Firstly,make sure machine is turned off at the wall.the easiest way is,by carefully putting a small flat blade screwdriver under the plastic ring that holds the door seal to the case of the machine, gently pry the ring off the machine. Now peel the door gasket away from the shell and fold it inwards into the drum.
You may need a torch now. Pushing the gasket back look into the left, front of the machine and on the front of the tub you'll see the fill hose that comes from the soap dispenser. Check that the hose has not come loose, or possibly rubbed a hole in it off the tub. You can re-seal it by just applying standard silicone/mastic.Re-fit in reverse, but firstly open the door gasket clip completely to making fitting possible. Once you've fitted it just give it a good squeeze.
