINK IS HELPFUL.
  • 135 Answers
Change your needle and take bobbin out to see if you have a thread jam.
Posted on Nov 25, 2014
SOURCE: E1 Error
If your sewing machine show's the E1 Error, then you have to open your sewing machine and replace the fuse.(you have to open the right Cover on Front where the Display is placed, because there is the circuit board placed!) There are 3 Fuses in the Sewing machine and they are placed at the printed circuit board. It should be the Fuse in the middle. (not those with the wire in it!) It's not easy at all to open the machine, the best thing you can do (if you have a Digicam) take some Pictures of the wiring so it will be much easier to put it back together. I'm NOT an Expert; but a passionate hobbyist. ;) If you are too; just save yourself further trouble with the helpdesk, and fix it yourself. I hope this post could help you!
Posted on Dec 27, 2006
  • 323 Answers
SOURCE: Janome memory craft 5700, purchased 2004
Take out your bobbin case and examine it for nicks, scratches and or rough spots.If the problem is not too bad it may be possible to buff out the bad spot with an emery stick or emery cloth. If that isn't possible or it makes too much noise after you buff it you will have to replace it. Look especially along the edges and underneath.
sewman7
Posted on May 23, 2008
bargainbox
  • 1388 Answers
SOURCE: janome 5700 handwheel stuck/inside pulley stuck
The error message relates to the motor sensing that it is working unusually hard.........the extra strain will have a physical cause, generally in the hook and bobbin region.......something blocking or slowing things down, so.......
Remove needleplate and bobbin case.
You will probably find an accumulation of lint in and around this area, also possibly in the feeddog channels.
Use a small brush and vacuum with crevice tool to remove the lint and wipe the hookrace with a tissue moistened with methylated (denatured) spirit to remove any dirt deposits.
Also check that the bobbin case is not damaged on the top surface by needle strikes or on the underside rim by the hook gouging as it spins.
If damage is present but mild, you can use very fine emery paper to smooth surface, if more severe, replace the bobbin case. Don't forget to change needles regularly too.
Best of ......
 www.bargainbox.com.au
Posted on Nov 21, 2008
SOURCE: My new home sewing machine( model MX3123) won't go
sound like it needs to be serviced
Posted on Aug 03, 2011
  • 980 Answers
SOURCE: My Shark 7133 slowed down
Slacken the stop motion as if to wind a bobbin and press on the foot control, if the motor runs really fast then you have either thread stuck in the bobbin case area or you may need to oil the machine
Posted on Sep 02, 2011
Janome 6600 bobbin will not wind error "stop for safety purposes"
I have a feeling the sensor has been jolted just enough to make it stop. Pretty sure this can be adjusted by the dealer quickly. Worse case scenario, you'll have to replace a sensor.
Feb 25, 2015 | Janome Sewing Machines
The Yamata sewing machine isn't making any stitches. When a press the peddle the machine makes a spinning sound and nothing happens. If I keep working with it and adjust the controls sometimes it will sew...
Hold the wheel at the end of the sewing machine, and then tighten the hub that is in the middle of that wheel. It is purposely designed to tighten and loosen, so you can wind bobbins up with thread without running all the parts of the sewing machine when you do so.
Jul 20, 2014 | Sewing Machines
Kenmore electronic sewing machine
it's possible that a sensor or computer part of the machine is going bad if the machine has a electronic part to it.
Apr 18, 2014 | Kenmore Sewing Machines
My 6003 Elna machine stop and says stop for safety purposes How do I get it unlock from that It wont do anything
This is usually what happens if the bobbin case gets dislodged, its just held in place by a magnet but if you have a jam up, often gets moved out of position. Remove top metal plate, take out bobbin, and have a look at the bobbin case, should be two metal markers or red dotsmfront side that align. Lift the case out by grasping edge and lifting up and towards you, clean underneath with the little brush, remove any jammed up threads, then return case to position, aligning the marks.
Feb 24, 2012 | Elna Sewing Machines
My Shark 7133 slowed down while sewing and stopped. The handwheel won't turn at all. I cleaned the bobbin area but it still won't work. The light switches on and the machine motor reves up but...
Sep 01, 2011 | Euro-Pro Shark 80 - 7133
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
Janome New Home mx3123 reverse button not working
1/28/13 - I have Janome Harmony 2049 that was initially sewing forward with no reverse and then after about 12 inches of sewing would ONLY sew in reverse. After spending an hour getting the plastic housing off...I was able to locate the shaft that made the reverse. It needed lubrication and after working it in and unjamming the part from the down position, the forward and reverse now work!
Huh, right? Hope it continues to work well. It is a smooth running machine, otherwise. Good luck!
Apr 05, 2010 | New Home MX-3123 Computerized Sewing...
Stop for Safety Purposes ?
I have had this happen to me many times. It really does feel as though the problem is in the bobbin, but it's not. After much aggrivation I took it into the repair shop and found out the thred was comming unhooked on the top not in the bobbin. It still happens all the time but I know what it is now so I just rethred the top.
Sep 16, 2008 | Elna Heirloom Edition 6005
Sewing Machines Logo
55 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
