Question about OEM 1999 Chevy C1500 Suburban Radio / CD Player 3tc36306r CD player remote, single disc El Paso, Texas
My starter won't shut off and the car keeps running. What could this be?
  • 637 Answers
Your solenoid is sticking causing the starting to continue to turn.
Posted on Nov 23, 2014
Testimonial: "What can I do to fix this problem?"
  • FastHarley
    FastHarley Nov 23, 2014
    SorryI didn't not realize that the rest. Do is turn your vehicle on as the starter hangs up get somebody to tap underneath tap on the starter and it will shut off. And maybe you can remove the starter and take it to an autoparts store they should check it for you free of charge.
2011 keep compass new fuel pump, new starter, engine shut off when driving
Your best bet ,take your vehicle to a qualified repair shop.
Nov 29, 2017 | Cars & Trucks
Hooked battery up wrong on 1992 explorer, stereo smoked and now the windshield wipers won't shut off. No blown fuses just popped the line circuit from starter relay to alternator. Replaced battery...
you must RUN the scanner/computer for easy diagnostic, and fix it.
Remember the electronic vehicle is very complicated, You can have some faulty: PCM+ignition coil+BCM+sensor+etc.
see the diagram attached.
Jul 23, 2013 | Cars & Trucks
Intermittent starter won't engage on mercrusier7.4 1988 boat engine
might be a burned spot on the starter contacts where the brushes power the motor.
tap the starter to see if problem goes away.
sometimes you can clean the contacts but that is a temporary fix.
Mar 11, 2013 | Cars & Trucks
Starter won't stop 1999 buick lesabre
could be a problem starter relay or starter solenoid
if the battery lead goes straight to the starter , pull the starter and have it bench tested
Sep 06, 2017 | 1999 Buick LeSabre
Starter keeps freezing and won't start but as soon as it is warmed up it starts and runs fine.
Put another starter on but not the same brand,Autozone has them with life time warranty.
Nov 16, 2012 | 2000 Ford Taurus
1994 evinrude boat motor keeps blowing fuse. motor keeps running but once shut off won't restart. also while motor is running the tilt won't work work
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jun 27, 2012 | Cars & Trucks
Starter is running but wont engage flywheel
check the starter gear, maybe it didnt actuate.
May 10, 2012 | 2001 Buick LeSabre
1998 sunfire ran for while after changing starter shut it off now it won't start
Check THEFT light on in dashboard, if YES, check disarm procedure in the Owners MAnual.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 16, 2012 | 1998 Pontiac Sunfire
Trouble starting my 1992 cav. 2.2. New battery, starter ok, new plugs, can start with ether and then idles and runs fine. Seems like I do not have that initial fuel??
well there is a fuel pressure regulator which keeps pressure on, even while engine is off. i would suspect it is bad, or you have something else leaking pressure off while the engine is not running.
Jan 20, 2011 | 1992 Chevrolet Cavalier
OEM 1999 Chevy C1500 Suburban Radio / CD Player 3tc36306r CD player remote, single disc El Paso, Texas Logo
61 people viewed this question
Top OEM GPS Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
RobDiesel
Are you an OEM GPS Expert? Answer questions, earn points and help others
