Question about Microwave Ovens
My microwave stops after 4 seconds. Why - Microwave Ovens
Is this an existing microwave that just started doing this? I installed a new microwave and it was doing the same thing, ended up being the breaker in my panel wasn't large enough. It didn't flip the breaker, just kept turning off at unit. Changed 10amp to 15amp, problem solved for me
Posted on Nov 23, 2014
I have a 18mth old Panasonic dimensions 4 invertor microwave oven that turns on for 3 or 4 seconds and stops altogether,any ideas?
What does the clock say after it stops? Is the time still correct, or is it wrong? Or maybe you mean only the turntable stops spinning, in which case the problem may just be that it needs a new belt! Try RepairClinic.com if that is the case!
May 16, 2017 | Panasonic Microwave Ovens
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
Goldstar microwave GMV 1540TW locked
From the handy owner's manual here:
To set child lock:
1. Press STOP/CLEAR.
2. Touch and hold START more than 4 seconds.
"LOCKED" will appear in the display window with two beeps.
To cancel child lock:
1. Touch and hold START more than 4 seconds.
"LOCKED" will disappear in the display window with two beeps.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Oct 06, 2011 | Goldstar MV-1526 Microwave Oven
NN-T774 INVERTER STOPPED WORKING AFTER 4 WEEKS
Check to make sure one of the plastic hooks on the door was not broken off. If both door hook latches are functional then the most likely cause of your problem is one of the latch switches located behind the control panel. These switches will fail if the oven user opens the door frequently BEFORE the cook cycle ends. Always push STOP/RESET before opening any microwave oven door.
Dec 30, 2009 | Panasonic Microwave Ovens
My microwave is locked and i dont know how to unlock it
"Locke" meaning the door? or locked meaning the buttons don't work? If it is the buttons then you have the child lock on. Push and hold the "Start" button for 4 to 5 seconds, and it will unlock.
Mar 12, 2009 | LG LMV2083SW Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Panasonic microwave shuts off
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Dec 25, 2008 | Microwave Ovens
Stops after 3 seconds - Panasonic NN-S252BF
may be magnetron spoiled or high voltage section problem,please check circuit andreplace damage parts...
Aug 14, 2008 | Panasonic NN-S254BF Microwave Oven
Stop after 5 seconds
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 24, 2008 | Panasonic NN-P294WF Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
