Question about LG LM6700 47 in. Cinema 3D Smart TV
I'm trying to connect my camcorder with the red/yellow/white lead however my lg tv doesn't seem have these sockets to plug into. It has two AV sockets one says rgb the other has two input sockets one
I'm trying to connect my camcorder with the red/yellow/white lead however my lg tv doesn't seem have these sockets to plug into. It has two AV sockets one says rgb the other has two input sockets one green the other yellow. Any ideas on how I can get connected?
    New Friend:
You are probably looking at a component input, which is a high definition set up. Often the red/yellow/white (or composite) inputs on newer TV's are located on the side for easy access. Check both the left and right side of the set to see if thats where they are.
if they are not there, what model LG TV do you have?
Posted on Nov 23, 2014
sandrew
  • 2961 Answers
SOURCE: LG - 42PX5D Input switching problems
I think the problem stems from the HDMI port and scart ports, i have read somewhere on a sound and vision web site that these two conflict and when HDMI is in it only sometimes blocks out the scart signal. This could be what the problem of the freezing is, as when all said and done its just a very large pc monitor; and look at the trouble they can get in!.
Posted on Jan 17, 2007
  • 52 Answers
SOURCE: LG plasma buzzing
Problem is probably with your cable box as you have confirmed that the set is working by using the dvd player, that is unless you have a bad cable for the cable box.
Posted on Aug 12, 2008
freetek
  • 5568 Answers
SOURCE: LG 42'' TV has no sound but great picture. How do I get the sound?
You shouldn't need anything plugged into the accessory jacks to get local sound from your set. Go through the main setup menu and check audio settings; they may be set to turn off the internal speakers to send the sound to a home theatre that you apparently don't have. Most sets have that as a selection and supply L-R audio for an external system and mute the internal speakers.
FYI: The three connectors you mention are coded as follows:
Red - right channel audio White - left channel audio Yellow - composite video (contains synchronization signals and video)
These may be input connectors (for external VCR/DVD decks) so check your owner's guide to verify.
Posted on Nov 23, 2008
SOURCE: LG 32LG30 no signal when pc and tv r connected via rgb cord
For No signal try- Updating your Video drivers, and making sure it shows a connection on your laptop ( by going to propertys on desktop and then dysplay)
For format try- Updating and or turning down the screen resulotion becuase the size differs on screen even if you think it shouldnt.
Posted on Jul 08, 2009
vinnyq
  • 157 Answers
SOURCE: My wii connection is black and white
You are connecting it into the wrong input. The Wii comes with a RCA cables that should go into the Video (composite) input that has yellow, red, and white. The component input will not work with the RCA cable input. Plug your Wii into Video1 and you should get the right colors. There should be another HDMI on the side of your TV, there are inputs located both on the back and side of the TV for your convience.
Posted on Oct 10, 2009
Camcorder to vcr a/v hook up and record
All you need is an connecting lead that comes out of the camcorder and that terminates in three phono plugs. One yellow (video) one red (right audio) and one white (left audio). As you can see from the stock picture on your post the VCR front has the corresponding coloured sockets. So you plug them into that. Sometimes these sockets are hidden on a cover. If your VCR hasn't got them, you can use a scart socket located on the back. You get a scart plug with the same connections. If it has male plugs you will need to get 3 female in-line connectors to connect your leads.
Once connected using the VCR menu or the channel selector, select the AV socket you have connected the camcorder too. Start it playing and you see the picture. Providing you have a tape in the VCR pressing record will capture the picture from the camcorder.
Feb 06, 2015 | Televison & Video
Wii does not show up on the tv screen
This problem is likely due to a problem with your AV cable. Try the steps below to get your Wii up and running.
  • Make sure the Wii is turned on and all cables are plugged in.
  • Unplug the AV cable from the T.V. (The AV cable has a red plug, a yellow plug, and a white plug.)
  • Plug the AV cable back into the television making sure that the red plug goes into the red socket, the yellow plug goes into the yellow socket, and the white plug goes into the white socket.
If problems continue try replacing your AV cable with a new one.
