Question about Tablets & eReaders
How do I get my tablet to turn on without plugging it in?
Everything. It will turn on if I plug it in.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 34 Answers
Sounds like the battery is dead, what does the Battery Charge indicator show, and will it stay on if you remove the charging lead?
A Factory Reset might cure this if the battery is showing fully charged with the power lead removed.
Posted on Nov 23, 2014
Tip
Power Cable Popping Out on Versus Chinese Tablet
Versus Tablets (sold mostly in the UK and Ireland until 2014) have some great features (like HDMI out and Bluetooth), but power is a problem. They do not charge through the USB port, but through a 3.5mm barrel jack plug (specs are 5v 2000mA).
The power cable on my Versus Android Tablet keeps popping out (and therefore the tablet won't charge). Lately it got so bad that the plug simply wouldn't go in at all. I did a bit of research and came up with a fix.
There's a small plastic ring at the top of the plug. Take a precision pliers and pull the ring off the plug. BE CAREFUL! - If you damage the plug it simply won't go in at all, and your tablet will be useless.
Without this ring the plug stays in and the tablet charges. It still pops out occasionally, but a lot less than it did before.
NB: I do see some replacement power adapters with these plugs available on eBay and Amazon, so you may be able to try out a replacement power supply too.
Versus Tablet
on Feb 01, 2015 | Tablets & eReaders
Gone into safe mode therefore wont charge.was advised to remove battery but how do i do this
what tablet is it ? you will have to do a full factory restore ( loosing everything ) if its apple then plug it into a compter and use itunes to restore it ( if you have synced before then you wont loose everything ) if its android turn the tablet off/hold the volume up button and the home button together and keep holding them while you power the tablet on,you will get a menu to restore it. some tablets have a very small reset hole on the back,use a paper clip and push the tiny button in that hole to reset it.
May 31, 2015 | Tablets & eReaders
TABLET WON'T COME OFF OF THE MAIN RCA SCREEN HOW CAN I FIX THIS
If restarting does not help, then leave the tablet on until the battery drains to zero and the tablet shuts off. Then plug it in and charge it fully. When you turn it on, everything should be reset. Worked for me and have had no problems since.
May 02, 2015 | Tablets & eReaders
How Do I A ASUS Tablet
I would contact Asus tech support . and have them assist you
Mar 23, 2015 | ASUS Tablets & eReaders
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
My tonbux 10.1 will not switch on
Most likely the charger is not functioning. Test it with a meter where it goes into USB port and plugged into wall outlet.
Dec 01, 2014 | Tablets & eReaders
How to reset SVP TCP-1020 tablet
In most cases, the battery comes loose from the main connection. Those tablets do come apart, the back just presses on.
Jul 30, 2014 | SVP 10-inch Tablet
Tablets & eReaders Logo
85 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
