Question about Sony Audio Players & Recorders
Can you fix a Sony Walkman Pro WM-D6C cassette player?
Nothing. Motor starts up, you can hear it, but that's all. Seems like a belt problem but I have none of those.
  • 30 Answers
SOURCE: WM-D6C in ex condition ... only there's no power at all ... can anyone help or recommend someone who can repair it in the UK?
try going to servicemagic.com for a location near you
Posted on Jul 17, 2007
night71
  • 328 Answers
SOURCE: WM-D6C Battery holder
Because of the age of the unit, Sony will not carry that part. However, keep an eye on E-bay and yard sales and thrift stores and hopefully you can pick one up real cheap. Good Luck
Posted on Oct 29, 2007
SOURCE: URGENT HELP cassette player problem, please reply
I HAD EXACTLY THE SAME PROBLEM ALL I DID WAS TAKE APART MOVED ALL WHEELS AND COGS IN SIDE AND JUST BLEW OUT ANY DUST CLIPPED BACK TOGETHER AND WORKED FINE PLAYS GREAT HENCE WHY IM LISTING IT ON EBAY.HOPE YOU HAVE SUCCESS
Posted on Sep 14, 2008
SOURCE: Sony Walkman WM-D6C
If your WM-D6C has a serial number below 267201 (take out the battery block and you'll see the serial number sticker there) then the problem is electronic, not mechanical. It is likely due to the speed controller chip (labeled as IC601 on the circuit board), which is made by Sony and is type CX20084. This chip decides the voltage that is fed to the motor which is only about 2.4 volts, Should the chip be defective then the motor receives about twice this voltage and thus runs too fast. If you take the back off the recorder you will see the circuit board; it looks like a rectangle with a small square extra bit sticking out to the right. It is here that the IC601 resides. It is about the size of a small pinky finger nail and has 8 tiny legs down each side. Measure the voltage on pin 15 (put one voltmeter probe (+) on the second leg down on the right side (pin 15) and the other one (-) on the battery negative), it should read about 4.8 volts, which it feeds into the base of transistor (Q601) that in turn will then feed 2.4 volts to the motor (if everything is working OK). If the chip is damaged, then the voltage on pin 15 will be close to zero, and the transistor Q601 will not be "held back" and so will feed about 5 volts to the motor. CX20084 is (unfortunately) obsolete, someone in the UK sells them for about $50, but an excellent company in Hong Kong (utsource.net) sells them for $5 (plus $8 S&H). Taking out the old chip and putting in a new one is close to microsurgery, you will need a micro soldering iron (18Watt Antex), a good eye, a powerful magnifying glass and a steady hand, but it can be done - I've done it! There is a possible second reason that could cause the motor to run too fast. There is a pick up coil on the main flywheel called FG901. If this is damaged it will be open circuit and then the only use for your recorder is probably a paper weight. You can test this by going back to chip IC601 and locating pin 1 (top left pin; a small circle on the body of the chip is next to pin 1), Pin 1 is connected to the positive side of a capacitor,  C602 (0.47 microF), check the resistance from the negative side of C602 to the ground (take battery out, and use battery (-) as ground). You should get about 600 - 650 ohms reading. If you get nothing, sorry there is not much you can do about it as these pick up coils are definitely not available. Finally, chip 601 (CX20084) goes bad if you connect the batteries back to front. Good luck. Giles..
Posted on Jan 16, 2009
  • 11 Answers
SOURCE: plays too fast
WMD6C has a pitch control on the back of the unit that can change the speed of the tape, so switch it off, but if that is not the problem then inside the unit it has a servo set speed pot on the main board.
Dave, Electronic Doctors email eledocs@hotmail.com
Posted on Apr 03, 2009
Sony Walkman Pro WM-D6C cassette player failure.
Almost any Sony or other small appliance repair shop should be able to do this,
Nov 23, 2014 | Sony Audio Players & Recorders
My nephew connected my Walkman Pro WM-D6C to a 20V laptop power ada[pter. Needless to say there was a spark and it no longer runs. Is there an internal fuse that has blown or is the problem likely to be...
I have repaired many D6, D6C Walkman and other walkman high-end, improve your performance if required and, if possible. My email: doctor.walkman @ gmail.com Ho riparato molti D6, D6C, e altri walkman di alta gamma, aumentando le prestazioni, se richiesto e se possibile. La mia email: doctor.walkman@gmail.com
Sep 09, 2010 | Sony Walkman WM-D6C Personal Cassette...
My sony wm-d6c appears to be running at double speed can I fix this easily
Your set is running wild because the motor has lost the regulation.Hence you will need to replace the motor. It is also possible that the belt had jumped and got into the large end of the pulley to make the capstan spin higher. So remove and check both of these sectiions and confirm. Hope this sorrt yourr fault.Good day
Jun 28, 2010 | Sony Walkman WM-D6C Personal Cassette...
Who can I send it to for maintenance/repair?
Get in touch with me and describe the problem. I have repaired many d6c and high-end Walkman and, when possible, increase the performance. doctor.walkman @ gmail.com
May 14, 2010 | Sony Walkman WM-D6C Personal Cassette...
My Sony Walkman Professional WM-D6C will turn on but the take-up spindle just slowly inches the tape along in short bursts, not a continious action.
Contact me at my email doctor.walkman @ gmail.com, I'll ask you some questions and some photos of the WM-D6C in his possession. We will solve the problem
Apr 23, 2010 | Sony Walkman WM-D6C Personal Cassette...
Sony Walkman cassette player/recorder will not rewind the tape
Fat chance to repair yourself! we repair that WmD6c but very hard to do!
Feb 23, 2009 | Sony Walkman WM-D6C Personal Cassette...
Tape fails to return to cassette when cassette removed.
I'm an repairer of electronic and micromeccanaca I have repaired many walkman analog (WM-D6C, wm-dd9, etc.. Improve your performance if required and if possible) and many like dat walkman Sony TCD-D3. I just started to repair even for those who come out of Italy. If you would contact me to explain the problem better I'll try to help. Email: doctor.walkman@gmail.com Sono un riparatore di elettronica e micromeccanaca ho riparato analogico walkman molti (WM-D6C, WM-dd9, ecc. Migliorate le prestazioni, se richiesto e se possibile) e molti come dat walkman Sony TCD-D3. Ho appena iniziato a riparare anche per chi si trova fuori d'Italia. Se vuoi contattarmi per spiegare meglio il problema cercher? di aiutarti. Email: doctor.walkman@gmail.com
Jul 29, 2008 | Sony Walkman TCD-D100 Personal Cassette...
261 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
