Question about Hotpoint Dryers
Took my hotpoint condenser unit out to clean and know it will not go back Why ?
Clean out, and try to feel if there was any thing in the space
    Problem Solver:
  • 13 Answers
If it will not go back in it is normally the seal at the end of the unit pull it back out again and make sure the seal is lying in it groove fully.
Posted on Jan 20, 2015
kachbibi1
  • 979 Answers
SOURCE: hotpoint aquarius condenser dryer TDC30
I would dry it just to be on the safe side, even though it doesn't say so. It can't hurt. The front t'stat should be under the top at or near the drum.
Posted on Feb 03, 2009
barkencoa
  • 3463 Answers
SOURCE: How do i clean the condenser on my hotpoint tdc32?
Remove condenser, and flush it out under a running tap, or hose pipe with cold water, this will flush all the fluff out of the condenser
Please rate my solution.
Thanks.
Posted on Aug 07, 2009
SOURCE: hotpoint CTD00 Tumble Drier: No water in draw, 3x as long to dry
sounds like pump has gone
Posted on Aug 31, 2009
barkencoa
  • 3463 Answers
SOURCE: How do I remove/clean the filter on my Hotpoint
There are 2 filters to clean on this dryer.
1 is at the bottom front left, pull all the way out, and wash clean under running water, quite in order to do this.
The second one is at bottom front right, again pull out to clean, but do not use water on this one.
Some dryers also have one located inside the door opening, pull out to clean if yours has one.
Please leave feedback.
Thanks
Posted on Nov 13, 2009
My frigidaire air conditioner is making my apartment feel damp and when i took my filter out to clean it that part was damp too! What do I do to fix this?
You may have a clogged drain or the unit is installed without enough angle pitch for the water to drain to the back of the unit toward the outdoor section of the unit. I'm assuming it's a window air conditioner? The moisture condenses on the cooling coil near the filter and should drip down into a condensate drain pan, then the water should drain to the back of the unit into a pan at the condenser coil fan that is rejecting the heat outside. The fan blade usually has a ring on the outdoor fan that pick up the condensate moisture the fling accumulated water onto the hot condenser coil to evaporate it. Also the filter should not be touching the cooling coil. Make sure it in the correct slot. Some a/c cooling coil require a wetting agent that allow the water to slide down the coil and not pull off of the coil into the indoor circulating fan.
Sep 11, 2015 | Frigidaire Heating & Cooling
Safe switch shuts unit off at 425psi. what could be the problem?
Most 410-a Units will work at a vapor pressure of 125-140 suction, the normal head pressures range from 300-425, First thing i would do is get a water hose and make sure the condenser coils are clean, which affects your head pressure. Also make sure the condenser fan motor is spinning at a speed that seems normal and that your feeling good heat come out of it. And of course the normal clean filter check and make sure your evaporator coils are clean as well.
Hope this helps.
Michael
Oct 28, 2014 | Heating & Cooling
Hi my condenser hotpoint Aquarius dryer TCL770 keeps beeping when drying ?? All filters clean ?? Do I need to look at the back by pump maybe .? Thanks
I also have the same dryer with a constant beeping while trying! Did as suggestion 4 and then took the back off, cleaned the heater matrix and thermostats, checked the rear draining pipes...so far so good!
Sep 15, 2014 | Hotpoint Dryers
We have a flashing vacuum condenser message on our screen -- what does this mean?
It probably means that your condenser coils are dirty and need to be cleaned up. The condenser coils are the copper tubes in the back of the machine next to the condenser fan. If just vacuuming them up doesn't sufficiently clean them then you may want to get some coil cleaner from your local hardware store or whoever sold you the refrigerator.
If the condenser coils are already clean then you may not have enough airflow. Be sure you have 4 to 8 inches of free space behind the unit to provide adequate airflow.
Mar 13, 2010 | Sub-Zero 642
Outside walls of freezer feel hot to the touch
It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Also clean the condenser coils on the back.
Feb 10, 2010 | Hotpoint HSS25GFP Side by Side...
Dryer not heating up
I hate to tell you but get ready for more problems with this drier, it has a bad track record. In some cases cleaning the condensor out and drying the unit well will allow the unit to function again. Once a month you need to empty the condenser unit, this is under the bottom panel at the front of the tumble dryer, you simply pull the panel down, undo the condenser and pull it out (it is normal for there to be some water in the tubes when you do this), you then have to flush the condenser by pouring water through it in either your sink or tub. Make sure that there is plenty of room around the drier and empty the water container often. This curcuitry of this unit it sensitive to high humidity and can cause the unit to not function properly. So with condensing dryers you have to work on keeping them clean. Let me know how it goes. Later DRRXR
Feb 02, 2009 | Hotpoint Dryers
Dryer runs no water enters condenser draw, empty water light on.
Remove the filter draw on the bottom left, and wash out under running water to flush out all fluff.
Reach inside opening and clean as much fluff anf gunge as you can from the cavity.
Get a plastic bag tie, reach and feel for a small at the rear of the compartment, and poke hole clear..
If this does not solve the prob, then it is probably a sticking or faulty float valve., or switch.
This involves a complete strip down to access these components.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius CTD00 dryer won't heat
I have just had a similar problem and fixed it today.
The "Empty Water" light was staying on and no heat was given out to dry the load.
I found it to be the float switch in the condenser unit at the back left. It had stuck with fluff and debris. I cleaned out the condenser reservoir and the polystrene float and now all is well.
To get to this unit you must first,
Take of the top and the left hand side panel.
Locate the 2 locking tabs that hold the top half of the condenser onto the back panel and release this part.
Remove this by releasing 2 further tabs that hold it to it's bottom half,
and you will see the float switch assembly on the left hand side.
Clean out the condenser reservoir of any water and aslo clean the polystyrene float, it needs to be free to slide up and down between the plastic guides.
Hope this helps.
JohnM
Jun 28, 2008 | Hotpoint NWXR473EV Dryer
Hotpoint Ice diamond fridge freezer both green & red lights on.?
bulmer...it takes about two days to fully defrost these units unless you take the freezer section cover off and use a heat source. If you do...be sure to protect yourself against water and electricity mixing....not healthy. See below for another note.
clean the condenser coils below the unit.
check for the amount of gas in the unit. It must be off for half an hour. Remove the back fiber panel. The big thing is the compressor. Clean off the largest pipe coming out of it. Plug the unit in...watch out for the fan! The pipe should frost up and then clear off or stay wet after about 5 minutes. It should not be frosty. If it is, you need refrigerant.
Note: If you do remove the inside freezer panel and defrost, you can see how much refrigerant you have in your unit. Start the unit. Wait 5 minutes and observe the coils. They should be evenly frosted end to end. If approximately so, you're good. If not, you're low on gas.
Dec 17, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Dryers Logo
52 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
