Gh3 notes mixed up on my TAC flying v controller
  • 3,382 Answers
Before somebody can help you you need to give us the make and model number. You have the unit and know what it is, we don't.
Posted on Nov 27, 2014
Buick lucerne starting disable throttle causes car not to crank
Drive by wire , electronic throttle control . What is it you would like to know Mr. Woods ? Can throttle cause car not to crank ? What year Buick ?
STARTING DISABLED SERVICE THROTTLE
Throttle Actuator Control (TAC) System Description for the 4.6L engine or Throttle Actuator Control (TAC) System Description for the 3.8L engine.
Purpose
The throttle actuator control (TAC) system delivers improved throttle response and greater reliability and eliminates the need for mechanical cable. The TAC system performs the following functions:
• Accelerator pedal position (APP) sensing
• Throttle positioning to meet driver and engine demands
• Throttle position sensing
• Internal diagnostics
• Cruise control functions
• Manage TAC electrical power consumption
The TAC system includes the following components:
• The APP sensors
• The throttle body assembly
• The powertrain control module (PCM)
Drive by Wire training
Jan 01, 2017 | Buick Cars & Trucks
U0107 code 2004 avalanche
U0107 CHEVROLET - Lost Communication With Throttle Actuator Control Module.
Possible causes - Faulty Throttle Actuator Control (TAC) module
- Throttle Actuator Control (TAC) module harness is open or shorted
- Throttle Actuator Control (TAC) module circuit poor electrical connection (loose or broken wires)
Nov 20, 2016 | 2004 Chevrolet Avalanche
My H2 2006 jerks forward sometimes while I'm stopped at a light. My mechanic just had it there and no warning lights are on anywhere. Has anyone had that issue?
Have you had it to the dealer ? May have TSB - technical service bulletin. TSB'S are factory technical information publications on know problems with fixes for dealer technicians . May also have up dated soft ware for your vehicles PCM - powertrain control module that may fix this problem . Could have a problem in the
Throttle Actuator Control (TAC) System - Electronic throttle control .Not all problems set trouble codes . And all car manufacturers have some problems with these systems .
The TAC system components include the following:
The APP sensors
The TAC module
Jun 10, 2016 | Cars & Trucks
What does 2110 code on 2006 ford fusion mean
P2110 2006 FORD FUSION P2110 2006 FORD FUSION - Throttle Actuator Control System - Forced Limited RPM 0 Comments ' Add Yours Possible causes - Faulty Throttle Actuator Control (TAC)
- Throttle Actuator Control (TAC) harness is open or shorted
- Throttle Actuator Control (TAC) circuit poor electrical connection > Help with this Symptoms - Engine Light ON (or Service Engine Soon Warning Light P2110 2006 FORD FUSION Description The TAC system is in the failure mode effects management (FMEM) mode of forced limited RPM.
Read more: http://helpforcars.net/obd_codes/p2110_2006_ford_fusion.html#ixzz3mUz73ACP
Sep 22, 2015 | 2006 Ford Fusion
What is code 2119
Possible causes
- Throttle plate sticking due to carbon build-up
- Engine Control Module
Aug 19, 2014 | 2003 Cadillac CTS
Tac module
Did you clear the DTCs after the repair?, using a scantool (reset)
then drive and see if both codes return, are they the only codes
stored after 20miles driving? and fast 50mph and coasting to a stop fast and hot engine? (this act runs out most monitors)
what car,? not stated, just honda. there are lots of honda\'s.
what year,? must be 1996 or newer if USA my guess 2004+?
what engine I4 or V6? option?
is car a USA car?, USA cars are in fact quite different from all other cars , over the planet.
NO , my answer is no, do not GUESS!
why not read the FSM and do the tests there.?
buy a real FSM honda,. why own such a complex system with no books (bible)
or read it on line at alldata.com or mitchels.
the ECU/PCM does not know what is broken. NEVER
it only knows,what tests (monitors) failed, ONLY.
so it\'s the job of the technician (mech) to do other tests (simple)
to find the true cause. if you guess, it will be 10x more.$$
seems you are there already with a new TB. ouch.$$$
I4 answers. (4 banger?)
123 = bad TPS, or wires /conns to it.
223 = is vasty more complex
223 can be thrown for many reasons,
there are 5 major parts, to this system.
PCM. / TAC RELAY/ TAC MODULE, TB (with motor and TPS) and APP (leaving out, the whole engine, me bad....)
ok, there are always 2 causes of 223.
