Question about Ovens
My defy oven's bottom element heat up although the oven is turned off
Remove element but seems as if top element also heats up although oven is switched off
  • 3,368 Answers
Assuming you have not removed or reconnected any of the wires I would look at the thermostat.
Posted on Nov 26, 2014
Amigaman
  • 248 Answers
SOURCE: Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Posted on Nov 04, 2007
SOURCE: Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Posted on Jan 06, 2008
  • 1314 Answers
SOURCE: Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Posted on Jan 11, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 13 Answers
    SOURCE: Neff U1721 bottom oven not heating fan & light are ok
    Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
    Posted on Jul 29, 2009
    Does the top element turn on during pre-heat on an Kenmore 790.92 range
    No, the top element was designed to only work on the broiler setting.
    Sep 20, 2014 | Ovens
    Whirlpool akz161 top oven. The lower heat element is not working how do l access this as l need to fix it myself
    open door if you can see screws at element ends remove them and change or you will have to do it from the rear
    Nov 16, 2013 | Ovens
    My Defy 621 stove causes the earth leakage to trip after a few minutes when the oven is swithed on. The thermostat was resently replaced. Could it be one of the elements, although it seems they are...
    Most likely an element. When the heating wire expands inside the tube it contacts earth and kicks out the earth leakage. Select 'grill' and try the oven. If it does not trip out the lower element is the culprit. Replacement is easy for a reasonably adept handyman - just make sure that the mains are off!
    Jan 16, 2011 | Ovens
    Top oven does not heat-although bottom oven is ok.
    If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
    Check out this tip that I wrote about the Oven not heating problem..
    Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Jul 29, 2010 | Whirlpool GBD277PD Electric Double Oven
    Kenmore electrical oven
    Trying to better define the problem....
    Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
    To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
    Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Oven will not heat
    Although I am not familiar with this oven, living in the u/k, I would say that without any doubt the oven element(s) have failed, more so if the fan is working, so I would have hesitation that you replace the suspect element (s)..
    Plz let me know how you get on.Thanks.
    Jan 03, 2009 | GE JKP15 Electric Single Oven
    Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
    Ovens Logo
    105 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
