Question about Prestige Remote Start
I have audiovox remote start security system model aps-998. my truck won't start. It's like the gas line has been disabled. How do I reset it so my truck will crank?
Ive tried to use the valet switch, but that has not worked. What else can I try to get my truck to crank?
4 Suggested Answers
jpk528
  • 95 Answers
SOURCE: prestige platinum by audiovox need to replace the remote for it
if you need a remote you can buy one from audiovox.com and also you can download the installation manual and user manual in which that will tell you how to program the new remote for the remote start.
Posted on Feb 16, 2009
  • 152 Answers
SOURCE: Reconnect remote starter
Those devices, when operating properly, are commonly not disconnected, but you could attempt to find the power lead and the in-line fuse to make those re-connections, also check the battery(s) in the remote. If the disconnection is more in-depth then you should acquire the installation and owners manual from Audiovox, so as to troubleshoot and maybe discover what else is disconnected.
Good luck...
Posted on Feb 23, 2009
logosc75
  • 625 Answers
SOURCE: I have a Prestige Model
The starter fails to disengage? Do you mean that the starter engages but the vehicle does not start? If so, there could be an issue with the immobilizer bypass. The vehicle is not seeing the transponder from the key/bypass, thereby not engaging the fuel pump. One way to confirm this is to put the key in the ignition and then remote start the car. If the vehicle starts, then you have successfully diagnosed the problem.
Or, do you mean that the vehicle starts and shuts down after 5 seconds. If so, the tachometer wire may have been disconnected during the repair service. The tach wire is green with an orange stripe and it may still be hanging (unattached) in the engine compartment. Try tracing any wiring harness coming through the firewall into the engine compartment on the driver's side that has an "aftermarket appearance", meaning that it may appear out of place in association with the factory wiring harnesses. Make sure that all the wiring is connected. The tach wire is black at the diagnostic connector on the drivers side of the motor or, you can use the uncommon wire at the coil.
Posted on Mar 12, 2011
2000 Tundra security system will not reset has shut down everything and will not crank. Tried the key in the door, key in ignition, searched for a valet button or toggle, nothing. No valet button
this year model did not come from the factory with a security system but many were installed at the dealer, is there a button under the steering column? if so i recommend you delete the alarm, if you ever have issues with the battery this will happen again. follow the wiring from the red light to the alarm control module and unplug the main clear connetor from the unit, also at the ignition switch you would have to unplug the ignition switch connector from the wire lead that goes to the alarm and reconnect the trucks factory connector to the igniton switch to take the ignition out of the alarm circuit
Feb 22, 2017 | Cars & Trucks
How can a security system be reprogramed in a 2004 Durango with a 5.7 hemi
Try this Instructions
    • 1Press the "Unlock" button on the remote keyless entry device.
    • 2 Insert the key into the ignition. Turn the ignition switch to "ON" without starting the engine.
    • Sponsored Links
    • 3 Press and hold the valet/override button below the steering column within five seconds of turning the ignition on.
    • 4 Release the valet/override button when the security light on the instrument panel stops blinking. The alarm is reset and disabled.
Read more
Jan 11, 2015 | 2004 Dodge Durango
Remote start wont start the car
try hitting function twice so its at level 2 code and hit the unlock button, that sends it into remote valet mode. if that isnt it make sure the valet toggle switch is on and connected
Dec 01, 2012 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Ive disconnected from battery to disable then reconnected for new start it dings but will not tirn over done all i can think but will not turn over starter wont engage
If this is a Prestige alarm with a starter disable, turn ignition on, press and release valet switch. This manually disarms the alarm.
If your vehicle does not have a starter disable, then your issue is mechanical with the vehicle itself.
If your battery is fully charged, then you may want to check the crank fuse for the vehicle. If the fuses are all good, try starting the vehicle in a different gear, (R,N,D).
Aug 18, 2012 | Basic Remote Vehicle Alarm System
Accidentally reversed the battery cables on my 98 honda accord 4cyl. 2.3l. I already replaced the main 100 amp fuse, replaced the main relay, replaced battery , and had alternator tested and its good. it...
If your car came with the Prestige Alarm unit, there is a possibility that the alarm box got deprogrammed or burned, and left the anti-theft activated. Use the Valet Switch to deactivate the alarm permanently, and see if the car starts. For some reason unknown to me, it takes a couple of cycles of crank/ take the ignition switch off, crank again for the Valet Switch to work. In my 98 Accord, this micro-switch is installed in the left front kicker panel, but there is no guarantee that it will be in the same place in you accord, since it is a dealer installed option
Jun 12, 2011 | 1998 Honda Accord
2005 lexus 330 inside trunk release switch does not work.The trunk will open if I use the remote button.
Check the valet trunk button in the glovebox. if thats not selected then its most likely the switch. however its unlikely, ive never seen one go bad before.
Feb 01, 2010 | 2003 Lexus ES 300
Car alarm activates when trying to jump start
look under the dash on the driver side look for button, (valet switch) press button and then crank.
Aug 24, 2009 | 1990 Toyota Cressida
How do i disable alarm for my 1996 thunderbird lx 4.6
Ok, try this.
Put the key in the ignition, and turn forward
all the way just before cranking. Then within
5 seconds, press and hold in the valet/overide
button, found under the dash area in most cases,
until the installed LED (the blinking light)
in your dash area comes on solid.
(Your valet switch might be the toggle (on/off) type.
in this case, key on, flip switch in oposite direction,
key off.)
This should be valet. This overides
the starter kill relay in the alarm harness,
and returns the car back to disarmed mode.
The only thing that will work now on your system,
is the keyless entry if installed.
Just Repeat these steps to rearm your system.
Feb 18, 2009 | 1996 Ford Thunderbird LX
Prestige Remote Start Logo
116 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
