Question about LG Televison & Video
Good evening, i have LG 50 inch digital plasma tv, i am running windows 7 in my desktop, i connected them using avg cable, it was working perfect, now the avg port on the input setting on my tv is not
That's all
    Top Expert:
  • LG Master
  • 74,251 Answers
Try a reset to this TV; and check it after. If it do not help you; contact any service technician.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Nov 24, 2014
SOURCE: HDMI input not working
I had the same problem with my 50 zenith when it was new. It needs a HDMI board replaced.
Posted on Jan 18, 2008
SOURCE: TV not finding Digital Channels from Cable Box
We have Comcast and we plugged the cable straight into our Bravia, searched for Digital Channels and it found 131. We actually get all the HD channels that we had using the box, plus a few more. It's worth a try.
Posted on Aug 24, 2008
  • 12 Answers
SOURCE: Connecting laptop to LG Plasma via vga cable
you should have a button that you have to press to get it to switch over, on mine i have to press and hold the Fn key then press the F4 key might not be the same on yours but you should have a f something key that has what looks like a little screen on it that is to switch the output if that does not work try hooking up your laptop just like before, and then restart it. good luck
Posted on Sep 30, 2008
  • 1623 Answers
SOURCE: Panasonic Plasma Monitor TH-42PWD7B - Convert to TV screen?
hi yvonne not sure if you sorted this but using this lead should get you sorted
http://www.maplin.co.uk/Module.aspx?moduleno=4702
the phono blugs ae used for audio and bnc plugs on the back of your panny are for the video
Posted on Oct 28, 2009
SOURCE: Panasonic plasma tv (47 inches), inputs not working
My 42 inch is powering on but is blank on the screen ..
Posted on Apr 01, 2011
How do I get sky from my set top box to work in a different room, I am trying to get my sky to work on a TV in a different room ? I have wired up TV coax cable from my sky box in sitting room and run
Hi Jim,
Here In my place in India, you can attach only one tv to the sky set top box.That too with AV cables. The program or channel changing is done by box only. The tv works as a monitor and has no role in program selection. You can attach a second tv to the box not through antenna cable but through AV cables only. That too if the box is having second set of output sockets. In that case both the TVs will receive the same programmes. To watch different programmes on the second tv you will have to go for an additional box.
Feb 09, 2015 | LG Televison & Video
TV link not working with my LG 50PH660V 50-inch Widescreen 1080p Full HD 3D Smart Plasma TV with Freeview HD/600Hz. I connected coax cable to my Sky Box, switching on the RF on, but I can not get it w
Hi Jim, your nearly there, all you need to do is go into the tv menu and move from DTV to the old type channel numbers and then find the bit where you can manually tune the tv to channel 68.
Have a sky menu picture running and you will see it come in.
Feb 03, 2015 | LG Televison & Video
Can I connect my teac AG 100 amp to my LG plasma tv?
yes.....connect to digital audio output.........optical fiber optic cable needed.....connect to digital audio input on hi-fi.......select pcm as format............good success, meder's tv service
Oct 14, 2012 | LG 50PK550 50 HDTV Plasma TV
Can't get sound to work with RBG cable from PC to TV
Sound will not work with mere RGB connection. The audio out of the PC should be conected to Audio in socket to TV.
May 02, 2012 | LG 50 50PZ950 50 3D Plasma TV
Trying to connect my 50 inch 50PC3D plasma tv, to my playstation 3 using HDMI cable. The tv is giving me an invalid format, is there an explanation/solution to this?
The PS3 video resolution setting is too high for the TV to work, please see your PS3 user manual on how to lower the resolution to the native resolution of this TV.
Jun 29, 2011 | LG 50PC3D 50 in. Plasma Television
We just bought a 60 inch plasma TV. We have a home theater which works fine when we run DVD's, but we would like to connect to the optical digital audio out port so we can hear the TV sound though our home...
If your surround system has either white/red phono connectors or scart marked as "aux in" or "tv in" or similar, and the TV has a headphone out socket, then you could use these. The cable required will be available on e-bay or a good electronic stockist.
Aug 19, 2010 | LG Televison & Video
Trying to connect to LG 60 inch plasma. no output
Hi.
You need to connect the Bose using the Optical Audio output from TV to Bose main unit (kind of square shaped connector), and not using the RCA inputs on TV.
The picture below is an LG back panel, the optical audio connector is at the lower side of I/O connections at the back of TV, on some model the location of connector may be different.
Dec 26, 2009 | Bose Cinemate Digital Home Theater System...
No picture have sound
Hi there, Im Kanth, i had the same problem, and i found a person in Mississauga, they fix all kind of problems in Plasma, they fixed my LG before a 7 months, its still running good, i came to know lots of ppls were having same problems, i sujest u to being the plasma to electronics @ Dixie and Britannia Mississauga, call them now 905 565 6595 or check there wesite for more info. http://dukeelectronic.com
Apr 02, 2008 | LG 50PX4DR 50 in. Plasma TV
Connections
conect ps3 audio throw optical
Dec 26, 2007 | LG MU-50PX10C 50 in. Plasma HDTV
Open Questions:
Televison & Video Logo
37 people viewed this question
Computer Repairing
Computer Repairing
