Question about Staples Tools & Hardware - Others
How do I find replacement insulated staples #97-559 for a Powershot Holiday cable Tacker #5900?
Looked at Home Depot Store where the stapler was purchased. Tried GBCable Boss insulted powershot staples but they did not work. Trying to get question answered on line.
    Top Expert:
  • Staples Master
  • 51,186 Answers
BobbyR1234
  • 173 Answers
SOURCE: i need blueprints for my black and deaker staple gun
You can find and download the product manual here in pdf. If this is not what you are asking for please let me know in further detail what exactly you are looking for.
Posted on Jul 04, 2008
  • 23 Answers
SOURCE: Need staples for my Swingline Heavy Duty Tacker #800
If you can find Arrow brand staples - 60x30 series staples are interchangable with the old Swingline 8xx staples, sizes as follows:
Arrow 60430 = 1/4"
Arrow 60530 = 5/16"
Arrow 60630 = 3/8"
Arrow 60830 = 1/2"
Arrow 60930 = 9/16"
Posted on Mar 22, 2009
  • 384 Answers
SOURCE: what size staples do I need to use on the
The gun uses "T50" staples. Buy them at any hardware store.
Posted on Jun 17, 2009
SOURCE: powershot pro staple gun
just purchased a Powershot model 5700m. how do you load the staples?
Posted on Feb 23, 2011
SOURCE: I have recently been given a Powershot 8000
With the staple exit facing toward you (don't squeeze the handle), find the small black square at the bottom (opposite end) from staple exit. Grasp both sides. Pull away from gun (not down). Chamber will open.
Posted on May 21, 2011
Paper pro generation ii won't staple
you can open this one its ribbet.also not good idea to try it.
can be dangerous.its not worth to loose a pretty face then to by a new one.http://www.ebay.com/itm/Pro-Heavy-Duty-Tacker-Staple-Gun-Insulation-Screening-Upholstery-Stapler-/110746725341?pt=LH_DefaultDomain_0&hash=item19c904ebdd
Jul 26, 2012 | Black & Decker Tools & Hardware - Others
Bought a "mont marte" handstapler and cannot find staples! 11.3 mm wide - 8 mm long and 1.2 mm fat! The last measurment is important, slimmer staples eject in two or threes in a twist! Can you help me?...
This is a stapler primarily for upholstering applications. Try inquiring at your local fabrics store or upholstering supply dealer. They may carry the staples. Unlikely you would find these at a hardware store but you could still try Lowes or Home Depot.
Oct 01, 2010 | Staples Arrow T2025 Staple Gun For Flat &...
Is there a depth adjustment r tension adjustment
As far as I can tell this unit does not have an adjustment. Normally such an adjustment would only be included on much more expensive and specialised units generally listed for professional use.
If you need more pressure then hitting the tack with a hammer is the general answer.
If you need less pressure, i.e. the tack is cutting through the insulation/wire you are tacking then a cushion may help.
Suggestions for cushion material include one or more layers of paper or a thin (e.g. 3mm) piece of neoprene foam. After tacking the wire in place the foam/paper can be removed almost completely to produce the desired result - a tacked wire with no damage.
Hope this helps. For more power I favour the Stanley PowerShot series: they are absolute brutes and shoot most variations of staples, tacks and nails.
Jul 29, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Problem loading gun..Where do we put in the staples and change the dial to accomodate it? fred
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Jul 07, 2009 | Ace Hardware Ace Heavy Duty Staple Gun...
Can't load the stapler
check those staples or take to home store where you and i am sure they will help you figure it out
Nov 20, 2008 | Powershot Tool Company Cobra 8000 Forward...
Compare staple guns
A hammer tacker is a device somewhat similar to a staple gun, except that the mechanical energy from the user's muscles is stored — as in a hammer — as momentum of the gun itself, rather than as compression of an internal spring. This type of stapler is typically used for insulation, roofing and carpeting.
Aug 27, 2008 | Do it Best Imports/ Jaun Yei 326409 Cable...
Tools & Hardware - Others Logo
88 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
Van Allen II
Van Allen II
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
