Question about Technics Audio Players & Recorders
I have a Technics audio receiver, model SA-GX650. The front speakers work correctly, but the back and center speakers do not work correctly, i.e. no volume comes out of them. Would you please let me know if you have any suggestions?
    Top Expert:
  • Technics Master
  • 43,131 Answers
Some receivers have adjustments you can make during set up to direct sound in various ways. There also may be configuration selections you can make using the remote. For example, enabling surround sound or selecting simulated stereo. The instruction manual should explain the various options.
Posted on Nov 23, 2014
  • Audio Service Clinic Jan 03, 2015
    Just perform the factory reset, or return to defaults reset. Youi will find it in your owner's manual. That will get you in the "ballpark" as to your sound system as a whole.
Older technics SA-GX100 sometimes left or right speaker will not work until volumes is cranked up
buy some turner cleaner or electrical contact cleaner(radio shack) with the power off take the volume knob off spray into the area where the knob goes(the little metal post) turn the post back and forth with your fingers or needel nose plyers several times (over time dust and dirt build up makes a bad connection) you may have to do this a couple of times dont worry this stuff drys realy fast this should do the trick
Sep 06, 2014 | Panasonic Technics Sa Gx100 Amplifier...
My Technics SA-GX100 Reciever worked for a minute, but when i set it up with all the speakers and attachments, it says "muting". i dont have a remote, so how do i UNMUTE it?
According to my Technics SA-R210 manual to UNMUTE without the remote....do the following......PRESS BOTH THE VOL UP & DOWN CONTROLS & THE LOUDNESS SWITCH ON THE UNIT AT THE SAME TIME......Not sure it will work for your model but that is what it shows for The Technics SA-R210 model, so it should be pretty much the same
Sep 04, 2010 | Technics SA-AX720 Receiver
No tv sound through reciever's speakers. How do I hook up?
TV is not customarily a sound source. It is a video destination. Get your TV-related audio to the receiver from the same places the TV gets it - each source device's audio outputs.
Feb 06, 2010 | Technics SA-DX750 Receiver
No sound from front speakers
Check if a or b or what is reflected for speaker.
Oct 27, 2017 | Technics SA-DX950 Receiver
Balance Knob Technics SA-GX190
Sounds like a dirty pot. With the receiver off turn or slide it back from one side to the other. Test it, if its a little better you can clean it with a little (a drop or two) of wd40, You will probably need to remove the cover to get to it.
Nov 16, 2009 | Audio Players & Recorders
Technics sa 400 Receiver
check inside to see if you have a blown fuse on the left channel
May 27, 2009 | Technics Audio Players & Recorders
Technics SA-DX930 Sound cutting in and out
try rehooking up speaker wires. make sure no bare wire is showing and positive and negative are aligned correctly
May 19, 2009 | Technics SA-DX930 Receiver
Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Apr 06, 2009 | Technics SA-AX720 Receiver
Can't get Surround Sound with Movie
hiya
do you get full 5.1 when watching a movie from the dvd player...........??
as when u watch tv the reciever must be set to pro logic to enable 5.1 upmix as its only a stereo feed....
Dec 15, 2008 | Technics SA-DX1050 Receiver
Technics sa-g78 no sound from front speakers
This happens on mine also. My theory is a relay. If you turn the volume up (Waaay up) momentarily, you "burn through" the oxidation on the relay and the sound comes back - for awhile. Some day, I'll get in there and replace it with something more robust.
Aug 06, 2007 | Technics SA-AX540 Receiver
108 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
