Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
If I do not have any suction, is it the motor . I changed the clutch. My brushes are rolling and checked for blocks . What is my next step?
Was working fine and went to use it again and it has no suction at all, checked for blockage , none found. The motor sound real whinny and not very loud. Changed the clutch but no help there. Are there a impellor in the motor and should I change that?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
On occassion a belt can slip off and/or break also, if this happens continually then try this simple solution. When starting your Dyson vacuum, start it in the upright position, do not put the head to the floor then start it, as this is like wheel spinning a car. Let it get up to speed in the upright position (which takes 2 seconds) then put the head to the floor. What happened Next?
Posted on Nov 24, 2014
    Problem Solver:
  • 18 Answers
Hi there are several reasons, motor failing could be one but if it is spinning it will be sucking, look in the short flexible hose for a block, pull out the inspection bend and the double clip unit at the side and check these. Are all you seals in place and not leaking? With the vacuum cleaner in the upright position turn it on is the air being sucked into the hand wand? if it sucks here then blockage is before the diverter which is in the lower part. If the suction is low in the upright positon, did you remove the bin and cyclone and seperate the two? there is likely a build up of dust etc. in the cyclone. There are also pleanty of Youtube video's. If it is all clean and clear borrow a similar unit and swap over the bin/cylone and the various interchangeable parts, finally have you replaced the filters?
Posted on Nov 23, 2014
chrispurs1
  • 372 Answers
SOURCE: Dyson DC07 Original won't pick up at base
Lie machine on its side pull back handle as if vacuuming & switch on (KEEP YOUR FINGERS & ANY LOOSE CLOTHING CLEAR OF BRUSH ROLLER)
Brush should spin if it doesnt ensure clutch control knob on side of machine is in drive position if it isnt rotate knob by hand to drive brush should now spin.
If it doesnt & your machine has A clutch either clutch will need replacing or belts will need replacing.
Manuals are available to replace belts & remove the clutch from this site http://dysonmanuals.llc.nu/index.htm
Posted on May 18, 2008
  • 97 Answers
SOURCE: Dyson DC07 works and cleans fine, but motor makes loud screaching sound.
If the screeching noise is happening at all times, it is most likely a motor failure; which unfortunately can only be resolved by complete replacement of the motor.
If it's a loud ratchety-screeching type sound, and is only occurring when the brush is set to carpet, it is most likely due to an obstruction of the brushroll or a problem with the clutch. Ensure that the brushroll can spin free, look for anything physically blocking it. Check the bearing ends on the brushroll, they can melt and cause the brushroll to not spin effectively. If neither of those two things resolves the problem, the clutch most likely needs replacement.
-R
Posted on Jul 31, 2008
SOURCE: Dyson 17 Brush Motor not working. I was an idiot
I am so sick and tird of this happening to me- it seems like the sammlest things cause my brusj motor to stop. It has happend 4 times, 3 of which were covered under warrenty and cost $80 in shipping to have fixed everytime!!! I am now out of warrenty and refuse to pay that kind of money for a machine that was alreaydy over priced. So I would love to know if you found an answer to your question...
Posted on Apr 02, 2010
Dysonteam
  • 167 Answers
SOURCE: No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Posted on Apr 22, 2010
VacuumRepair
  • 438 Answers
SOURCE: There is no suction from
Hi Doug,
There are several things that this could be. Probably the most common problem that we see when customers come in with this problem is actually a fairly simple problem to fix. Here are just a few things that this could be.
The fist possible problem is a VERY common problem actually.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
If you are getting suction power from the hose, but the vacuum still doesn't pick up on the floors, I think that these solutions should fix your problem. If you just replaced the clutch mechanism, the roller brush should be fine, but turn the vacuum over on it's side and make sure that the roller brush is actually spinning while it's on carpet mode. If none of these problems fixed your Dyson, please use the Clarification Request, or leave another comment here on the Fixya repair page, and I'll be happy to further diagnosis the vacuum cleaner with you.
I hope this was helpful to you. If so, please be sure to rate the repair as helpful by clicking the thumbs up icons in the top of the repair page. This is what keeps Fixya repair professionals like myself continue posting these detailed repair solutions for free, rather then just the premium ones that users pay to have answered. We really do appreciate when someone recognizes the work you've done. Thank you very much,
Chris J.
GoVacuum.com
Posted on Aug 09, 2010
Dyson model DC07 the belt controlling the beater bar is not turning but does have tension
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dc07
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dec 09, 2016 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Loss of suction from base but ok from hose. filter cleaned and dried
When the Cyclone Assembly on the Dyson is not spinning around, it usually means that you are loosing suction somewhere. This can either be caused by a clog, suction leak, or dirty filters. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Possible Problem # 1. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the vacuuming position with the handle down. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the handle was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
Possible Problem #3. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
hope this helps you .........
Mar 11, 2015 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do i fix dyson dc07 not picking up I've replaced obvious and made sure no blockage, but still not picking up please help
Remove the bottom brush plate to check the belt. If the belt is intact and spins the brush when operating the vacuum, and your sure there is no blockage (need to check several tubes), the clutch assembly may be worn. The motor drives the brush via the clutch assembly. The clutch assy. is connected to the brush by the belt.
