I have a model e1332o and I have a rectangular "initial setup menu" grid in the center of the screen The actions to move, select or exit are not buttons on the remote nsew to move only changes volume and chanel, no buttons Ok to select or exit to exit
    Top Expert:
  • Televison & ... Master
  • 35,762 Answers
If you have arrow markings on the remote, the associated buttons are used for the actions you describe.
Posted on Nov 23, 2014
4 Suggested Answers
  • 89 Answers
SOURCE: toshiba that uses CT-90040 remote
if this is a time warner cable remote. the toshiba code is 015. sometimes a tv has several codes but only one controls everything. dont understand tuning video into tv. sounds like u need to plug rca wire into input plugs on the front or rear and then move switch to video but dont know what wires u r using.
Posted on Dec 27, 2008
SOURCE: video input selection remains displayed - can't get rid of it
The solution to your remote problem is to go to wal-mart and when you go through the check out lane there is usually some last minute items. there is a silver remote that is usually hanging in those aisles and that has been the only one I have found that works.
Posted on Mar 07, 2009
  • 133 Answers
SOURCE: Front panel buttons and remote have stopped working.
Is the favorite channel menu a function that is normally accessed by a button on the remote?
If so, that button on the remote might be stuck.
If this is the case, the menu may at times pop up all by itself and other buttons on the remote and on the TV's front panel may not respond at all (it had happened on my remotes more than once).
Try to clean the remote control (the housing, rubber pad with knobs, circuit board) with ethyl alcohol, when you clean the housing, you should also clean the holes through which the buttons protrude, there might be some dirt that keeps the button stuck.
It may also be a stuck button on the TV front panel, so check these too.
Also, it could be something else, i just wrote the description of a problem and the solution which to me seemed most likely.
Hope you get it fixed.
regards
3rq8 (Triarcuate)
Posted on Jul 26, 2009
How to use a usb keyboard
as a P/S2 keyboard.plug it in the USB contact in the back.in any USB port.
Apr 08, 2013 | Dell Inspiron One 2305 Desktop Computer...
Keyboad failure on dell gx520 boot
Usb or Ps2 keyboard ?
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Enter bios restart your computer you will see a certain to press to enter set up usually the Delete or the F2 key this will vary depending on you computer and bios. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Enable PS2 & USB in BIOS You can enable PS2 and USB settings in BIOS by entering the BIOS setup screen when the computer boots. You will need to changes to the appropriate settings in this screen. The exact procedures vary by system, but there are a few common methods that may work if the motherboard manual is not available for guidance. The general procedure is the same for any modern computer system, but the menu arrangement and keystrokes to enter the setup program can vary greatly from one machine to the next. Power on or restart the computer and watch the initial boot screen to find the keystroke required to enter BIOS setup. This is often shown at the bottom of the screen. Typical keystrokes include pressing the "F1," "F2," "F9," "F10" or "Del" key. Press this key when the prompt appears on the screen. You can find the proper key in the computer's motherboard manual or on the website of the motherboard or computer manufacturer. Enter the BIOS setup screen and look for the "Advanced" or "Onboard Device Configuration" menu. Use the arrows to select your choice and press "Enter." Change the settings for the PS2 port by moving the menu choice to the "PS2" setting. Press "Enter" to bring up a smaller menu with the options to enable or disable the PS2 ports. Select "Enabled." You can also use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the PS2 port. Change the settings for the USB port by moving the menu choice to the "USB" setting. Press "Enter" to bring up a smaller menu with options to enable or disable the USB ports. Select "Enabled." Alternatively, use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the USB port. Save the settings and exit by pressing "F10" or using the "Esc" key to back out of the current menu. Choose to save and exit from the main menu if needed. Follow any additional instructions on the screen to save or navigate the menus. Hope this helps.
Dec 13, 2012 | Dell OptiPlex GX520 PC Desktop
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
Hello
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
How to master reset
Master Reset or Factory Reset
When Factory Reset is performed, the setup value will factory default setting
When initialization starts.
1.Select System Setup from Menu Screen.
2.From the System setup submenu, Set Factory Reset to ON
3.When you exit Menu, The phrase FACTORY RESET Appears on the monitor and
The Initialization starts.{ON/OFF} Use arrows UP-- DOWN & , kEY TO MAKE CHANGES
HOPE THIS HELPS
Oct 18, 2010 | Samsung SMT-190 19" Flat Panel TFT LCD...
