Question about Singer CG-590 Commercial Grade Sewing Machine
How do I adjust needle depth on my Singer 590 c?
My daughter hit a pin with machine needle, and now I can not get my hook to pick up my bobbin thread as the needle is not going down far enough.
  • 25 Answers
There is an Allen screw on the shaft of the needle bar that you can loosen to be able to adjust the height of the needle. Some machines also have markings as to where the needle height needs to be. If you still have trouble talk to the people at the link below. They may be able to help. good luck Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Posted on Feb 04, 2015
How to adjust timing to pick up bobbin thread?
the eye of the needle has to be at or marginally below the hook of the bobbin case
on the up stroke of the needle so that the hook can pick up the needle thread and run it around the case
at the end of the machine there is a straight shaft that the needle arm is attached to and the clamp for the arm has a screw that can be loosen so that the position of the needle can be set in relation to the hook
singer have good pdf down load workshop manuals that explain it with diagrams
May 07, 2016 | Singer Sewing Machines
Adjust the timing on a singer confidence quilter 7469q
Hook/needle timing needs a hands on guidance to get it fix, 2 options either you can watch in utube 'singer sewing machine hook timing' or 'google' for singer 7469q service manual for your referral.
Nov 10, 2013 | Singer Confidence 7469 Mechanical Sewing...
Singer 7430, Needle hits the bottom of the bobbin case.
when the needle breaks on a pin that can cause a
problem with the timing, the machine needs to be serviced
Dec 11, 2012 | Singer 7430 Sewing Machine
I cannot get the top needle thread to pick up the bobbin thread on a Singer 404. I have the manual online and can see that I have loaded everything properly, but the bobbin thread just sits there when I...
Hi Jennifer:
Do you understand how a stitch is formed on a sewing machine? The needle goes down to its full down position. At that point the shuttle hook should be pointing right at the needle scarf, ready to go past it as the needle starts to go up.
When the needle starts its upward travel it forms a loop... the shuttle hook enters the loop and the bobbin thread is "captured" in that loop.
If your machine's timing is advanced, the needle will hit the hook and break or make nasty thumping noises. If your timing is ********.... the hook misses the loop entirely and does nothing.
So... open up the entire bobbin/throat plate area.... take the foot off so you can see. Clean if necessary. Then turn the hand wheel by hand until you see that the needle is at the lowest point of travel. Where is the shuttle hook?
From there you'll have to use your logic to find the right screws and adjust the hook.
Here' is a Parts Chart for your machine.
http://www.parts.singerco.com/IPpartCharts/404-1_4_5.pdf
Sep 14, 2012 | Singer Sewing Machines
How do I get Singer zigzag 457 to stop hitting the needle on the bobbin housing?
the sewing machine is out of time & needs to be retimed at a
sewing machine repair shop.
here's a link for a free manual
http://www.singerco.com/uploads/download/5d6ce627c00cb91c477d4703f1b704aab08a72c8.pdf
Sep 11, 2012 | Singer Sewing Machines
I have a Confidence 7470 purchased in May 2009. I was sewing tulle today and the thread kept snapping while sewing. I assumed it was catching in the tulle. The last time it snapped, the thread jammed in...
Sounds like your machine is off timing, When the machine is properly timed, you should see the hook passing behind the eye of the needle when the needle is on it's upward stroke. If this is not correct the machine will not pick up the bobbin thread. You may have to take it in for adjusting, unless your a bit machnical.
May 11, 2011 | SINGER 7470 Sewing Machine
Adjust timing on Singer Merritt 4530
what size replacement needles for a singer merritt 4530
Oct 21, 2008 | Singer 7462 Mechanical Sewing Machine
Picking up bobbin thread
First easy thing to check, are you using the correct length needle.
If this is not the problem then somehow the needle bar has moved and the the needle depth is to high or the timing is wrong..
Unless you really know what you are doing then I am afraid a sewing machine tech needs to reset the needle depth and subsequently the timing.
Mar 30, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer CG-590 Commercial Grade Sewing Machine Logo
124 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