Feb 25, 2015 | Dyson Vacuums
Problems with suction on floor of vac
Often times when people bring a vac in for repairs and say it has no suction at the floor it has good suction but not good agitation. Make sure the belts in the clutch are new (some people are selling used clutches with stretched out belts) and the brush roll is good. If the agitation from the brush roll is not good it will not pick up even light soils like hair and lint.
Oct 08, 2017 | Dyson DC14 Animal Bagless Upright Cyclonic...
8955 Upright Vacuum: How to change belt?...
Be sure to unplug your vacuum from the electrical outlet before proceeding!
-Turn your vacuum upside down so that the handle is resting on the floor and nozzle portion is resting on a work bench.
-Remove the 2 phillips screws from the metal bottom plate and set the bottom plate aside.
-Look at the right side of the brush roll. You will see a bent metal rod that attaches to the brush roll end cap. This is the clutch rod that allows your brush roll to spin or not depending on the position of the carpet/floor switch on the top of the nozzle. Pull this rod out of the brush roll clutch only. Leave the switch end of the rod where it is and just let the rod rest there.
-Pull the brush roll and old belt out and dispose of the old belt.
To install a new belt; put the new belt on the motor shaft first, next put the other end of the belt over the end of the brush roll and stretch belt and brush roll back in to place. Notice that on the brush roll end cap opposite of where the clutch rod goes, there is a metal piece with a slot cut into it. Be sure that this slot mates with the plastic stop in the nozzle so that the end cap cannot move.
Snap the clutch rod back in place and rotate the brush roll by hand to make sure the belt is not pinched.
Replace the bottom plate.
May 18, 2010 | Riccar 8955 Upright Vacuum
My sebo does not seem to be picking up stuff off carpet, what can i do. When I use the hose apart from the vacum it does having sucking power.
Unlike most vacuum cleaners, the Sebo Felix has two separate motors - one for the suction and one to drive the brush roll - so there are several things to check. You say the hose has suction, so the problem is in the lower part of the machine. First, check that there's no blockage in the base of the machine, then check that the brush roll is actually rotating when the machine's switched on. If there's no blockage and the brush roll is rotating, then the problem is simply that the brush bristles are worn and you need a new brush roll. If the brush roll is not rotating, listen to hear if the motor is running - if it is, then you need a new drive belt. If the motor is not running, there's an electrical problem and you may need professional help. If you need more advice, post a response here and I'll do what I can to help. Good luck!
Jan 31, 2010 | Sebo Felix Classic Bagged Upright Vacuum
I have a 4 year old pink dyson that I've loved until recently. It's always been easy to unclog when it wasen't picking up-now it seems maybe a seal problem has occured. The suction is making a funny noise...
Thanks for your response.First: (This is most likely as you say the suction is making a funny noise.) The DC07 has a short length of clear plastic hose on the underside of the machine. Check this very carefully for splits (pull it off from the motor end and then unscrew it from the brush-roll end). Even the smallest split can cause serious loss of suction. If you find a split it's best, and inexpensive, to replace the hose rather than try to repair it. Next: (Less likely.) Most, but not all, models of the DC07 have a "brush control system" operated by a knob on the right side of the base. This knob has two positions: "bare floors" (or "off") and "carpet" (or "auto"). The roller will turn only when the knob is on "carpet", and even then only when the handle is tilted back (with the base still flat on the floor). Dust pick-up will bee poor if the brush-roll has stopped working. The problem is that this system uses two belts, only one of which is easy to see. If you're sure that the control knob is in the correct position, but the roller doesn't turn when the machine is on and the handle is lowered, then most likely one of the belts is broken (one belt goes from the motor to the clutch mechanism behind the control knob, the other from the clutch to the brush-roll). It's also possible that the clutch itself has failed.
Belt/clutch replacement on this model is not for the faint-hearted! To see what's involved, you can go to www.dysonmedic.com then scroll to the bottom of the page and click on "DC07 clutch replacement". At least you will see how to remove the clutch cover so you can check on the other belt and confirm if this is the problem or not. Then you have to decide who is to do the job!
But, with any luck, you will find that it's that little plastic hose that's the problem anyway... and don't listen to the Oreck salesman!
I value your feedback, so please remember to rate this response. Good luck!
Jan 20, 2010 | Vacuums
Motor works, but no suction! what do you think?
No suction usually means a clog somewhere or bad filters. The hose and/or the dirt inlet by the brush roll may be coulded. The belt may have stretched enough to not turn the brush roll under load and that can seem like no suction. The worst is the motor is running at full speed, which would mean replacing the motor.
Apr 24, 2008 | Vacuums
Eureka 5197 self propelled bagless upright
Did you check the brush roll when you changed the belt? The smell of rubber would inducate a belt slipping. So if the brush roll (part #61308-2)isn't turning, the belt would get hot and would be slipping. If the motor sounds real loud, then you could have a bad motor(part #60775-4).
Feb 14, 2008 | Eureka 5197AT Upright Vacuum
Not enough suction for Panasonic MC-V5716 upright
Probably not the motor protector, its function is shut off the motor if it overheats. Most likely you have a clog or partial clog in the inlet down by the brush roll, or it is in the hose. But if the motor is running, and suction is low, with no clogs, then maybe the motor is running at a slower speed and will have to be replaced.
Nov 04, 2007 | Panasonic MC-V5716 Upright Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
62 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