My PC doesn't load
Restart computer. Watch closely at the bottom of the screen for an F command.
This F command will allow to enter setup.
When computer is loading, start pressing F12 repeatedly until setup is opened.
When setup opens, you'll see a file menu that runs across the top of the screen. It will start from the left and move to the right - press F9. When prompted, select "restore default settings". Move to each file menu and press F9 and set "default settings".
When you come to the Exit menu, do the same thing, then select the Exit Menu, and choose the "Exit Saving Settings" option.
Once it exits, it will automatically restart and begin the loading process into Windows (or your operating system).
If the OS does not load, you will need to re-enter setup: under the file menu, search for an option that will allow you to enable a second F command which should be F5 or F10. Once this is done, go to exit, and select "exit saving settins".
The computer will begin loading, but you will want to restart the computer - watch again at the bottom of the screen for the new F command - remember what it is when you are in setup, and begin pressing it as before with the F12 command - the F5 (F10) will bring you to an option menu for starting the computer - select the "start in safe mode" option.
If the computer does not load in safe mode, you will need to format the hard drive and re-install the Operating System.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jul 23, 2010 | Acer Aspire m5640 PC Desktop
I have a Philips 46PP9302 and can't find the Quick Setup guide. I'm wondering if it is located on-line. We moved our tv and want to recalibrate it.
http://www.retrevo.com/support/Philips-46PP9302H-TVs-manual/id/278ci462/t/2/
The above link should take you to the location where you can view all the parts of your models manual. Select the area of interest and rad onlinje
Please rate my help++++Thanks for using FIXYA
Nov 24, 2009 | Philips 46PP9302 46" Rear Projection...
My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
  1. Press action button to enter MENU.
  2. Navigate to SETUP.
  3. Scroll down to CONVERGE.
  4. Press VOL > to select.
  5. Press CH buttons to navigate up or down.
  6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
  7. Press VOL > to select.
  8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
  9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
    center of cabinet.
  10. Press ACTION button to display red center correction screen.
  11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
  12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION
Remote Control must be in TV mode.
  1. Press ACTION button to display red correction screen.
  2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
  3. Use the navigation buttons to align the RED cross with the white cross pattern.
  4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
  5. To exit press ACTION button repeatedly, then press CH up.
Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Region unlock
Quick 10 Steps:
- Power
- Setup
- Down 2x
- Play
- 253135
- Left
- Down
- 0
- Play
- Setup
Done
Detailed version:
1. turn Power 'On' - slider switch left side of unit
using the included credit card remote:
2. press 'Setup' button, bottom left (next to down arrow button) to display menus
3. 'Down' arrow 2x to Preferences menu
4. press 'Play' > button, center of arrow buttons, to select Preferences menu
5. press numbers: '2,5,3,1,3,5'
6. 'Left' arrow < button
7. 'Down' arrow button
8. you should now see REGION CODE 1 or similar
9. Press '10/0' button for all region, or whatever region you want
10. Press 'Play' > button again
11. Press 'Setup' button to exit menus.
Oct 17, 2008 | Initial IDM-1250 Portable DVD Player
Panasonic tv
- push menu
-setup
-ant cable
-sleep 30 min
-ch 124
-vol min with remote
-press vol - in front tv
- aparece chk you see
-with button poweer select
- push pwr & action to exit
jesustolu_9244@hotmail.com
Sep 12, 2008 | Panasonic CT-27SL15 27" TV
Fine tuning grid on my Samsung HDTV with remote.(BP59-00048)
To adjust manual convergence on your projection TV, follow theses steps:
  1. Turn your TV on.
  2. Let it warm up for 30 minutes.
  3. Press the Menu button on your remote. The Main menu appears.
  4. Use your remote to select Function, and then press the joystick.
  5. Select Convergence, and then press the joystick. The Manual Convergence screen appears.
  6. Select Red, and then press the joystick. A series of crosshairs appears on the screen.
  7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have. Note: You must do the outside crosshairs first.
  1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair. Note: Make the single horizontal line as white as possible.
  1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair. Note: Make the single vertical line as white as possible.
  1. Repeat for all outside crosshairs, and then for the inside crosshair.
  2. Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
  3. Repeat Steps 7 through 10 for Blue.
  4. Press the Menu button on your remote to exit.
Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
Jan 05, 2008 | Samsung BP59-00016A Remote Control
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
