What kind of adaptor and how many volts - Computers & Internet
  • kakima Nov 23, 2014
    For what make and model?
    Problem Solver:
  • 11 Answers
20v ac adapter for laptops
Posted on Nov 26, 2014
I'm traveling to India where electricity is 240. Do I need to buy a power converter for my Asus laptop?
most laptop power supplies support full range power input. meaning it will accept any normal outlet voltages used anywhere. if you look at the power supply of your laptop it should say vin (voltage in) 100v to 240v 50/60 hz, or close to that if it is.
Nov 01, 2016 | ASUS Computers & Internet
Hello what kind of voltage use the power adapater?
The power adaptor has normally two voltages.
One is primary (Input) which is 110V AC in USA. 220V in UK and others.There are now a days Adaptors which accept both 220V and 110V. However the Adaptor pin will differ. It will be Flat pins for 110V and Round pins for 220V.
The other voltage is the Output which is fed to the Equipment and is Equipment specific. It can be 18V to 5.2 Volt DC. It varies equipment to equipment.. If a wrong Adaptor with output Voltage not matching with equipment requirement is selected, it may damage the equipment. Be careful.
May 21, 2015 | Sport & Outdoor - Others
I have a model-JJB052000-2509 50/60 H2 Output5V-2000mA and I need power adaptor can you help me?
pls let me know where do u live,,you need 5volt 2 ampere adaptor,,u may use 2-5 ampere also,,volts should be =5 volts,,,u can charge ur note with laptop usb connector also,,,or u can find this adaptor on amazon.com,,,ali express,,,or any other as per ur area
Jan 27, 2015 | Archos 101 Internet Tablet 16GB 10.1"...
Ti-5033 sv calculator, the 6 volt adaptor doesn't
No...most of the time it is the jack in the back of the machine where the adapter plugs in that goes bad... the problem is usually not the adapter but the plug in....
heatman101
Jun 18, 2011 | Texas Instruments TI-5032 SVC Calculator
Where can I find a replacement 120v ac adaptor for a Thor X flashlight?
My Thor X 10 million candlepower spotlight takes a standard 12 volt, 1500 mA, center positive AC adaptor. You should be able to find one with an appropriate tip at any Radio Shack store, but you may find a cheaper universal adaptor at a Walmart or even at a "Dollar Plus" kind of store. An adaptor with a lower mA rating will take longer to charge your light, but it should still work (down to about 750-800 mA, I'm guessing).
Double-check the charging port of your Thor light to see whether there's any information about the input voltage requirements. On mine, the light itself has the charging port labeled for 12v, though I was reading the more detailed specifications off the adaptor itself. I can't recall whether the 2.5 million candlepower light also uses 12 volts of power (I think it does), or whether it takes 6 volts (a single battery vs. two batteries wired in series).
May 18, 2011 | Cyclops Thor 2.5million Rechargeable...
I have a power on board veco12pob 450 amp jump starter unit and my question is what kind of adaptor do i need . I would like to know the volts and amps.
I have the same problem: today I tried a 12 volt, 1500 milliamp (1.5 amp) power cord and it has charged mine halfway, so far. It fits the plug in, but not certain, yet, that it has enough power to fully charge.
Jun 29, 2010 | JUMP START SYSTEM
I have the driving force wheel but the adaptor is missing, what kind of adaptor do I need? How many amps and volts?
Look on the back or the botton of the wheel. It should tell you the Volts and Ampage. Then just look on ebay for a cheap adapter
May 20, 2010 | Logitech DRIVING FORCE FEEDBACK STEERING...
Hi hope you can help i have just bought an Alpine CDA-9835R
What kind of car are you trying to put it in? There are many different cars out there that require the use of an antenna adaptor to make it fit the standard "motorola end" of the aftermarket stereo. The Alpine needs to "see" 12 volts constant power on the yellow wire and 12 volt switch (key on) on the red. Good luck
Mar 01, 2010 | Alpine CDA-9835R CD Player
Portable fm/am/sw radio
yes you did! you overstressed the components of the radio plugging a 6V instead of a 3V adapter!
Nov 01, 2007 | Audio Players & Recorders
Compaq Armada 7400 AC Adaptor Pins
Below is the URL for compaq's Service Manual for that model. This shows you the details of every single part & how to disassemble and reassemble every screw. Surely it has to be in this document, somewhere. --> ftp://ftp.compaq.com/pub/supportinformation/forum/portables/7400msg.pdf
Aug 04, 2007 | Compaq Armada 7400 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
