Question about Microwave Ovens
How do I repair the function control assembly of my
I need the function control assembly part; do you know where to buy it?
MY KEYBOADS DOEN'T FUNCTION,WHAT CANI DO?
Depending of course on your full model number, you may need to replace the membrane keypad or the control panel frame assembly, which comes with a new keypad.
There's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 26, 2012 | GE Profile : JVM3670BFBB 36" Over the...
Panel (time,date,Etc.) does not light
can you still microwave food?
If you cant the device has broken down and I would recommend takeing it to warranty repairs.
If its a cheap model, I supose you might be better off with buying a new one. Since if you dont have warranty repair it might cost more than a new model.
If you need more assistance let me know.
Thanks, remember to review and good luck to you
Mar 12, 2008 | Microwave Ovens
The bulb that is under the microwave that shines on the stove top is missing so I need to know what type of bulb to buy to replcae it.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven
here.
Cooktop light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
So be sure to unplug the oven before removing or installing bulbs.
We see (and repair) this a lot. If yours needs repair, at our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Wife tried to change cooktop light know microwave wont come on i still have clock display whirlpool mh1150xm
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too, as well as other functions.
Jan 30, 2010 | Microwave Ovens
Where can i buy a control panel for a ge profile microwave model hvm1540
If you have pads failing on the membrane keypad or an "F3" error, you can buy the control panel assembly with a new keypad already attached here.
(You will need to enter your full model number from the tag in or on the unit, such as HVM1540WW001, etc.)
If you have other trouble, and it is the control board ("smart board") that is at fault, you can buy a new one here or you can get it repaired here for only $39.95 in most cases.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jan 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Touch Control panel of my daewoo KOT-151S microwave needs to be replaced. I have to push control pad several times to get it to operate. Sometimes it will go on after just a few pushes, other times it...
We regularly replace these.
You can send your KOT-151S control panel assembly to us to install a new membrane keypad. The cost would be $64.95.
Or you can order an entire control panel assembly (plastic frame, stainless trim piece, keypad, and control circuit board) for $88.85, which includes return shipping.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
prototech@usa.net
Jul 31, 2009 | Daewoo Microwave Ovens
Hello. The touch panel does not work, only clock.
OK, you will need to replace the entire controller assembly(key pad). this assembly that is in your unit at this time is damaged and, replacing it with a new assembly, will restore normal key pad functions. You can order a new assembly by clicking the link below or, you can call for service if you are not interested in disassembling this unit. professional service techs are recommended.
CLICK TO ORDER YOUR NEEDED PART.
Jun 07, 2009 | LG LMV1630ST Microwave Oven
Microwave works fine, but the LED display is not working
Then chances are it can be repaired without having to buy a new board. I would suspect a connection or power component on the control board.
We regularly repair these for customers nationwide with our guaranteed $39.95 service.
For disassembly info, please see these links: http://www.microwavedisplay.com/safety.txt
and http://www.microwavedisplay.com/disassembly.txt
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Sep 12, 2008 | Hotpoint JE740WY/GY Microwave Oven
Repair help
Thefirst thing I would suggest is a hard reset. Unplug the unit for aminute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
Your control board may need to be repaired. While these run about $232, we can often repair them for only $39.95 nationwide.
William E. Miller
prototech@usa.net
Aug 29, 2008 | KitchenAid KHMS147 Microwave Oven
Microwave
I wiggled the ribbon cable between the control board and the intermediate circut board. The LCD came back for an instant. I am sure it is this ribbon cable. It looks like it is held on with adhesive. How can it be impossible to repair if people are offering to do it less than 40.00 dollars to fix it? Someone must be selling a replacement ribbon cable that will work.
Mar 20, 2006 | Sharp R-1501 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
