Question about Invacare Health & Beauty
I have an electric scooter Invacare Auriga 10 completely unused and with new batteries at once and not to move forward or back, the batteries are full and when I pull ahead in the engine can be heard
Not wont start forward
  • 4 more comments
  • Tomislav
    Tomislav Nov 24, 2014
    Yesterday I cleaned the carbon brushes because it seems to have been stopped and immediately started working and still drove fine and now suddenly again the same, sometimes they want to go and twitching, I'll try them again clean.
  • Tomislav
    today was drive perfect:-(
  • Tomislav
    Right now I again took out the carbon brush and again a little clean it with fine brush paper and when i was put it back it was working immediately, it is definitely something about the brush, the motor works great when have a contact.
  • Tomislav
    At the time when it starts driving like crazy, the problem occurs mostly after a couple of hours not driving
  • Tomislav
    Seeking the cause, this just happened a second time, the day before that I drove up the hill and I suppose it might then warmed up and that the brush stuck, but that day all drove without problems, I parked it in the morning did not want to go first time...
  • Tomislav
    Tomislav Jan 21, 2015
    I found that the problem in the carbon brushes, climb up my house is steep and that the engine overheated and the brush and rapidly spread and run aground, should drive carefully, press the turtle in first gear, will now have to order another pair of original Auriga brush does anyone know the address where I can order?
SOURCE: will not sometimes more often will not go than will
sounds like a loose terminali had a similar problem on my scooter and i fixed my problem by tightening those up
Posted on Jun 24, 2009
  • 175 Answers
SOURCE: I have a invacare The joystick mk5 will not lite up batt. are new
Some chairs, like the M91 are a real bear to replace the batteries and connectors can get knocked loose in the process. First, using a voltmeter you need to see if the controller is getting power. On the DC setting, use voltmeter at the three-pin female connection at the joystick that is the charging port. The two pins that are opposite each other are the "hot" pins, and your meter should read about 25 volts, +- 2 volts. If its 0, there is a connection that isn't made from the batteries through to the controller, or the controller or joystick is shot. If you do have power to the joystick, then it's probable that the joystick is shot. A new one from Invacare is pricey, around $1,000.00 I have found a new site that can repair most makes. I have not used them, so cannot vouch for their work, but give them a call and see what you think.
http://www.flightsystems.com/cart_controls/wheelchair_powered_scooter_market_cart_controls.htm
If you don't have power, start at the terminals from the battery, and follow each wire back to the power control box, unplug and replug firmly as you work your way back. Check all fuses on the way. Then check all of the other connectors inside the chair, unplug, and reconnect again. Unplug and reconnect the wires leading into the power control box, and then restart chair. If no lights still, then the power control module is probably the culprit, but the address above fixes those too. The joystick and the power control module work together to make the chair operate safely. Good luck
Posted on Jul 08, 2009
gewiz
  • 1263 Answers
SOURCE: Blinking charge light on Invacare Zoom 300 scooter
Can you try another charger ?
Is it a onboard charger ? if so they do go wrong, Are they supply MK batteries ?
Check the leads from the charger connection socket to the motor controller board.
Regards
GeWiz.
Posted on Oct 06, 2009
  • 23 Answers
SOURCE: Scooter motor clicks.
This sounds like you have tripped your circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead. Do you know where the circuit breaker is on your model?......
OK this one was hard:) I like a challenge. I have located the User manual for your chair, it does have a circuit breaker, the troubleshooting page even mentions it, but NOWHERE in the whole document does it give its location. Can you beleive that? I have tried other models in your brand, and similar products but none of them show where it is. The best I can find is this link to an online tech manual on maintaining your model. if you scroll down to page 66 it gives a rather indistinct photograph but I hope it helps.
http://www.scribd.com/doc/15487491/OnLine-Technical-Training-Course-Roadrunner-Mobility-Corporate-Office-717#fullscreen:on
If you need a copy of your User Manual Follow this link. Troubleshooting is on Page 27. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/invacare/Invacare%20Pronto%20M41%20Owner%27s%20Manual.pdf
Posted on May 06, 2010
  • 177 Answers
SOURCE: invacare auriga looses power
Hi. Most probably its the throttle pot ( Wig Wag ) thats causing the problem. I am an Invacare service agent and I have changed these many times for this very reason.Also check motor brushes are not worn down or jaming. Good luck. Neil.
Posted on May 30, 2010
Lx176 wont engage forward or reverse until unit warms up. rock it back and forth
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Sep 11, 2016 | John Deere Garden
My alero with a 2.4 cylinder wont go forward but go in reverse
You have a failed transmission, have it taken to a transmission shop for repair.
Jun 15, 2012 | Oldsmobile Alero Cars & Trucks
Have power wont start
try to start the car. When it doesn't start , leave the key forward the normal 2 clicks. Look for a light on the dash that says security or antitheft. If you see this light. Go to this link.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Also try starting in neutral.
Jan 17, 2012 | 2000 Chevrolet Malibu
When i open car door security lite flashes, car turns over but wont start
Your passkey security system is activated. The key has a transponder chip in it, if the ignition doesnt read that signal correctly, your anti theft will kick in to stop a potential car theif. Try turning the key forward like you are trying to start it. 2 clicks forward, for 10 minutes. Then turn it back and forward again and try to start. This may reset your system. If not, Its probably DEALERSHIP time.
Apr 12, 2011 | 1998 Cadillac Seville
Wont start unless i press the gear shift and start
There is a switch that senses when the shift is in park, you need to adjust it from your description
Sep 11, 2009 | 2001 Chrysler 300M
Health & Beauty Logo
70 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
