55 toshiba no picture no sound. Other tvs ok.
    Scholar:
  • 195 Answers
Is this a DLP set? if so--possibly you have a lamp bad--or maybe a color wheel not starting...
Posted on Nov 26, 2014
55 inch rca picture problems
Newer LED type TVs have the LED drivers integrated at the edges of the screen. Sounds like you have some going bad and getting overheated. That will cause the picture problem and the melting. Time for a new set.
Jan 31, 2016 | RCA Televison & Video
I have a 2011 Toshiba 55 55SL417Uand the picture wont come on the green flashes 3 times pauses 3 flashes pause over and over
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jun 21, 2015 | Toshiba 55 55SL417U LCD TV
Disassembling 518h3
I have the same set. I have not found any videos online as of yet, but hopefully this link will help.
http://www.doityourself.com/forum/entertainment-center-tvs-stereos-vcrs-dvds-8-track-tape-players/296524-broke-toshiba-55h70.html#b
Feb 13, 2013 | Toshiba 55H70 55" Rear Projection...
Panasonic tcl55e50 has sound but no picture and power light is blinking what do i do?
Blinking of power light to Pansonic TVs are fault indications. Count the number of blinks occurs one time switch ON. Check this site to get more details to blinking codes to Panasonic TVs
Jan 23, 2013 | Panasonic TCL55E50 55 1080p 120Hz Apps LED...
Toshiba tv just click
Hello
If there is sound output from its speakers, when turn ON, and catches a transmission, the fault must be to its Timing Contrrol board. This board also known as T'Con board. This is a common fault to all LCD tvs, irrespective of their brand.
If sound output also absent, the motherbaord [Main board] has the fault. Whicheaver it may, this is a skilled work, and can only be done by an experienced service techinician. If you know anyone such, just contact him/her.
Otherwise contact the nearest Authorised Service Center for Toshiba at your town. OK.
Feb 08, 2012 | Toshiba REGZA 52XV648U LCD TV
Sanyo 24 in flat screen model DS24425 Screen slowly goes fussy and slowly goes black , a slight tap on the rear left side brings the picture back to good screen,for a few minutes or a couple of hours no...
Hello
Your flat panel TVs picture tube base board has soldering loose contact with it. Just unplug your TV from AC mains socket, and open it. Pull out the picture tube base card from the picture tube neck. Pull it out straight, no shake must be there, as it will damage its connecting pins.
Normally, loose sodering are very difficult to loacate, as they will be quite micrscopic in size. Just resolder all the suspected loose sodering point on that board, by applying a little more solder. This will solve your TVs problem. OK.
May 26, 2011 | Toshiba 55ZV650U 55 in. LCD HDTV
Re:toshiba 55h70 tv i unplugged the tv to paint. when i plugged back in a wk later i have no picture or sound. nothing. can't access the menu - completely dark screen. the red lite "on" button...
I would check the fuse on the main board. Check the Capacitors on the Power Supply board. Seeing that you unplugged it and replugged it in you might have bad caps that were weak to begin with. Please learn how to safely work on a TV before attempting . Even when a tv is unplugged it has enough power to kill you. Discharge all Capacitors first. make sure its unplugged of course.
Jan 06, 2011 | Toshiba 55H70 55" Rear Projection...
No display or audio
I had the same problem after replacing several things and still having same problem, it ended up being a capacitor.
Jul 03, 2010 | Toshiba TP55H60 55" Rear Projection...
65" toshiba projection tv no picture but has sound..
if you could hear only sound in tv and not picture means it might be the picture tube problem just check it.
Sep 17, 2009 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
