The screen is beeping Dr. What does that mean?
  • 3 Answers
Not 100% positive but probably has to do with door switch(s). There should be a diagnostic sheet either under the top cover or behind the lower kick panel on the machine. This sheet will instruct you on how to put the machine into diagnostic test.
Posted on Nov 23, 2014
Oven Lock stuck open before start of self-cleaning cycle I get a code F9, a flashing lock light, a continous beep and a dr code on the panel when I try to set self-cleaning cycle again.
Thank you for your inquiry, Lucie!
From what you have described your Frigidaire oven lock is stuck open and you are receiving error codes "F9" and "DR". The "F9" error code stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Apr 30, 2015 | Frigidaire Stove/Oven/Range Black Glass...
I have a Frigidaire front loader washer model number LTF7000EGO and it was washing fine then started a beeping noise with dr flashing. What does that mean?
Hello friend, thank you for your post!
I understand that your Frigidaire washer, LTF7000EG0, is displaying a "DR" error code. "DR" stands for door which means a problem with your door it could be an issue with the door latch assembly or door strike. I would suggest resetting your washer and you can do that by unplugging the power cord or flipping the household circuit breaker for ten minutes.
If you continue to experience an issue with the error code "DR" I would recommend reaching out to a professional technician for proper diagnosis and repair. I hope this information has been helpful. -Matt
Oct 09, 2014 | Washing Machines
It says dr and beeps on my frigidaire front load washer
Hello shadow183 - Typically DR is a generic door error code. Possibly the door is not shutting properly, either it is sagging and not latching properly or the door sensor and the main control board are not communicating correctly. You would need this to be diagnosed by a professional technician in order to properly repair the machine.
Sep 27, 2012 | Frigidaire ATF6000ES Front Load Washer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
When i hit start it beeps repeatedly and says dr on the screen
in the service manual it says if you have a dr error code either the door is not closed or you need to replace the door lock assembly. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to help others in similar situations in the future. Thanks again for using fixya
Rick
Jun 04, 2011 | Frigidaire ATF6000ES Front Load Washer
I have an IBM T40 (2379). Sometimes it boots up, sometimes it doesn't and beeps 4 times at me, but the real problem is that the screen will come on for 3-4 seconds, and then shut off. What could be my...
Beeps usually mean there is a problem with your system hardware. 4 beeps usually mean a memory failure, but beep codes vary. Google "beep codes" to get a list of meanings. Lenovo Support has several pages for this. Try HERE
Sep 28, 2010 | IBM ThinkPad T40 2379 Notebook
I have Frigidaire Affinity washer that beeps and blinks "dr"
Hi. the "dr" represents a faulty door mechanism. you will need to replace this device asap.
Click here to purchase your new door mech.
May 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Code dr keeps popping up even if the door is shut and the dryer will not turn on
It means that the door switch is making a bad connection. You should look around near the door switch for loose parts or wires. If everything seems tight, perhaps replace the door switch
May 06, 2009 | Frigidaire FGQ1442ES Gas Dryer
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
