Question about Video Cameras
Tried everything and cannot get my receiver to pair with my camera
I have tried everything. The cables are all correct. Had it paired and working for about 3 months. It then quit and I haven't been able to re-pair it sense. Light is flashing slowly. It doe not recognize the camera anymore. Hooked the receiver to the computer and it recognizes the receiver but still won't pair up.when hooked to the DVR, the screen turns white as it is waiting for the camera picture. What is wrong or is my camera toast after only a few months
SOURCE: JVC GR-270U Blue screen with playback
a 1394 cable is specified for the GR - D - 270 but the GR - 270 U , not listed ( does your camera use VHS/c , or mini DV tape ? )
Posted on Aug 16, 2007
SOURCE: Canon ZR850
I was told by Best Buy I could use the USB to transfer video which is not the case, you have to get the firewire cable. To get the computer to recognize the camera (for still images not video) you have to have the memory card in the camera then hook up the USB.
Posted on Dec 09, 2007
SOURCE: sony handycam DCR-HC26 and mac not recognizing with firewire
mlkml
Posted on Apr 23, 2008
SOURCE: USB DEvice not recognized
I had a problem like this -- tried plugging the camera in to the rear USB slots not the front ones and it worked fine.
I think that it doesn't like going via a USB hub, but wants a direct connection. All of the USB ports on my computer are connected direct to the motherboard (i.e. none are on PCI cards or anything), but looking at the hardware info for the computer, it looks like the motherboard has a few "direct" USB connections, and then an on-board hub which the front ports connect to. If your computers are the same, that would explain things. I'd suggest trying each USB port one at a time (turn the camera off before plugging in, and back on when in) and see if one of them works. Wouldn't hurt to power the camera from the mains at the time too.
Posted on Feb 22, 2009
SOURCE: computer won"t recognize new camera
j need driver for canon powershot A 470
Posted on Apr 03, 2009
Pioneer vsx-5231 not pairing with Phillips bdp-2175 smart bluray player
have you tried to connect the Philips direct to the TV's hdmi?
Could be the resolution on the bluray is set to 1080p which may be out of range for the receiver or even the TV for that matter. If you can reset the output resolution of the bluray to 480p first, just to establish a picture then try 720P which all HD tv's and receivers can handle.
I did a quick search and could not find the resolution reset procedure for this unit. Other units will reset if you press and hold 2 or more buttons together.
May 04, 2014 | Pioneer VSX-521-K 5.1 Channel A/V Receiver
Uniden survaillence system will not pair with this camera but says it will pair with any wireless camera. How do I pair the GE with Uniden
I am not aware that Uniden survellience systems pair with cameras other than a Uniden camera. Please provide model number of your Uniden system to help with a solution to your problem.
I understand that GE Add-On Wireless Digital Color Camera 45256 will work only with a GE security system like Ge 45255
Apr 27, 2014 | GE Add-On Wireless Digital Color Camera...
My samsung video monitor (sew3030) says out of range and I have tried everything and nothing works.
I had this same problem all i did on the menu went to the option where it has the monitor and the camera behind it and click on the middle button (select) and it says pair it and some seconds then you click the button behind the camera and that was all i had to do hopefully it solves your problem if not this is the number you can call for technical support 1-877-349-3149
Mar 04, 2012 | Samsung Wireless Baby Monitor Camera...
Installed Pioneer DEH P6200BT. Experiencing BT problem. Everything seems to work correctly, locating, pairing, receiving calls, dowloading address books, all of that works correctly. The problem I have is...
Hi! I just figured this out myself. The radio only sends the phone call audio to the front speakers. My car only has wires for one set of speakers, so I chose the rear channels. I just rewired to the front channels instead. Solved! Bad on Pioneer, there is absolutely no mention of this in the installation or operation manual.
Dec 07, 2010 | Pioneer Car Audio & Video
My summer best view handheld video monitor says out of range and will not pair.
Have you tried pressing the pairing button at the back of the camera unit and press the scroll button at the center of the receiveing monitor at the same time as suggested by the manual? I had the same problem, followed the manual instructions and solved it. (Greetings from Mexicali, M
Sep 06, 2010 | Summer Infant Best View 25" Color Video...
Bluetooth headset now will not pair up with my LG enV
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
Jul 20, 2009 | OEM Systems Motorola Bluetooth Headset...
I am trying to pair Visor Blade,Supertooth-Lite with mobile phone
Try holding down the green button release the mike then enter 0000 the phone should then pair. This worked for me so I hope it will work for you.
Mar 16, 2009 | Cell Phones
S-Sir Sub Unit won't pair
In order to properly pair the units, verify that the channel switch on the back of the sub units are set to either A, B, or C. Then go into the setup menu and go to setup tab. You can then scroll down to system setup. Verify that the base unit is set to the same channel as your sub units A, B, or C. You then can choose the pairing operation. Have your sub units close to the base and on for this operation. They must be linked to have the pairing operation work. The pairing option will ask if you are ready to pair a sub unit. Select OK. You will then be instructed to begin pairing. Find the pairing button on the back of the sub unit and depress. Depending on the sub unit you may see a red light flash or the front display will say pairing. Once complete the menu screen on the TV will tell you that the pairing is complete and ask if you would like to do another unit. Continue if you have another unit or select OK to complete the process. Once you return to the system setup menu the channel indicator A, B or C will have the work pairing next to it (i.e A (pairing)). If you continue to have trouble you can change the RF channel on the system setup menu from AUTO to ON. Good Luck. CEB
Jan 29, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Pin number for philips SHB6100 aside from 0000.
yeah hedenram is right. my problem was that i was trying to pair something WITHOUT the headset in pairing mode. just switching it on doesnt put the headset in pairing mode and it will reject the 0000 passkey even if this is correct. it is vital when you turn on you hold the power button til it flashes red/green and then it will be in pairing mode and accept the 0000. the only way i found this was in the instruction booklet which i thought i had chucked away
Oct 22, 2008 | Philips VOX120 Wireless Headset
Sony DSC-S650 ( 7.2 MP and 3x zoom) - Not working
I have the same camera and have had the same problem. The first time I had to change batteries I could not find lithium batteries and ended up trying alkaline batteries. I was only able to take 1 or 2 pictures before they would die and the camera would shut down. When I switched back to lithium batteries, everything worked fine. I hope this helps.
Dec 30, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Video Cameras Logo
154 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
