Question about Gateway M250A B E ES G GS Series, (846874000094)
How do I fix a ge side by side gss25jfmc that wont cool?
    Top Expert:
  • Gateway Master
  • 14,162 Answers
Ok, its likely you will need a new evaporator (freezer) fan motor and a new motherboard. GE had a issue with the motherboard causing the freezer fan motor to go out.
Here's the motherboard for your model you can order:
Manufacturer part number WR55X10942 is RepairClinic item number 1531075
[img src="http://www.repairclinic.com/dbimages/00001592/00479990.jpg" border="0" alt="">
Here's the evaporator fan motor for your model you can order:
Manufacturer part number WR60X10074 is RepairClinic item number 914169
[img src="http://www.rcappliancepartsimages.com/dbimages/00000763/00230839.jpg" border="0" alt="">
reference: http://www.applianceblog.com/mainforums/threads/17017-FIXED-GE-GSS25JFMC-Won-t-cool
Posted on Nov 24, 2014
  • 3,506 Answers
You will have to find out what it will not cool, most likely the compressor is defective or you have low refrigerasnt.
Frigadare refrigertor side by side its cooling fine but the freezer wont freeze
Check the heater coil in rear of freezer. Mine was burned out. Letting ice build up on the cooling fins. Replaced with new type double heater coil and fixed proble. You'll have to remove the cover off rear wall of freezer section to access it.
Jul 04, 2014 | GE GSS20IEP Side by Side Refrigerator
Top half of my refrigerator and freezer not as cold as it should be
Make sure there isn't anything blocking the cooling coils GE Side by Side Refrigerator GSS25JFMC Service Manual in PDF format... You can purchase a service manual from here.
Jun 26, 2017 | GE Refrigerators
Defrost heater mnot completely defrosting
unplug it and get your hair dryer remove the panel again and blow dry the entire thing untill all is melted be carefull not to over do ad not to put dryer in the freezer stand back where the water will not splash on the dryer after leave it off for 1 hour than turn back on and put setting on number 3 for 2 to 3 hours than adjust to your normal setting not higher than 5 or it will repeat problem.It is getting very well cool causing to over cool to fast.
also air spray out back side and bottom of refrigerator is always a big help
Good Luck
Apr 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
My ge side by side model gss25jfmc ww will start to freeze food in the cool side then it stops cooling in the freezer side. Ice will form on the back wall of the freezer. I haved thawed it out &...
I can tell you how to find the problem , but , it is a little work .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , and , when to cycle off due to temp satisfied .
Jan 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Model #: GSS25JFMC WW. during the pass two days my refrigerator has stopped cooling.
Your refrigerator has a control board on the back. This is likely the problem. Another possible problem is the start relay and capacitor on the compressor. To examine the board unplug refrigerator and remove cover over the board. Remove so you can examine both sides for burn marks or signs of heat on the black relays. Visit my site and enter the model or part number into the search feature You will also see a picture of this board on my web page.
SITE=> http://servicepartstec.blogspot.com/
Board part number WR55X10656 main control board. Thanks, Sea Breeze
Jun 30, 2009 | GE GSS25LGM Side by Side Refrigerator
Gss25jfmc side by side
Either the defrost heater (in the coil) dont work or the deefrost termostat(round thing with two wires atached to the coil) or the timer (black thing with a plug with 4 o 5 wires),it could be at the botoom front of the refrigerator,pulling the grill,or inside the fridge in thecold control box.
Mar 30, 2009 | GE GSS25JFM Side by Side Refrigerator
Refrigerator not cooling, frosting up
You might try GE customer service and ask where to locate the defrost timer,since that sounds like your problem.
Nov 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Aug 11, 2008 | GE GSS20IEM Side by Side Refrigerator
Gateway M250A B E ES G GS Series, (846874000094) Logo
63 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
