There isn't anything about catv - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,118 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 24, 2014
Not getting all the channels- only 2 - 13 and auto set isn't finding the others. Apreciate any help.
Look in the setup menu, set is now set to air or antenna which on cable will only allow channels 2-13------------if on cable or such switch the setting to catv/cable and not to air/antenna.
Dec 21, 2012 | Televison & Video
I have a Jensen TS2750J model ... am trying to hook up and be able to process the HD that the home I rent a room from receives that signal from their cable company ... but don't know how to get my TV...
Hi.
The setting on your tv for the best signal is the HRC setting.
HRC stands for High Resolution Cable.
If you connect the cable to the blue jack, and set your tv to HRC, when you scan for stations, it should pick up all of them, not just the analog cable stations.
Now, some cable companies require an additional adapter, provided by them, in order to recieve the cable signal properly.
This adapter is called a digital transport adapter.
You should contact the cable provider, and see if the adapter is required in order to recieve their signal properly.
I hope this helps you out.
Good luck to you, and have a good day.
Jun 27, 2011 | Jensen Q2749J 27" TV
I just need to know how to link up my Allegro DVD/VCR REMOTE CONTROL to my Phllips Magnavox Television.
TUNING This DVD+VCR is equipped with a frequency synthe- sized tuner capable of receiving up to 181 channels. These include VHF channels 2-13, UHF channels 14-69 and CATV channels 1-125. Auto Channel Programming 1. Choose the SOURCE SELECT option, then use b / B to select TUNER. Use b / B to switch among TUNER, LINE1, and LINE2. 2. Choose the AUTO CHANNEL SET option, then use b / B to find channels. • The tuner will automatically cycle through all available channels (TV/CATV) in the area and place them in the tuner's memory. •After the AUTO CHANNEL SET is complete, the TUNING menu will hide and return to the TV screen automatically. 3. Make sure the TUNING BAND is set appropriately (TV or CATV). • TV : If you are using a standard antenna to receive channels. •CATV : If you are using basic cable to receive channels.
Oct 15, 2010 | Allegro DVD/VCR ABV511
How can i get my tv off catv? without a remote
Press the menu button on TV
Use the ch +/- and Volume +/- to move within the menu
Go to SETUP
Go to TV/CATV and the select TV
This will take it off of the Cable settings and put it back on Antenna
Good Luck...
Mar 05, 2010 | Toshiba 32A33 32" TV
How do you change the tv from CATV to just TV in the programming?
the tv doesn't need to know that the signal is coming from a dish, so the use of catv while using direct tv should be okay. it seems that the problem may be with where you are making the connection from the direct tv box. plug it in where you would a cable box cable.
Jan 24, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
Emerson ewv404 catv to antenna
There is an option in the menu which changes the tuner from cable to antenna (off-air or broadcast) mode. On many/most late VCRs, you must have the remote box to access these functions.
Old VCRs (15 years +) might have had a switch to make this change.
Nov 01, 2008 | Emerson EWV403 VHS VCR
SYLVANIA LC200SL8 ? 20" LCD-TV Settup up channel setup
This is the chanel set up options I see on the online manual:
- CHANNEL SETUP -
ADD/DELETE(DTV)
AUTO PRESET CH(DTV)
AUTO PRESET CH(TV/DTV)
AUTO PRESET CH(CATV)
! CATV takes approx. 50min.
To set up for over the air broadcast that local channels now have in HDTV, you will select AUTO PRESET CH(DTV). You will have to disconnect cable for this option; however, the cable company will send local channels over the cable.
Bottom line, if you have cable, use it, it will most likely still deliver the best signal.
So coonect cable and use this option:
Oh, and the reason it takes so long is because there are more channels to scan with cable then with the local over the air channels.
Aug 23, 2008 | Televison & Video
My Quasar VV8220
According to the manual, follow the steps below to program channels on your Quasar VV8220 TV:
1) Hold the CHANNEL MEMORY Button on your remote in and press the 1 key
(a box will come up where you can shift between TV & CATV --
you will want to be on CATV (for cable channels).
2) Press the 4 key which will change from TV to CATV -- make sure it is
on CATV or if it is already on CATV, press the 5 key.
3) Press the 4 key (the auto set guide will engage and go through the channels).
Hope this is helpful.
Aug 14, 2008 | Televison & Video
CATV access
you need to hit the input button on your remote to CATV and u will get the cable channels
Jul 16, 2008 | Emerson TC1351 13" TV
Intructions for programming a remote control
I own this remote. Here are the instructions.
1 turn on your tv or catv
2 aim remote at tv or catv
3 while holding tv or catv button press 0 to 9 last ch 100/ent or channel
4 release both buutons when tv or catv changes channel.
note press tv or vcr or catv button first to select desired function
Mar 06, 2008 | Hitachi VT-RM380A Remote Control
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