Jun 16, 2011 | Nintendo Wii Console
Doesnt show up on the television. It does turn on. turned playstation on and off, tried different connections, still nothing
It is likely that the problem is your AV cable. This cable has one plug that connects to your Playstation 3 and a red plug, a white plug, and a yellow plug that connects to your television. Follow these steps to get your PS3 up and running again
  1. Unplug your AV cable from your PS3 and T.V.
  2. Plug in your AV cable to your PS3 and T.V.
When plugging your AV cable back into the T.V. make sure that the red plug is in the red socket, the yellow plug is in the yellow socket and the white plug is in the white socket.
If problems persist try using a different AV cable.
Jun 13, 2011 | Sony Playstation 3 (PS3) Console
What type of av cable is compatible with a Canon MV530i camcorder?
The AV lead for your type of camera is a triple-segment mini-jack, which leads to yellow, red and white phono plugs.
Yellow is for composite video, white is for the left stereo and red is for the right stereo channel.
Mar 27, 2011 | Canon MV530i Mini DV Digital Camcorder
I have a new LG SL90 television. I also have a
If you do not have a scart socket available on the tv you need to get a wii component cable that contains the six input jacks. HD tv's tend to have these inputs on the back, you have the normal red, white and yellow jacks plus another red green and blue you'll need to plug in from the component cable. If you have an AV input with just red, white and yellow you can remove the scart adapter from the normal wii av cable and plug the separate jacks into that too.
Dec 31, 2009 | Video Game Consoles & Games
How to connect to an analog tv
Try to locate the composite video/audio in(1) and audio (2) out sockets of your tv.
(1): three small round sockets, one yellow, one white, one red (2): two small round sockets, red and white. (only if you want sound from your tv on your marantz receiver)
You will need a composite audio/video cable: 51433a4.jpg
and a composite audio cable: db5db51.jpg
Connect the composite video/audio cable (1):
the yellow lead to MULTI OUT (yellow) the white lead to MULTI OUT (white) the red lead to MULTI OUT (red)
on your tv: connect these cables to the respective yellow, red and white input. (there should be a text like: game in/dvd in/ext in/AV-1/VCR) If all you see at the back is a big socket like this one: 0f41fcb.jpg
you will need a SCART-to-composite adapter, like this:
(2) To get audio from your tv to your Marantz, locate an 'audio out' (red + white round connectors) on your tv, and connect these pins using cable (2) to TV (complete bottom left on your Marantz).
Dec 13, 2009 | Marantz SR7002 6.1 Channels Receiver
I cant plug my jvc to my tv .Each time i try,nothing shows up.
I am assuming that you have an AV cable which you need to have connected to your camcorder at the AV output socket, and the other end should have RCA phono plugs (one red, one white and one yellow) which usually connect to three corresponding sockets on the front or side of most modern TV sets, these may be inside a front panel which opens. Once connected, you need to select the appropriate AV input on your TV remote, very often this will be "Front AV" or AV3 or AV4, you need to check your TV instruction manual to be sure of which input is required for your specific model of TV...hope that helps!
Oct 13, 2009 | JVC GZ-MG130U Camcorder
How to connect (yellow, red & white) to component video
Connect either DVD player or DTH with the TV. There is only one input on your TV.
May 27, 2017 | Akai DVD-3850S DVD Player
g
OK,you need 3 leads,(A/V leads),normally red white and yellow.
So yellow is for Picture (video).go from video OUT (combo) to TV video IN.
Then red and white .... Audio OUT of combo into Audio IN on TV
TV must then be set to AV1 or AV2 depending on which AV inputs you used..
Rod
May 04, 2009 | Televison & Video
Footage transfer
here....http://cgi.ebay.co.uk/AV-USB-VHS-TV-to-DVD-Capture-Card-S-Video-Grabber-Y35_W0QQitemZ120367919357QQcmdZViewItemQQptZUK_Computing_Computer_Components_Graphics_Video_TV_Cards_TW?hash=item120367919357&_trksid=p3286.c0.m14&_trkparms=72%3A1300|66%3A2|65%3A12|39%3A2|240%3A1318
that one is in hong kong, but that is what I used time an time again. Just install the software, plug in the device, connect the red yellow an white leads to the red yellow an white leads that plug into the camcorder somewhere an off you go
Jan 18, 2009 | Sony Handycam CCD-TRV68 Camcorder
LG LM6700 47 in. Cinema 3D Smart TV Logo
67 people viewed this question
Computer Repairing
Computer Repairing
