Question about Hoover Washing Machines
How do i access the fill pipe on a hoover WMH148DF
It seems to have come loose from the outer drum
The fill pipe goes thru the soap tray to the fill to the drum
so remove the soap tray drawer
usualy behind the drawer is the screws to release the inlet matrix
you may find you need only re- attach the pipe with little sruggle
i use some evostic glue let it go tacky place the tube back then tease the clip over with plyers
this forms a good seal
i think perhaps a drum suspension piston isnt so hot
if its throwing pipes off...!!
Posted on Dec 08, 2014
  • 1462 Answers
SOURCE: loose drum!!!!
inner drum is tightened usually with a bolt thro the main pulley (sometimes a nut) but this is unlikely to be the problem. suspect you bearings have worn.
Posted on Apr 24, 2007
  • 38 Answers
SOURCE: Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Posted on Mar 05, 2008
onthejob5130
  • 640 Answers
SOURCE: spin cycle very loud,
spin surpport defective,,,this part is under warranty,,lifetime warranty..contact whirlpool for replacement of spin basket,,onthejopb
Posted on Feb 07, 2009
beltronic205
  • 1474 Answers
SOURCE: loud noise during spin
Sounds like drum bearings gone..Quite expesive repair
Posted on Oct 03, 2009
  • 353 Answers
SOURCE: loose part in drum area
unplug machine go to botton remove large outlat hose9attached to the drum and pump u can then work inside through the hole
Posted on Mar 20, 2010
The fill pipe has come loose from the outer drum on a hoover WMH148DF Washing machine how di get at it?.
Firstly,make sure machine is turned off at the wall.the easiest way is,by carefully putting a small flat blade screwdriver under the plastic ring that holds the door seal to the case of the machine, gently pry the ring off the machine. Now peel the door gasket away from the shell and fold it inwards into the drum.
You may need a torch now. Pushing the gasket back look into the left, front of the machine and on the front of the tub you'll see the fill hose that comes from the soap dispenser. Check that the hose has not come loose, or possibly rubbed a hole in it off the tub. You can re-seal it by just applying standard silicone/mastic.Re-fit in reverse, but firstly open the door gasket clip completely to making fitting possible. Once you've fitted it just give it a good squeeze.
Nov 23, 2014 | Hoover Washing Machines
Hoover 5oom overflows when filling
Check to make sure the the tube that runs from the top panel down to the pressure weir on the side of the outer drum is in place, These can come off with vibrations, if this is ok your pressure/level dial needs to be replaced.
Mar 05, 2012 | Hoover Washing Machines
Does not stop filling up with water
the over fill valve is blocked up or stoped working if the little pipe that come's off the bottom of the outer drum is blocked up then this valve wont shut off the water flow and it over fills have a look inside the washer find this valve and pull off the pipe then,,, "blow hard" down the pipe till you here air from the bottom of the drum,,,if its blocked it should now work ok they get blocked with sope!
Aug 10, 2010 | Kenmore 22422 Top Load Washer
Door seal on servis M9824W has been removed to access bits in the drum. how do i refit it.
The door seal, the hot air inlet and door seal overflow pipe had been disconnected from the drum. Main problem was access to reconnect the door seal overflow which is a very short pipe section going to a small hole in the front of the outer drum and access very difficult.
First remove the top cover of the machine. Two very long screws and two self tappers at the top rear of the cover.
Make sure that the hot air duct is disconnected from the heater outlet and remove the separate plastic duct which bridges between the heater and the hot air duct in the seal.
In this case the door seal had been pulled off the outer drum and the retaining coil spring had also been recovered. If the seal is still in place there is a "handle" moulded into the seal which might assist in starting the removal of the seal.
Remove the outer seal from the front panel of the machine by easing out the wire and spring retainer which can be accessed by the door hinge. Carefully remove the door seal from the front panel and remove it.
Check for damage and if necessary get a replacement.
To Refit
Push the door seal into the machine loosely and connect the overflow pipe (very difficult access). I leaned the machine on its back to make access a little easier.
Next carefully fit the seal onto the outer drum starting at the bottom by the overflow pipe. Be very careful not to disturb the previously fitted overflow pipe. Make sure the seal is correctly fitted over the retaining flange on the drum.
Next fit the retaining spring by threading it behind the overflow pipe and into the recess on the outside edge of the seal, connect the two ends of the spring together to form a circle and carefully stretch it into place around the door seal. Take care at the top to make sure it goes behind the hot air inlet duct.
Apply a little gasket compound onto and under the lip of the overflow pipe where it enters the outer drum at the bottom (a bit messy and awkward).
Next fit the seal to the front panel of the machine ensuring that the tabs on the seal are aligned with the markings around the front edge of the door aperture.
Fit the wire and spring retainer such that the coil spring sits on the left side of the opening within the moulded recess in the door seal.
Now refit the hot air inlet duct between the heater unit and the door seal ensuring that the parts are it the correct position and the two lugs are stretched over the the small spigots on the heater body.
It took 4 hours to do the job but that included the learning curve. Reckon it should only take an hour if two peaple are available when fitting the inner and outer seal retaining springs.
Nov 03, 2009 | Washing Machines
Bra wire's trapped between inner and outer drum,
If you cant pull wire out from inner drum with long nose pliers, Remove heating element and use torch to inspect bottom of washer. Most of the time the obstruction makes its way to the bottom. Use whatever tool necessary to remove spring.
Sep 25, 2009 | Hoover AAA160 Front Load Washer
I HAVE A HOOVER HAH2406 MY PROBLEM THAT THE WASHING MACHINE STILL GETTING FILLED BY WATER THOUGH THE MACHINE IS OFF.THE WATER IS FLODDING THEN FROM THE FRONT DOOR
This is either the large pipe that connects from the BOTTOM of the outer drum, to the suds pump inlet, or the pump body itself, or the seal inside the pump. This may be tricky to work out where the leak is coming from, but just use a good torch, with the back removed, and watch it through a short cycle. If it is a plastic pump, they usually have small star-screws holding the 2 parts of the pump body together. Try tightening these, if they are loose. If the machine is over 8 years old and has had a lot of use, it will most likely be the pump seal.
Aug 29, 2009 | Washing Machines
Hoover hnf 6167 noise when spinning and one of the drum tumbler things keeps breaking off
the screws that hold the baffle on have worked loose and are rattling around in the outer drum. causing both nopise and baffle falling about.
Sep 21, 2008 | Washing Machines
Water Accumulating in Washing Machine Drum
Could be draining from your sink outlet. Ensure the outlet pipe is routed higher than the sink trap. Normally attached underside of the work surface.
Mar 04, 2018 | Hoover Washing Machines
Mar 05, 2008 | Hoover AAA140 Front Load Washer
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
