Question about Kitchen Ranges
Where do I find the red button to for the oven?
  • 637 Answers
Please share make and model.
A thumbs up would be greatly appreciated if this answer is helpful to you. H
Posted on Nov 23, 2014
How to reset thermal fuse on jkp56 double oven
If it has a red button in the middle, push it until it clicks. If no red button, you have to replace the thermal fuse.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Jun 03, 2014 | GE JTP45 Electric Double Oven
I have a gas garland convection oven 10-15 years old. I see the red button to relight the pilot light but I can't find the pilot light itself. Can you tell me where I should be looking?
On the main bake burner is going to be a small pilot burner,got to lift off the oven floor to get to it. It is going to look something like this picture and is attached usually to the side of the main burner.To light the pilot,push that red button light the small pilot burner..hold in the red button for about 20 seconds..release the red button..pilot should be on..if goes off the thermocoupler is going to be in need of replacement
Aug 26, 2011 | Ovens
GAS TO STOVE WAS TURNED OFF FOR COST SAVINGS BECAUSE NOT USED. OVEN PILOT LIGHTS WON'T LIGHT CAN'T SEE WHERE HOLE FOR LIGHT IS SO TO BE CLEANED??IT LOOKS LIKE A BLEEDER VALVE FOR BRAKS IS HOLE AT...
To light those pitots remove oven floor& access panel below the doors,for each oven will be a gas valve inside of the panel below the doors and has a red button. push that red button,light pilot inside of oven near the main burner,hold red button for 30 seconds and releas.Pilot should be on,repeat for other oven. If pilots go out after red button was held down for 30 seconds the part called the thermocoupler will need to be replaced
Aug 18, 2011 | Garland H283 Gas Kitchen Range
HOW DO YOU LIGHT THE PILOT FOR THE OVEN? OVEN I
Remove the oven floor & the access panel below the door,inside of lower access panel their will a gas valve with a red button on it, push red button,light pilot burner connected to main oven burner,hold red button for 15-20 seconds,release red button and pilot should be on.reinstall panels
If you release red button and pilot goes out the thermocoupler needs to be replaced
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Imperial IR-6-C Elite Gas Kitchen Range
Power outageoven says stop the little button seems jammed wont push in any way around this?
i have the same problem. the oven was installed in my new house before i moved in, the display just says stop an the button doesnt click or anything? did you manage to find out what was wrong?
thank you
Jul 01, 2010 | Whirlpool AKZ159IX Oven
How to light pilot for oven in 1950's roper delux
If it is an insta-light, I just rebuilt a Roper that age, the instructions are to turn off oven heat control, wait two minutes, locate red button which you have done, apply match to pilot, depress red button for 5 seconds and that should keep pilot light on, the instruction manual states to hold match for 60 seconds prior to pushing button, then hold for 5 seconds, either way, you don't want to flood the area with raw gas, and yet still apply enough heat long enough to lock in pilot, has the gas line been loose? Make sure it is purged of air, again, don't flood area with raw gas, it is pretty typical pilot procedure, the worst part is finding the red button, usually behind a burner cover. So try holding the button a bit longer with your match on it, some take a while, worst is the control has gone bad, but there are replacement valves for this vintage, I did check,
Sep 21, 2009 | Roper Kitchen Ranges
Display panel works, but oven will not come on
I take it the oven will not heat. there is a safety thermo inside the grilles. it can be reset.. turn the power off at the breaker... remove the grille..inside of the door. then look inside the thermo is has two wires going to it and a red button in the middle.. push the red button down it will reset the thermo with a click... replace grille and restore power... hope it helps.. replace grille
Sep 19, 2009 | Dacor Epicure 30" Double Wall Oven,...
Oven won't heat.
EUREKA! I found the reset button and my oven is heating as we speak. Ok, open the oven door. there is a thin panel with vents right at the door latch. Unscrew the (6) screws and pull off the panel. There is a red button on the left back behind the wiring. GOOD LUCK!
Dec 08, 2008 | Dacor ECS130 Epicure Electric Single Oven
Re: my whirlpool digital oven
The red key sign is a lock against children. To cancel it you have to hold the two buttons at the same time for 5 seconds (you activate it the same way).
The STOP sign appears after the cooker switches of after a power cut. You just have to press the left button, and, using the right knob, set the time.
Jun 24, 2008 | Ovens
Kitchen Ranges Logo
54 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
