Question about Refrigerators
How do I get the icemaker to make ice
My freezer used to make ice on a regular basis but now won't make ice any more
    Top Expert:
  • Refrigerators Master
  • 14,161 Answers
TROUBLESHOOTING ICE MAKERS.
Posted on Nov 24, 2014
  • 3,506 Answers
Check that you are getting water to it, The most common problem is that the water valve goes bad
Icemaker not making ice
sometimes when the icemaker is not used,,water will thaw, drip/pool around the auger,,this will keep it from dispensing.
take the bin out, inspect all the parts for ice...ck that the on/off wire is in the correct position
Apr 15, 2014 | Kitchen Appliances - Others
Icemaker is slow in producing ice
If your icemaker is producing ice, but it is slow, there are 2 likely explanations.
1. Temperature. Water freezes at 32 deg, but the icemaker won't eject the ice until it gets below 10 degrees. If you always had good ice output and all of a sudden it has slowed down, you're temperature is a little higher than ideal. Check for a door seal not making good contact or try dropping the temp in the FREEZER side a couple degrees
2. New model. Most new refrigerators make ice much slower than older models to meet energy efficiency guidelines. This is not a repairable issue.
May 25, 2012 | GE Refrigerators
Amana ars2464 won't make ice
first check that the icemaker is getting water
second, check the temperature in the freezer. the freezer needs to be below 10 degrees to work.
if both check out, then you need a new icemaker
May 06, 2012 | Amana Refrigerators
Icemaker wont harvest
if you press the arm that slides out to feel the ice all the way in three times within a few seconds, this should start a harvest cycle. If it does, then you know it can cycle and you have a temperature issue.
your ice can freeze even at 25 degrees, but it won't harvest unless it is getting to about 8 degrees or colder, so check the temps in the freezer
Apr 17, 2012 | GE WR30X10093 Refrigerator Icemaker Kit
My icemaker won't deliver cubes despite switching from crushed to cubes on selector, what's a guy to do
you have to take apart the complete ice maker from inside the freezer as it has to be cleaned on a regular basis to operate properly. check with your owners manual, it tells you how to clean it.the ice cube shoot is the first to freeze up & block your flow of ice. it's not hard to do. all the best.
Dec 01, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag MBB1952HEW won´t make ice. Where is the fuse to icemaker located? It´s not in the bottom freezer coil area.
back wall of freezer has thick layer of ice frosting over, freezer not cold frig compartment seems to be ok.///????
Oct 14, 2009 | Maytag 22.1 cu. ft. Bottom Freezer...
Freezer drain line and upper drain pan freezes up regularly.
sounds like your fill tube is leaking
you should be able to pull it out from the back of the machine
to inspect it
if the fill tab on the tube is facing in any other direction than down it should be straight down
Oct 09, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Used to make several batches of ice a day, now 1-2 a week.
If your refrig has the icebucket on the door and the icemaker on the roof of the fridge then you have two eyes on each side of the freezer....they are bad. If not then the icemaker module is bad. If you have a regular icemaker that hangs from the left side of the freezer then the module is bad. Also......Is your freezer still working good? Icemakers will not work if the temp is not low enough. Are you sure the icemaker is cycling but not making the full number of cubes? Low water pressure will force the icemaker to make only a few cubes at a time
Sep 11, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Icemaker making too much ice & Freezer frosting up.
Hi gpss,
It sounds like you are getting large amounts of warm moist air into the freezer. This can be caused by the door being left cracked open or the door seal not sealing properly. Check your door gaskets on both sides of the refrigerator. One other possible is the ice chute. If it is not closing all the way it will cause the same problem. You will get alot of frost forming in the freezer then it will melt when the refrigerator defrosts. Let me know if this helps, and if you have anymore questions.
Mike
Sep 30, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
