Question about Dimplex Heating & Cooling
Where can I obtain a fan control circuit for Dimplex FCX24A storage heater?
Replaced control switch as it had crumbled due to age and heat.Small relay on circuit board not operating. Need circuit diagram to check further.
SOURCE: dimplex dual night storage heater/convector heater
runs for 30 seconds then shuts off
Posted on Jan 23, 2008
buzzwood
  • 65 Answers
SOURCE: Dimplex Compact Electric Flame Stove Heater
call Dimples !-800-663-6663 ext 358 They will be able to help you out.
Posted on Jan 21, 2009
SOURCE: My dimplex night storage heater is not heating up,
thermal heat line melted just 2years 3 weeks old should this heater have been recalled some were put in by the warm front scheme frozen old age pensioner
Posted on Jan 19, 2010
heatman101
  • 43501 Answers
SOURCE: My edenpure heater turns on
If you have continuity through the bulbs then the next most likely thing is the thermostat...
If you check here you will see that they sell the t-stats so I would check that out...
Check for continuity through the t-stat and if there is none then you know what to try..
heatman101
Posted on Dec 04, 2010
SOURCE: wiring diagram for Dimplex wall heater Model 6100770000
installing a wall mount heater not sure on the wiring .heater has 3 wire black red and blue sources has white and black what wires go together
Posted on Dec 11, 2010
I have a small wall heater, towel rack included, the fan & timer work, but no heat. Where do we find the model number
Usually on a small sticker on the back near where the wire goes into it.
If you know the make you can Google it and look at the images tab like this for 'Dimplex bathroom fan heater'.
dimplex bathroom fan heaters Google Search
Jan 22, 2016 | Heating & Cooling
How do we get our heater to blow out warm air again
Either the control circuit has failed or a protective device called a 'thermal fuse' has gone open due to excessive internal heating.
Jan 25, 2015 | Dimplex DS5629 Electric Heater
Hi, I have a Dimplex DUO500i storage heater and
Sounds like you heating coils burnt threw. how much did you pay for it? Might want to buy another.
Oct 29, 2013 | Heating & Cooling
Fire was working fine, then flame effect stopped. Heater still works on both settings, but no flame effect. Tried new bulbs, but still no flame effects, any ideas?
If it is not the bulbs, it is often a melted switch or circuit board.
You can obtain technical support for your stove here:
Dimplex Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Jan 05, 2013 | Dimplex Compact Electric Flame Stove...
My dimplex night storage heater is not heating up, the power supply is fine. Is there a fuse or trip switch anywhere
Dec 19, 2009 | Dimplex Heating & Cooling
Does my FCXA/FCX24A electric storage heater contain asbestos? The number on is 00401706WW...
The use of asbestos in insulation and sprayed-on coatings was banned in 1985. I believe your heater is newer than that, so probably not.
Dec 16, 2009 | Dimplex DS5598 Mid-Size Heater
Hi, I don't understand how the early and late boost works on the storage heater. Someone told me I should turn the output switch off when I am at work during the day, then turn the output control up when I...
Output switch is the one that says Cool-Off-Heat. Turn this offwhen you aren't home.
Output control is the thermostat. If you want to heat the room turn up the thermostat to the desired heat after putting the output switch on heat. It will take a few minutes for the heater to get hot. Early boost would be if you want immediate higher blower speed to speed up keep the heated air from being too hot and late boost will hold off the fan until the heater is higher in temp and the air temp discharged will be hotter.
Nov 19, 2009 | Dimplex DS5603 Heater
Fan works but no heat
go to : www.dimplex.com or call: 1-800-668-6663 ext. 358 for custmer help
Jan 04, 2009 | Dimplex Compact Electric Flame Stove...
Early / Late boost in dimplex storage heater
The output setting if turned off isn't adjusting the temperature in the room automatically if its off,and by turning the output up is like turning up the heat.By turning the output switch on you can let the heater automatically control the heat.Still you need to monitor the adjustments to your liking and then you know how hot it will be when you come back into that room.
May 26, 2008 | Dimplex DS5603 Heater
Dimplex DS5804 (similar to DS5603) turns on, but no fan to push heat.
A simple way to check the thermostat is to by-pass it. remove the wires from it, and connect them together. If the heat works after that, Its a no brain-er. The thermostat is just an adjustable temperature controlled switch.
Feb 26, 2008 | Dimplex DS5603 Heater
Heating & Cooling Logo
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
