How to program flat pane tv - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,283 Answers
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Nov 24, 2014
Double image, how to solve this ?
It has T'Con board. But, it can't be replaced. It is an integral part of the LCD pane; and inside it.
Jul 22, 2015 | Samsung HG32NA470PF 32 LED-LCD TV - HDTV...
Tip
How to find out the product keys of the installed programs on your computer.
How to find out the product key/s of the installed program/son your computer.
Many computer users are having problem locating theirinstalled programs' product keys. Some pre-installed OEM programs like Microsoftofflice 2007, Microsoft operating system, etc... on some systems came with no written/labeledproduct keys. And there's situationwhen the software or the operating system asks for the key when some changes ismade with the system registries and the user can never access the programunless the product key is typed in. But in fact, the product key is alreadythere on the system and it's hard to find out with simple methods. The easiestway to find the product key of a particular program is through Magic Jelly Bean Keyfinder (clickhere to download). This is a small program which helps computer users tofind their installed programs' product keys. It detects almost all installed programs'product key. Simply download and install the program. Once it's installed, runthe program, it'll open up a window with two panes, you'll see the lists ofinstalled programs on the left pane and the respective product details on theright pane.
Click the name of a particular program on the left pane andyou'll see the information about the software with the product key. As we knowthat there're many more tools available, but with whatever I have tried, thisKeyfinder is the most effective program and most of all, it's FREE. So enjoy and get rid of thehassles.
Warning: Pleasedon't use the to steal the product key, but use this to get your own productkey.
Your comment and input is highly appreciated.
Thanks.
on Sep 25, 2010 | Computers & Internet
The volume button do not work
Check and replace all micro-switches at the pane buttons. You ahve to open the TV to replace it. Contact any service technician.
Gopakumar Gopalan Google
Feb 17, 2014 | Element Electronics FLX1911B 19 in. LCD TV
Faces have white spots on TV color distorted
If the LVDS cable [the flat data cable, that connects the T'Con baord to display panel] have any loose contact at any one end connectors, this kind of fault can occur. To most models of Sony LCD TVs, the T'Con board stated above, will be inside the display panes, and could not be accessible. Check your TV. If the T'Con board is not a built-in one type, just re-seat both ends of the LVDS cable. If it is built-in type, contact the authorized service center. You can't access it without disassembling the display pane, and it is a skilled work. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 17, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Picture flickers constantly
If there is any internal oscillation takes plece inside the TV pane, this fault can be occur. Contact the service center
May 30, 2013 | Televison & Video
Color green purple
Check the strip wire connection between LCD pane and T'Con board for any loose contact.
Dec 18, 2012 | Sony KLV-37S400A 37 inch Multi-System HDTV...
NEED TO PROGRAM MY RCA TV WITH A HUGHES HRMC-13 REMOTE
Hello
Codes for RCA tv with Hughes remote are:
160 161 156 165 065 070 004 023 024
056 074 081 152 167 145
Code Entry
Use the REMOTE pane under the System Setup menu tab to program your
HRMC-11, HRMC-12, or HRMC-13 remote control to operate your TV, VCR,
SAT, AUX device, or DVD (HRMC-11 and HRMC-12 only). The AUX menu
button can be used to control a CATV box or other type of device. Use the menu
buttons to choose the desired type of device and display a brand name menu list
from which you can select the manufacturer of your device.
Code scanning
To use the Code Scanning method:
1. Repeatedly tap the top part of the CHANNEL (CH) button.
2. Continue to step through the codes until the component turns off, indicating
you have found the correct component code. If you accidentally pass a code
that responds or realize you may not have been aiming the remote control at
the component, tap the lower part of the CHANNEL (CH) button to step
backward through the codes.
3. Press the remote control POWER button to verify the proper code by
turning the device on and off.
4. Press the device button (in this example, TV) again to lock in the code.
OK
Feb 20, 2011 | Televison & Video
The screen or lcd panel if thats what it is called got cracked and i need a new screen because it just shows wierd colors but i can still hear sound and everything .
LCD Panel (screen) would cost you approx new tv price. I would recommend to buy new tv instead of lcd pane (screen) replacement of this tv.
Thanks.
Feb 15, 2011 | Apex Digital LD4088 LCD TV
The screen on my plasma tv cracked. i looks very minor but when i turn on the tv the power light flashes a few times and then finally comes on but there is no picture. is there something i can do get get...
I am sorry to give you the bad news..... Your TV is finished.
Plasma sets operate by creating a plasma between two glass panes spaced very closely together. A vacuum is created between the two panes and is it backfilled with a very small amount of rare gases.
When one of the panes is cracked, air enters the space and the set is no longer capable of producing a plasma.
Feb 15, 2011 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
Delete from add delete at control panel
The only way to modify the add/remove programs list is to edit the registry. If you are uncomfortable doing this, get someone to help who is, or just leave the registry alone.
It's best to back up the registry in case you make a mistake.
To back up your registry, see this article.
On to the fun part. Follow these instructions exactly. Note: this applies to Windows XP only. If you have Windows Vista, please modify the question.
  1. Click Start, and then click Run.
  2. In the Open box, type regedt32, and then click OK.
  3. In Registry Editor, locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
  4. In the left pane, click the Uninstall registry key, and then click Export on the File menu.
  5. In the Export Registry File dialog box that appears, click Desktop in the Save in list, type uninstall in the File name box, and then click Save.
  6. Each key listed under Uninstall in the left pane of Registry Editor represents a program that is displayed in the Currently installed programs list of the Add or Remove Programs tool. To determine which program that each key represents, click the key, and then view the following values in the details pane on the right: DisplayName: The value data for the DisplayName key is the name that is listed in Add or Remove Programs.
    -and-
    UninstallString: The value data for the UninstallString key is the program that is used to uninstall the program.
  7. After you identify the registry key that represents the program that you removed but which is still displayed in the Currently installed programs list of Add or Remove Programs, right-click the key in the left pane of the Registry Editor window, and then click Delete.
    Click Yes in response to the "Are you sure you want to delete this key and all of its subkeys?" message.
  8. On the File menu, click Exit to quit Registry Editor.
  9. Click Start, click Control Panel, and then click Add or Remove Programs.
    In the Currently installed programs list, verify that the program whose registry key you deleted is no longer listed.
  10. Do one of the following:
    • If the program list is not correct in Add or Remove Programs, double-click the Uninstall.reg file that you saved to your desktop in step 5 to restore the original list of programs in the registry.
      -or-
    • If the program list is correct in Add or Remove Programs, right-click the Uninstall.reg file on your desktop, and then click Delete.
Mar 22, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