1: the 223 monitor was fooled.
2: or there really is a real TAC FAILURE. (PARTS)
This is the number one thing go learn about OBD2 systems
fooled or not fooled.
To diagnose this system and not take wild expensive guesses.
what do we do.?
we learn how it works,
it is just a closed loop servo system that is fly by wire.
or better, its Throttlebywire. it is a royal PITA, no lie....
in a nut shell, you create demand via the foot (TPS)
note first there really is 2 TPS, TWO !
the one a the foot is DEMAND, (you) honda calls the pedal APP sensor.
you step on the gas, err, app, the PCM sees this.
and then sends a command to the TAC, THE TAC RUNS THE TV (throttle valve) motor, and tries to match your demand.
see, that word match>?
if it can not match your demand for any (most) reasons.
then its a failure, but the ECU is bricks stupid, it DONT KNOW WHY , but just takes a wild guess, and pukes out 2 codes.
lets examine what can cause the ECU to give out TAC codes.
not a full list by ANY means.
1: bad engine?
2: air leaks, or MAP/FAF weak readings (causing lean conditions)
any air leaks to the induction plenum (aka vacuum leaks)
3: sticking TAC parts (gummy) the motor, the TV or idle controls parts that are malfing,
4:engine lean for any reason (bogging)
5: gross misfiring not detected by P300 monitor, (it happens)
I ask you, are you going to replace $2000 in parts, just for a vacuum leak? why let the ECU do that to you,
it is , brick stupid, do not let any ECU dictate the snap (shot gun) buying of parts.
and buy an FSM and read the pages, the book is way less than
any TAC.
or the $15 access fee to alldata.
see discount here.
http://www.scantool.net/software/alldata-diy-1-month-subscription.html
consider this simple thought.
the brain saw the drivers demand, but could not respond to the demand, ! that is it. (TBW, throttle by wire system)
The list of possibles are huge. i will not attempt to list them all
but will say this, we do all tests on the engine and EFI to see
if there are "other intanglements" ( lean, or other conditions)
or air leaks in the system .
and one more thing, all scan tools (real) have pending pages
got pendings ,while driving? y/n , yes, bingo. if not 123,223
and all scan tools have a freeze frame,
showing the last failure, and all PIDS, related to it
so looking at the freeze frame you can see when it happend
driving, how fast, and Baro readings, RPM, see list. examine all there. to get some idea of the conditions of failure, (it idle?)
This is my first big TAC post. i hope it helps others to understand
the reason the parts guy gets so rich, The ECU is stupid.
all this BS to replace a $5 throttle cable.... sigh. (i lied, its for traction controls,etc)
Oct 03, 2013 | Honda Cars & Trucks
Engine won't start and shows trouble code P1516 and reduced engine power light is on
Here is the definition of the code.
P1516 CHEVROLET Description The Throttle Actuator Control (TAC) module contains data which is essential for proper TAC operation. The TAC module continuously test the integrity of this data. When the TAC module is unable to write or read data to and from Random Access Memory (RAM), or the TAC module is unable to correctly read data from the flash memory or and internal TAC module processor fault is detected and the Detected Trouble Code (DTC) is set.
Read more: http://engine-codes.com/p1516_chevrolet.html#ixzz286Gl3cSo
Sep 28, 2012 | 2002 Chevrolet TrailBlazer
2009 Ford Fusion codes 2107,2110 car slows to 30mph and will no longer accelerate
Well, those codes definately are related to why your vehicle will no longer accelerate!
P2107 is "Throttle Actuator Control (TAC) Module Processor"
This code means that the TAC portion of the Powertrain Control Module (PCM) has failed the self-test.
Posiible causes:
> TAC motor circuit harness shorted to ground
> TAC motor circuit harness shorted to voltage
> Damage Electronic Throttle Body (ETB)
> Damaged PCM
P2110 is "Throttle Actuator Control (TAC) Forced Limited RPM"
This code is informational only. It sets in conjunction with other throttle actuator control codes (like P2107 above). It is just letting you know that the PCM is limiting RPM due to a TAC malfunction, (So it doesn't do a "TOYOTA" on you and run away!"
Jul 06, 2011 | Ford Fusion Cars & Trucks
My gh3 wireless guitar won't respond to the + and - button
You can use a standard controller to input anything you need, but it does sound like the d-pad is broken. Get it replaced.
Feb 14, 2009 | Nintendo Guitar Hero Wireless Guitar - Wii...
47 people viewed this question
 Grubhead
Grubhead
