Question about Meiko Dishwashers
Can somebody help me please,meiko k200 continous refilling of water.The PCB and magnetic float sensor already but unsolve problem.
  • 67 Answers
Try cleaning the intake valve as it sounds like it is stuck in the open postion despite the float sensor
Posted on Nov 24, 2014
Where is the water level sensor located
Brand and model required. Often the sensor is activated by a floating magnet in the water tank. Most problems occur when the magnet stops floating. Normal solution is replace the tank, cheap solution is jam something plastic under the magnet.
Jun 03, 2015 | Coffee Makers & Espresso Machines
Low water warning light flashing when water level is not low
The water level sensor is based on a floating magnet. The magnet breaks out of it's holder in the water tank. Remove the water tank via the door on the back of the machine, tip the water out (and the magnet will probably come out too). Put the magnet back in the housing down near the water valve, and wedge the black lid on with a bit of plastic. Refill and enjoy coffee.
... or put some black tape over the red light.
Feb 13, 2014 | Sunbeam Coffee Makers & Espresso Machines
Error 201 on the Meiko 40.2 undercounter. I am thinking that it is the float switch somewhere, the sump basin is filling up just fine. anybody have this problem?
Check that the water hose is correctly attached and is free of "kinks" or pinching. Also check that the water supply is turned on all of the way.
May 26, 2011 | Meiko FV 40.2 Dishwasher
All the lights on my machine are flashing. What
I had flashing lights in my braun tassimo and tried all previous solutions
Cleaned the barcode reader
Seated the water container properly
The problem was down to the flosting magnet in the water container (which was floating when filled)
The magnet had lost its strength somehow, so i held a strong magnet from from a fish tank cleaner at the back whilst the water container was in and it worked perfect
Inside the machine is a sensor which detects the magnet that floats in the water container
I am looking for a new magnet and will keep you informed if it worked when i get one
Good luck from Ash
Feb 05, 2010 | Braun Tassimo Coffee Maker
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
The Sensor Magnet for water tank does not float to the top
OK, first of all, I do not recommend my solution if you are forgetful or do not check your water level manually daily.
However, I found a super easy solution.
The way the unit works is to use a float in the water chamber with a magnet on the bottom. When their is enough water in the tank, the float rises and the magnet on the bottom floats to the top of the magnet chamber. When it floats up, it aligns with a sensor in the machine that allows the machine to operate. When the the water level lowers, so does the magnet and drops below the internal sensor disabling the machine with a "Fill Water Tank" error message.
To eliminate this error and allow the machine to operate, I simply popped off the lid to the magnet chamber with a butter knife and turned the water chamber up side down to let the magnet float fall out. Remember to empty the water first.
Here comes the highly technical part. Turn the magnet float upside down and slide it back into the float chamber. Since the actual magnet is on the bottom of the float it now is at the top allowing the internal sensor to turn off. No more error message!
The reason I do recommend this is because this completely defeats the purpose of the sensor and will most likely damage your machine if you run it without water. Keep you tank filled however and you will eliminate the frustration of a "float gone bad" keeping you from your morning caffeine.
Apr 08, 2009 | Saeco Incanto Classic Espresso Machine
Add water
There is a floating magnet in the side of the water fill container. Make sure the magnet is floating. That is how the Keurig determines whether there is water in the container or not. If it isn't floating, the machine thinks the water container is empty. If it is not working properly your only option is replacing the water container (or rigging the magnet and being very careful to make sure the reservoir never runs dry).
Mar 28, 2009 | Keurig Special Edition B60 Coffee Maker
Add Water
Turns out I finally called Keurig and explained the problem (says to add water when water container is already full...) and they told me that it was most likely an issue with the water container. They sent me a new water container about a month ago and it looks as though the problem has been solved!! Solution: Call Keurig and get a new water container!!!!
Dec 26, 2007 | Keurig B60 Coffee Maker
Fill Watertank Message
The black thing floating in the water tank is a plastic shell with a magnet inside. If you clean it...make sure you reinstall it with the tapered (smaller) side down. There is a slight size difference BUT it will make ALL the difference in the world.
I had no idea there was a magnet in that black/greyish case. The direction of the casing is important.
I had the same problem and that solved it!
Jul 29, 2007 | Miele CVA615 Espresso Machine
Dishwashers Logo
123 people viewed this question
Top Meiko Dishwashers Experts
jdthefixer
Trevor Turner
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
