Golf Logo
Brett Sackett Posted on Nov 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1990 easy go golf cart two-stroke will not crank over
David Payne
Level 3:
Top Expert:
  • Master 14,162 Answers
  • Posted on Nov 24, 2014
David Payne
Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2998366
Points
455836
Check the Lights
  • If your golf cart is equipped with lights, make sure that those lights were not inadvertently left on. Check the light switch to make sure the lights are off. If the lights were left on the battery has probably gone dead, and hooking up a battery charger to the golf cart should get it running again.
Check the Gear Selector
  • Some models of E-Z-Go golf carts are equipped with a safety mechanism that prevents starting if the gear shift is not fully in the "Park" position. Carefully check the gear selector to make sure it is in park. You may want to shift the gear selector from neutral to park to make sure the gear selector is truly in the "park" position. After moving the gear shift, try to start the golf cart again.
Check the Battery
  • If your E-Z-Go golf cart still will not start, there may be a problem with the battery connectors. Since all golf cart batteries contain corrosive acid, you will need to wear heavy work gloves before working with the battery. With your gloves on, carefully twist the battery connections back and forth, then attempt to start the golf cart. If the cart starts, or at least comes closer to starting, the problem is most likely corroded battery terminals. You will need to carefully remove the battery terminals and clean them. It is also a good idea to remove the battery from the battery compartment and wipe it down. If the battery cable connectors look damaged or worn they should be replaced as soon as possible.
Check the Ignition Wire
  • A bad ignition wire could also cause your E-Z-Go golf cart not to start. Begin with a visual inspection of the wire, looking for signs of corrosion or damage. If the wire appears to be loose, reseat it and try to start the golf cart again. The ignition wire should plug into the solenoid, but it is not unusual for these wires to become dislodged, especially if you have been driving over rough or uneven terrain. If you notice corrosion on the wire it can be wiped off, but be sure to wear your heavy work gloves to protect your hands.
Read more : http://www.ehow.com/way_5637586_e_z_go-golf-carts-starting-problems.html
IF YOU NEED ANYMORE HELP LET SOMEONE HERE KNOW.
I have a 1990 ez go golf cart won't fire replaced Battery solenoid and coil what else could it be?
Spark plug, fuel filter, fuel pump, plugged air filter, Is there battery power getting to the coil while it's cranking? The ignition switch could be acting up.
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 • Golf
2answers
Yamaha Golf Cart won't start
did you leave the key on and kill the battery or a light or something double ck that battery , they will still light up the ignition and lights and ll but does not have enough to crank the starter , that is what is sounds like to me be put a jump on it or charge it and try again , when you turn on the ignition does the lights light up on the dash panal if so the batter is low
Yamaha golf cart
Look under the seat for a pressure switch.
Oil and fuel blowing out through top of motor in yamaha golf cart 4 stroke engine
Engine got to much oil in it? Worn engine allowing fuel down into engine diluting the oil and raising the oil level? Blocked engine breather, pressurising the crankcase. Oil change and clean the breather. Worth a try
1helpful
Yamaha 4 stroke golf cart back fires all the time..Replaced coils and the carby but no change
Very important... valves get out of adjustment and are easy to set. This is where I would start FOR SURE. Check out www.buggiesgonewild.com and an example of how to do it on EZ GO 295 http://www.buggiesgonewild.com/ezgo-gas-tech/1196-ezgo-295-350-engine-valve-adjustment.html
Need electrical schematic for 1990 EZ Go gas cart-2 stroke
You might try the library. They have a reference section for automotive, and maybe golf carts. It has worked for me in the past
Top Golf Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
vince
Are you a Golf Expert? Answer questions, earn points and help others
