How do I get cc on model KDL-37M3000. I had to reactivate my digital receiver and lost the captioning.
    Top Expert:
  • Televison & ... Master
  • 36,279 Answers
Closed captioning is selectable as part of the initial set up routine. You need to return to initial set up and reselect it.
Posted on Nov 23, 2014
How can I turn off CC on my SONY 52XBR. I used the Remote control settings and selected off on the cc display, but the cc never turns off. I also used the menu button on the side of the T.V to select
If Closed Captioning is being displayed even though the CC option in the TV menu is set to Off , then it is being produced by another device, such as a cable or satellite set-top box. To remove the Closed Captioning from the TV screen, it must be disabled on the device that is decoding the Closed Captioned signal.
NOTE: Some set-top boxes may automatically display Closed Captioning on the TV screen when the set-top box sound is muted. If this is the case, turn off the Mute function of the set-top box
Oct 31, 2014 | Sony Tv Xbr Bravia Kdl-52xbr5 52 Lcd Tv...
How do I turn off the caption on this freakin Sharp Liq. Crystal T.V.? I lost the manuel! IT'S NOT A SANYO...IT'S A SHARP T.V. MODEL # LC40E77UM
hi,
For switching off the closed caption option do the following.
1. Press CC on the remote.
• This will present the Closed Caption information display.
2. Press CC while the Closed Caption information is
still on the screen.
• Press repeatedly until you select the desired closed
caption service as OFF.
ok
Feb 25, 2011 | Sanyo DS31520 31" TV
Cant turn off closed caption
sherrillbrom
With our VIP receiver models, you have an option to turn on/off closed caption through the receiver. Press the Menu button on the remote, which will display the Main Menu on the TV screen. Press 8 (Preferences) and then press 6 (Closed Caption). On the Closed Caption screen, press 1. On the Closed Caption On/Off screen, select CC Off and then press Done from the TV screen (using your DISH remote). This will turn the feature off on the receiver. Test to see if it is turned off by watching a program that has CC. If it still appears, then the feature is activated through your TV. Please refer to your TV manual to turn the feature off. I hope this helps.
Ray Calo
DISH Network
Feb 21, 2011 | Televison & Video
My closed caption on my new dynex 26L 150A11 will not turn on. I have followed all instructions in the book. I need the cc. any one have an answer? thanks cosycat
There are several possibilities here so you will need to work with me to resolve this problem. In order for Closed Captioning (CC) to work, you need to make sure the CC settings are correct on the TV, and then make sure they CC is switched on. In addition, if you are using a cable or satellite receiver box, CC also needs to be switched on for these "boxes".
It's easiest to start with the TV. Please make sure you have done the following:
1. Check the Closed Caption settings are as follows from the TV on-screen menu as follows:
a) Press the "MENU" button on the DYNEX remote
b) Press the RIGHT arrow twice to highlight the "SETUP" menu
c) Press the DOWN arrow once to open the "SETUP" menu
d) Press the DOWN arrow twice to highlight "CLOSED CAPTION"
e) Press the RIGHT arrow or the "ENTER" button once to open the CLOSED CAPTION MENU
f) Make sure the Closed Caption option "CC MODE" is set to "ON". This can be changed using the UP/DOWN arrow keys to highlight "CC MODE" and using the LEFT/RIGHT arrows to switch between off and on.
The "Basic Selection" and "Advanced Selection" settings are for analogue and digital closed-captions respectively. In addition, the "Options" sub-menu can be used to change the size and style of the digital closed captions (Advanced Selection). All three of these options should eventually be set according to your personal preferences, but for the purposes of making sure it is working, I suggest you set them as follows:
Basic Selection = CC1
Advanced Selection = Service 1
These options are the basic settings which will display only the spoken dialogue of the TV program.
g) Press "EXIT" on the remote to close the menu and return to viewing mode.
2. Press the "CCD" button on your Dynex remote control. This can be found in the bottom right-hand corner of the remote. Each press of the "CCD" button will cycle the closed captions between ON and OFF. (CCD means Closed Caption Display)
3. Check the Closed Captions are displayed and then adjust the Basic and Advanced Selection options until the type and appearance of the closed captions are how you like them.
If you have done the above and still cannot get it to work, please let me know whether you are using a cable or satellite receiver and the brand/model number. I will then be able to assist you further.
Regards,
BElectric
Dec 30, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Sony Bravia KDL-32XBR4, closed caption turned on and being displayed. We wanted to use the "display options" to make the closed caption bigger. The "this is how it will look" looks...
Go into the tv menu again,Go to"Display Options"closed captioning u pick captioning bigger for as a default,but did u push the button on the remote said Enter?Press the enter button for the defualt caption will see the left side of the tv captioning default u want.Now the if u,used the CC button.U will get the bigger bold matalic captioning u want.
Nov 24, 2010 | Sony Televison & Video
How do you remove closed captioning on a Sony Bravia TV - model KDL 40V5100?
Hi:
In your menu there is a option for CC, use this menu option to set CC to the off posistion.
Aug 22, 2010 | Televison & Video
Have a KDL-52BR4, cant get rid of closed caption on the screen even after pushing cc button on remote
If you are using a Cable Box, make sure that CC is off. Same applies to a satellite receiver. If you don't have either of those then I would contact your service center to have it looked at. The micro is the only thing that can cause that, providing your sure about how to turn the closed caption off in the menu. Try that way first, instead of using the CC on the remote.
Aug 19, 2009 | Sony Televison & Video
Sony Bravia KDL-37M3000, bought June 08. The
Get a digital antena,If u using the signal over the air,rescan.If the signal is cable or other pay tv signal.Ur digital turner,it damage.
Jul 09, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
CC will not turn on....
There are usually several versions of the closed captioning. Cycle through them to see which ones work. Turn one set on...wait a few minutes...if that does not bring up the captioning during normal shows (not commercials)...try the next set.
Feb 26, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
