Hitachi split ac. I turn on the mains, the fan turna on for a second then the filter clean red light starts blibking and ac goes dead. Only the power light is on and red light is blinking. Help please.
    Scholar:
  • 195 Answers
Likely this means the filter is dirty--or the airflow around it--is blocked..and needs to be cleaned out to restore operation.,..
Posted on Nov 26, 2014
  • 18 Answers
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Posted on Jan 05, 2008
  • 4 Answers
SOURCE: TV shuts off
I would suggest that you guys turn the unit off when this happens, unplug the unit for 30 seconds, plug it back in, and see if this helps. If this does not solve your problem, you should call 1-800-448-2244, so a service center in your local area can be found for further assistance.
Posted on Jan 21, 2008
  • 59 Answers
SOURCE: PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Posted on Feb 05, 2008
SOURCE: my tv is blinking red in the power indicator 4 times on my KDS-50A2000
I had the same problem. Red LED blinking 4 times. This error means that one of the fans is NOT spinning! To check.... unplug the tv.... turn the TV around to a well lighted area so that you can see the fans in the back... plug the TV in and turn it on. Watch for the fans in the back... and see if they are spinning. If not... that is the reason why the TV will not turn on! In my case, the fan next to the lamp was stuck for some reason. I removed the the cover of the TV from the back... and cleaned the fan, made sure all connectors to it were properly connected... and viola! The TV is perfect again! Enjoy!
Posted on Jan 01, 2009
rulds2008
  • 3866 Answers
SOURCE: I have a JVC HD52z575 that when I turn it on the
Power supply would be the issue the fix would be my good friends @ www.teexp.com I hope this helps.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 13, 2009
How to remove filter light in Hitachi split AC
Ensure you replace the filter on the AC or
How to clean filter of split AC
When its turn off,not unplugged, press at the same time ''Function Button" and the ''AUTO Swing" button on your Remote Controller.
Apr 10, 2016 | Hitachi Heating & Cooling
AC power light blinks but not starts
The outside unit has a problem. Have it tested.
May 05, 2017 | Hitachi Heating & Cooling
LED LIGHT BLINKING OF HITACHI SPLIT AIR CONDITIONER
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
Jun 18, 2012 | Hitachi Heating & Cooling
RED LIGHT BLINKING IN HITACHI ICLEAN AC.. WHAT TO DO?
I was told the same thing that Dennis has posted by the guy who came to service the AC. So I think, it is ok as long as it blinks 9 times in a row and then repeats it after a brief pause.
Jun 08, 2012 | Heating & Cooling
Hitachi split ac ace cutout how to go to standby mode
Its very simple to remove that red light glowing on the AC, just switch-off your AC with your remote, but don't turn off the switch that resides with in the plug, remove filters wash gently and dry under shade and place them again in the AC, now keep it without turning-off the switch for 30-60minutes this is called stand by mode. Now take the remote open the panel and press the button that is situated in 4th row and 3rd column. By doing this the red light will be turned off and enjoy your AC.
Apr 17, 2012 | Heating & Cooling
Hitachi ACE follow me red filter light is always on
the red light turns on automatically after 120 hrs of running to remind us for cleaning the filters. once you cleaned the filters and inserted back , then just keep ac in stand by mode, open the remote panel and press the button on extreme right bottom of the remote ( see carefully in the remote, there is very light image of the filter is made along with the button). red light will go off. no need to press the reset button.... enjoy
Apr 03, 2012 | Hitachi Heating & Cooling
Hitachi ultravision projection that is turning off
Ur tv projection bulb,been a long time had not been replaced?If the the bulb been,replaced the ballast might be dead.
Apr 14, 2010 | Hitachi UltraVision 55HDS52 Television
Starts to power on,then shuts down
Have you checked the filters? I have a Sanyo PLV-75 and had a similar problem.  The normal fan would come on when the unit was first started, then after a few seconds the secondary fan came on and then the unit would shut down.  Called tech support and they asked if I had cleaned the filters. I did it, and it worked great.  Check the manual for where the filters are and hit them first before getting a new bulb.  Hope it helps!
May 24, 2009 | Sanyo PLC XF10NZ Multimedia Projector
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
