Question about Dishwashers
Hi. We have a baumatic bdw13 built in dishwasher, which is showing error code E6 (thermistor fault). Please could you tell me where the thermistor is located a whether it is easy to replace? Thanks
    Scholar:
    New Friend:
  • 80 Answers
Hello Kristy!
A thermistor is a temperature sensitive resistor that "opens" (opposite of short) when it reaches a certain temperature and is installed to protect electrical equipment down stream. Why not just a fuse?, you may ask. Good question. A thermistor can tolerate a brief current overload that would blow a fuse, allowing continued operation following transient high-current events like motor start up.
While thermistors sometimes simply decide it's time to join their relatives in thermistor heaven, or wherever dead thermistors go, it usually means there is a steady, excessive load (failing motor?) in the circuit requiring attention.
Where yours is located is a mystery but I would guess it's under the machine near the motor. While I have attacked these issues myself, this sounds like a job for the big kids, especially since thermistors seldom just die.
All the best.
Posted on Nov 26, 2014
4 Suggested Answers
  • 7 Answers
SOURCE: getting error code e3 on display- not reaching
the problem is the heat element, it is to replaes..dont now the prise..i am from denmark...
Posted on Oct 29, 2009
Testimonial: "thanks mate its good to know the problem"
SOURCE: error code E2
Error Code E2 means the pump is blocked. The remedy is to take the filter out which is underneath the bottom dish basket and ensure its is clean and free from debris. Then use a small container to empty the water sitting in the bottom of the machine/filter housing and ensure that no waste is stuck in the bottom. That should clear it
Posted on Nov 26, 2009
mc1bean
  • 3053 Answers
SOURCE: how do I get to
Hello, cuddy
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
My dishwasher will not start and the plates light keeps flashing, what does this mean and what can I do to fix this. Thanks
Here is a link to the error codes for your washer. http://www.manualslib.com/manual/213875/Baumatic-Bdw13.html?page=25
Also, another link to an incredible source of info on a whole host of manufacturers' diagnostic routines--your model is on page 19, includes how to enter diagnostic mode, etc. I hope this helps you!
Oct 04, 2015 | Baumatic 23 in. BDW13 Built-in Dishwasher
Hello I am getting error code E3 on my Baumatic dishwahser- how may I resolve this? Thank you
its "malfunction of temp sensor or heating element"so it is either the heating element or temp senser.is faulty test and replace the faulty part
Nov 09, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Error code E2
May 24, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Bumatic dishwasher bdw13 showing error code 1
Ok I think I can really help you here.
This is your error code, sounds like it has problems filling, might also be blocked.
‘E1’ LONGER FILL TIME. FAUCET IS NOT OPENED.
Ensure that inlet hose is not
kinked or crushed
Found the online manual for this model, it is a PDF file so you will need 'Adobe Reader' to read it. (click on link)
http://www.tlc-direct.co.uk/Technical/DataSheets/Baumatic_Manuals/BMBDW13.pdf
That should help you
Bri
Feb 07, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic BDW13
e4 code means the machine is showing a fault code for overfill,tip the machinee to a 45 degree angle and get excess water out should run ok after that
Aug 13, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic BDW13 14 dishwasher SHowing E3 Fault
word_answers.gif I had the same problem and changed the two thermostats on the base and got it working. You can get them from partmasters.co.uk (thermostat protector) cost 17.99. They just screw in and are dead easy to fit
Mar 08, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
I need to reset my dishwasher but don't know how!!
If it's any help then here is the link to the user manual (when you download it it applies to bdw13 as well even though it is labelled for the bdw14) http://www.baumatic.co.uk/products/discontinued-models/dishwashers/integrateddishwashers/BDW14 Best I could come up with is to try page 19 at the bottom of the "dishwasher doesn't run" section - there are two different types of reset which may do the job. Hope this helps :)
Mar 13, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Dishwashers Logo
96 people viewed this question
Top Dishwashers Experts
