I have a top loading Samsung washing machine and after washing and water has drain and starts spinning I am hearing a strange whirring sound it is only happen while spin drying
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 60 Answers
Maybe there is trapped residue or something in the drum,,,,u need a technician to detach the drum ,,,clean nd replace it back...
Posted on Nov 23, 2014
5 Suggested Answers
SOURCE: Whirlpool washing machine, top load
hi without further investigation its a bit hit or miss , does the whole tub tilt or is it just the inner drum ?
if its just the inner drum then it sounds like the bearings are on there way out
if its the whole tub then it could be one of the springs that it hangs from or the shock absorber underneath that may have come adrift
hope this helps
paul
Posted on Jan 30, 2008
  • 7 Answers
SOURCE: top load does not spin dry the clothes
Transmission or solenoid that should pick and put transmission into spin. I bet it's a kenmore or similar.
Posted on Mar 08, 2008
SOURCE: GE TOP LOAD WASHER DOES NOT AGITATE OR SPIN
I have a GE MODEL WWSe5240G0WW top loader washer that has seen very little use. My problem is that the unit will not agitate or spin,every thing else seems to work ok. I did remove the top lid switch and jumped the to wires (Yellow/Red and Orange) still did not make any difference. Any in for would be great.
Posted on Feb 21, 2009
  • 4348 Answers
SOURCE: Hi, My top loading kitchen aid
Your machine may have a coupling that has failed, this is a rubber and plastic coupling, designed to reduce noise. They fail and the machine will barely work... This is not a hard replacement. Open the machine and look near the motor.
Posted on Feb 12, 2011
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
My Samsung WA75b9 toploader stops when the rinse cycle starts -makes noise but won't rinse or spin!
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 14, 2010 | Samsung SW62ASP Top Load Washer
Why no spin?
heatman101
May 21, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Front loading washing machine will not tumble or spin
This sounds like a drive belt porblem. The belt that connects the drum motor to the drum has slipped/broken/worn out. A new drive belt will most likey fix this one...
Alternately, a loose or broken pulley. I don't suspect a bad motor, since you say you can hear it clicking and whiring...
Jun 10, 2009 | Washing Machines
Not draining and spins a little but makes a whirring sound
you need to clean your pump something in your pump is causing your motor to work harder
Dec 26, 2008 | Kenmore 22422 Top Load Washer
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water does not drain, strange noise while in spin cycle
sounds like something is stuck in your drain system. Most likely just in front or even in the pump
Please check this
Apr 22, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Loud whirring sound
no problem withthe water they sometimes use a water ring for balance, or you may be hearing water reaming in the pump and hose areaa, its always there. as far as not spinning completly you may need to replace the belt or the idler(tension pulley), two 5/16 screw along the very bottom of unit will gai you access to see inside the machine
Apr 04, 2008 | Amana DLW330RA Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
