Question about Exercise & Fitness
How do I disassemble norditrack act to move it?
Does this norditrack use wax or silicone lube
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
I am assuming you have never waxed your machine before. If this is the case, you should be safe using the liquid silicone lube. When this becomes an issue is if you were using the powder wax and tried to change to a silicone liquid. It would still work, but you would, more than likely, end up with some wax build up on your rollers.
How to Lubricate Treadmill Using Liquid Lube Video
Jan 05, 2016 | Exercise & Fitness
I have a Norditrack X5I NTL15909.0 and the incline stopped working so I did a calibration and it is stuck in calibrate mode.Every time you turn the power on it tries to calibrate up 2" and down 2"?
You need a new incline motor, The incline sensor is bad. One way to test is to pull the black and red off the MCB and applied 120 volts on the black (up) or Red (down) wire and see the incline motor move. If it does then the MCB is bad
Apr 05, 2015 | Exercise & Fitness
Ifit card reader on my norditrack C2255 dosn't work.
Sounds like card may have lost the data. This can happen if static discharge causes the card information to vanish.
Feb 26, 2014 | Exercise & Fitness
My norditrack track E3800 will not work
did you check and see if there are brushes on the motor? they may need changed
Feb 24, 2013 | NordicTrack E4000 Treadmill
I have a brand new Norditrack 1500 that makes a "knocking" noise when I start to run on it.
you can adjust the belt, see the video attached.
However try to LUBE see the video too.
Jan 08, 2013 | Nordic Track NordicTrack Treadmill, A2550
Replacing walking platform on norditrack c2200
see the next video, and proceed according.
God bless you
May 15, 2012 | Exercise & Fitness
How do I lubicate my Norditrack T9ci?
You get a tube of lubricant and instructions in the kit at treadmill accessory kit.
May 30, 2010 | Nordic Track NordicTrack T9 ci Treadmill
ETX 60 altitude doesn´t work, but motor works
You need to tighten the friction lock - it acts as a slip clutch.
Apr 08, 2010 | Meade ETX-60 AT Telescope
Hello. I have a nordic track c2420 and I was wondering if there was anyone who would know how to take it apart into two pieces so I can move it
i have a norditrack 2420 that has only about 20 miles on it i moved it to another place and it wont turn on any ideas i dont have a users manual and cant find one on the internet is there a fuse or breaker somewhere thanks
Aug 16, 2009 | Exercise & Fitness
Exercise & Fitness Logo
43 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
