Hitachi split air conditioner. I turn on the mains, the fan turna on for a second then the filter clean red light starts blibking and ac goes dead. Only the power light is on and red light is blinking. Help please.
  • karan arora
    karan arora Dec 12, 2014
    Update- Got it fixed, the ecu circuit board had shorted, I was told its quite a common problem with Hitachi Split ACs
  • Somnath Sanyal
    Somnath Sanyal Nov 02, 2016
    How much did you spend in getting it fixed..?
  • 637 Answers
Clean filters and reset.
Posted on Nov 23, 2014
  • karan arora
    karan arora Nov 23, 2014
    Done already. Still not working.
SOURCE: Air conditioner turns on then shuts itself off immediately
There's something wrong with your aircon. Usually the lights will start to blink. Depending on the brand and model, the number of times it blinks will give you an error code which tells you what's spoilt. You may like to check this out http://www.astiquer.com/blinking.html
Posted on Oct 07, 2008
SOURCE: samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Posted on Feb 13, 2009
  • 89 Answers
SOURCE: ELECTRA SPLIT UNIT AIR CONDITIONER - NOT WORKING
If the outdoor fan is the one you are talking about, it will not cool when it is not running. It sounds like the motor is over amping and going out on interan overload. You will have to change the motor for the fan outside on the condensing unit
Posted on Nov 17, 2009
Testimonial: "Hi - thanks for your comments. I am assuming the same and I am working on getting a replacement fan. Hopefully will be getting it by this weekend"
  • 1218 Answers
SOURCE: red blinking and ac not working
If the power "flickers" and unit fails but will restart once the breaker is reset, this sounds absolutley normal. It is a safety device that keeps the unit from burning up things due to improper power being supplied. As long as resetting puts it back into service with no issues, don't worry about it.
Posted on May 14, 2010
SOURCE: Samsung AS09XLN air conditioner lights blinking
Sounds like a common problem I have found with Samsung mini split unit. When powering on, does the internal blower attempt to start, then the unit stops and lights blink? If so, on the circuit card there is a 1.2uf or 1.5uf (CBB61) that probably has gone bad. I have replaced several of these. Good luck.
Posted on Jun 13, 2010
I have a Hitachi 1.5 ton Split AC and in that Red light always glows (the one indicating filter grid) How can I turn it off?
I've never owned one of those kind of air conditioners, but most air conditioners have a filter where air from the room enters the unit. They need cleaning or replacement and that sounds like what the indicator is suggesting. Might check manual or download one off internet.
Jun 09, 2016 | Hitachi Heating & Cooling
How to remove filter light in Hitachi split AC
Ensure you replace the filter on the AC or
How to clean filter of split AC
When its turn off,not unplugged, press at the same time ''Function Button" and the ''AUTO Swing" button on your Remote Controller.
Apr 10, 2016 | Hitachi Heating & Cooling
LED LIGHT BLINKING OF HITACHI SPLIT AIR CONDITIONER
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
Jun 18, 2012 | Hitachi Heating & Cooling
Hitachi split ac ace cutout how to go to standby mode
Its very simple to remove that red light glowing on the AC, just switch-off your AC with your remote, but don't turn off the switch that resides with in the plug, remove filters wash gently and dry under shade and place them again in the AC, now keep it without turning-off the switch for 30-60minutes this is called stand by mode. Now take the remote open the panel and press the button that is situated in 4th row and 3rd column. By doing this the red light will be turned off and enjoy your AC.
Apr 17, 2012 | Heating & Cooling
Hitachi ACE follow me red filter light is always on
the red light turns on automatically after 120 hrs of running to remind us for cleaning the filters. once you cleaned the filters and inserted back , then just keep ac in stand by mode, open the remote panel and press the button on extreme right bottom of the remote ( see carefully in the remote, there is very light image of the filter is made along with the button). red light will go off. no need to press the reset button.... enjoy
Apr 03, 2012 | Hitachi Heating & Cooling
I'm using whirlpool mastermind chrome split ac.. clean filter light started blinking so i cleaned and replaced the filters but still CLEAN FILTER light is blinking. please give a solution
If you didn't turn the Master ON/OFF Switch to OFF, before removing the filter. That is the problem. To clear the error message. Turn the Master ON/OFF Switch to OFF, unplug the unit, remove the filter and reinstall it. Wait 10 minutes, plug the unit back in, turn the Master ON/OFF Switch to ON. The controls should have reset themselves and the clean filter light should not appear.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 12, 2011 | Whirlpool ACC108PS Air Conditioner
Heating & Cooling Logo
521 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
