Question about John Deere Garden
I have a 3032e John Deere Tractor that will not hold throttle lever when it is moved
Nothing yet
  • John Deere Master
  • 2,478 Answers
Check your clamp near carb
Posted on Nov 24, 2014
Testimonial: "it turned out to be the friction washers at the bottom of the throttle lever. thanks for your help"
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
SOURCE: have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Posted on Jan 08, 2010
  • 52 Answers
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Posted on Apr 18, 2010
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
What is 0 divided by 0?
Its' (0). What else? Are you mad?
Jul 18, 2016 | Office Equipment & Supplies
I just received my Tomtom Go2535TM gps. There is no sound. What is wrong?
Take it back to the dealer for a replacement its faulty
Dec 24, 2014 | Tomtom GO GPS
What is better then God worse then the devil poor people have it rich people want it and if you eat it you'll die. What am I?
Nothing.
Nothing is better than God, nothing is worse than the devil.
Poor people have nothing, rich people want nothing.
If you eat nothing you'll die.
Sep 09, 2014 | Cars & Trucks
Sometimes when i get a text from someone it reads "Nothing to display"
hi....
Nothing to display is nothing but a blank message. they did not include any text while sending the text message.So the screen shows nothing to display.
thanx
Jul 15, 2010 | Nokia 2610 Cellular Phone
HYUNDAI WTP-20
Replace main power button or seek qualified repair man
Jun 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Garden Logo
133 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
