Question about Polk Audio PSW Series PSW10 Black 10-inch Powered Subwoofer Each
<!-- from fixya rte -->Where is the fuse in Polk psw 10 subwoofer? - Polk Audio PSW Series PSW10 Black 10-inch Powered Subwoofer Each
You will have to remove the plate amp and look on the pcb, it is generally located near where the main power lines come in.
If you still can' find it contact Polk tech support, Ive owned several Polk products and always found there tech support very helpful; very helpful;
Tech/Product Support
9AM-5:30PM EST Mon-Fri
1-800-377-POLK (7655) Option 1
FAX: (410) 764-5470
polkcs@polkaudio.com
International: +1-410-358-3600
Posted on Nov 24, 2014
What type a fuse do I use for my Psw 125 power sub
Is this a Polk PSW 125? I'd contact Polk customer service.
Here is the manual http://www.polkaudio.com/Media/POLK/Product%20Manuals/PSW110_125_MN.pdf
There is some discussion here http://forum.polkaudio.com/discussion/77264/psw125-blown-fuse
A blown fuse indicates something wrong. I'd contact Polk.
Nov 17, 2015 | Audio Players & Recorders
PSW 125 Diagram Schematic
download with model number suport e-manual pdf
Aug 28, 2014 | Polk Audio Psw 300-watt 12" Powered...
Which amplifier plate can use for Polk Audio PSW 1000
call parts express tell them your problem and they do have a plate amplifier that will work actually it's a better amp with more power.
Jun 14, 2012 | Polk Audio PSW1000 Subwoofer
My polk psw 10 keeps blowing the 2a fuse as soon as i plug it in ? Any solution besides the dump ?
Unplug the power, get inside it and disconnect either lead to the driver; stand back and plug it in to see if that helps. If so, the woofer is shorted and can be replaced failry cheaply. Otherwise it's probably more complicated and expensive for a hands-on tech to isolate the electrical problem.
Dec 23, 2010 | Polk Audio Audio Players & Recorders
Optimum set up for Polk Audio PSW 10?
Run 2 RCA cables from the two Purple connections on your Receiver (Labled "PRE OUT SUBWOOFER") to the Red and White connectors on the back of your Sub (it does not matter which Purple connecter you plug into either the Red and White)
Set the volume control on the Sub to about 75%, and keep the power switch in the "ON AUTO" position. To set the Low Pass value, look at the back of one of the front speakers in your setup, and note its frequency range (will look something like 100Hz - 17kHz). Set the Low Pass at a value slightly higher than the low value on the back of your surround speakers.
To set the phase switch, stand in the middle of the room with some music on (something with some bass, but not over the top bass) and have someone switch between 0 Deg and 180 Deg. Listen for which setting sounds "Louder and Fuller". This is the one you want. You will need to do this each time you move the Sub, as its position may change its phase in relation to the rest of your system.
Good Luck!
Mar 26, 2010 | Polk Audio PSW10 Subwoofer
My Polk PSW 303 subwoofer emits a hum when plugged in and powered off. When the unit is turned on the hum gets louder. At this point the unit is useless. Does anyone know what could be causing this?
Hiya sounds alot like there is a power supply issue with the unit that will require repair for it to be doing off or on. Probably wont be to expensive, request a quote first to make sure viable.
Best of luck
Jul 16, 2009 | Polk Audio PSW-303 Subwoofer
Polk Audio PSW 350 sub has no power
Hi, Just call the parts line at Polk Audio. They should have the fuse. You can also ask for technical if you're not sure of the problem. Here's the number for Polk: 800-377-7655 Good luck to you.
Dec 30, 2008 | Polk Audio PSW350 Subwoofer
PSW 10 Not working
Your 2A 250v slow-blow fuse is blown, located under the back pannel. Mine just did the same thing. Problem is the problem with my PSW10 goes beyond the fuse. I have contacted Polk tech support to help me trouble shoot.
Sep 06, 2008 | Polk Audio PSW10 Subwoofer
Polk Audio PSW Series PSW10 Black 10-inch Powered Subwoofer Each Logo
210 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
