Question about Hamat Plumbing
I need to replace flexible hose assembly to Hamat 3-3175 PC side spray. Can I order as assembly and install?
Threaded assembly to secure side spray to sink broken at collar of threads where joining base of side spray. Flex hose runs through it. Can I replace just the threaded assembly and secure to base of side spray, placing flexible hose through it? Or must I replace flex hose with the threaded part? I can send photos please advise.
3 Suggested Answers
  • 54 Answers
SOURCE: leaking under sink and st base on sink
Remove spray head then faucet tighten connection on the spray hose
Posted on Sep 26, 2009
  • 92 Answers
SOURCE: i have a danco spray head, it broke at the pullout
no one can get it out, sad as it is you just might as well contact Danco and see what they will want to send yu a new handle and hose.
They might do it for free. Most companies are doing that today in order to keep people in the product.
Thanks for using FIXYA to help you out
Tom
Posted on Sep 09, 2011
I want to remove content control
REMOVAL
A/C Compressor Mounting
1. Discharge the refrigerant. Refer to MTC-111, "HFC-134a (R-134a) Service Procedure" .
2. Remove the front right wheel and tire assembly. Refer to WT-6, "
Rotation" .
3. Remove the engine under cover and the splash shield using power tool.
4. Remove the engine air cleaner and air ducts. Refer to EM-14, "
Removal and Installation" .
5. Remove the drive belt. Refer to EM-12, "
6. Disconnect the compressor electrical connector.
7. Disconnect the high-pressure flexible hose and low-pressure flexible hose from the compressor.
Jun 13, 2014 | Computers & Internet
How do i make it continue to run with no bucket so it does not fill and and so i don't have to empty it
Attach a length of garden hose no longer than 5 feet, to the threaded drain hose connection that was supplied with your unit, to carry water to the drain.
1. Remove the drain-hole cover on the back left side of your unit.
2. Connect a garden hose to the threaded drain hose connector.
3. Push hose connector tightly to the drain-hole on Rear Grille with the arrow on the tab pointing UP.
The hose attachment will accept a standard garden hose fitting.
Do not over tighten the hose when connecting it to the hose connector,
use a rubber washer and tighten by hand firmly without stripping the
plastic threads.
When being attached to hose connector drain hose connection,
do not bend or kink the hose. The hose should lie flat from the
dehumidifier to the drain.
Jul 04, 2011 | LG LHD45EL Dehumidifier
Where can I get a replacement hose 1.5 meter long?
Contact Hamat
Techincal Support or Warranty
Parts
Call 1-866-52-HAMAT - option 6 or extension 1242
Hours: Monday - Friday - 8:30 AM to 5:30 PM est.
email: support@hamatusa.com
Mar 24, 2011 | Hamat 3-2865PC Everest Pull-Out Kitchen...
How do i change the mass air flow sensor on my pontiac montana
The Mass Airflow sensor is held in the air intake hose to the engine from the air cleaner by 2 approx 4" large hose clamps, unplug the connector to it and loosen the hose clamps on each side of the sensor and pull off flexible air intake hoses on each side of the aluminum body of the sensor and remove the sensor assembly. See picture below.
Mar 21, 2011 | 2003 Pontiac Montana
The hose running thru to the faucet head has severe leaking. Can this be repaired?
yes the hose can be replaced, this is a off brand, if you remember where you got it, you can order a new hose...
Pleas rate/vote this response thanks
Dec 19, 2010 | Hamat 3-2861ST Everest Pull-Out Kitchen...
How to replace the dust cup on a craftsman weedwacker
The dust cup has female threads and is threaded onto the end of the drive shaft. Care must be taken if the flexible drive shaft isn't pulled out of the tube and removed. Turn the dust cup until you can line up the hole in the side of the cup with the hole in the shaft. If you can, insert a thin, strong metal object like a Phillips screwdriver in the holes to lock up the shaft. Unscrew the dust cup with a large crescent wrench. Spray the assembly with penetrating oil beforehand to make it easier. Please post back if needed.
Nov 12, 2010 | Craftsman Garden
Low pressure from pull-out spray
you may try and remove one of the bobbins and see if this helps any.
Jun 27, 2009 | Hamat 3-2861ST Everest Pull-Out Kitchen...
Replacing my rear brake pads & discs
  1. Disconnect flexible hose. Remove the union bolt and gasket from the caliper, then disconnect the flexible hose from the caliper. Use a container to catch brake fluid as it drains out. Torque: 30 Nm (22 ft. lbs.) HINT: At the time of installation, please refer to the following item. Install the flexible hose lock securely in the lock hole in the caliper.
  2. Remove caliper.
    1. Hold the sliding pin and loosen the 2 installation bolts. Torque: 26 Nm (20 ft. lbs.)
    2. Remove the 2 installation bolts.
    3. Remove the caliper from the torque plate.
  1. Remove 2 brake pads with anti-squeal shims.
  2. Remove 4 pad support plates.
INSTALLATION
Installation is in the reverse order of removal.
  1. After installation, fill brake reservoir with brake fluid and bleed brake system.
  2. Check for leaks.
Jan 13, 2009 | 1997 Toyota Land Cruiser
Plumbing Logo
89 people viewed this question
Top Hamat Plumbing Experts
Colin Stickland
Colin Stickland
ray gallant
Daryl Gleaton
Are you a Hamat Plumbing Expert? Answer questions, earn points and help others
