Tv makes a screeching noise then looses picture
    Top Expert:
  • Televison & ... Master
  • 74,211 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Nov 24, 2014
Making screeching sound
is it a loose fan belt this will make a scretching noise thats the cheapest thing expensive things if its a manuel could be a thrust bearing on the gear box or worse still an imput shaft bearing on gear box but i think it will be just the fan belt screeching
Nov 03, 2013 | Mercedes-Benz Cars & Trucks
1993 nissan altima what could be causing a screeching
It probably is a belt. You should look under the hood and check for a loose belt. Tighten as necessary. You should not be able to deflect the belt more than 1/2" in the center of the span of the belt.
Brakes will also make a screeching noise when they are worn out. This noise will also go away when you stop (of course). The sound is quite different than the belt sound.
Jan 31, 2010 | 1993 Nissan Altima
Dryer makes screeching noise..dries the clothes ..seems the tub is loose
at the top of the drum there is a felt pad with 3 white nylon glides attached to it. if this is worn, and it does wear, it will make a screeching noise like you described because it changes the postion of the drum and it will also appear like it is loose. you can purchase this part as a kit along with the glue to hold it on and it is not an expensive part. hope this helps.
Oct 14, 2009 | Frigidaire FEX831CS Top Load Stacked...
Loud buzzing noise which became a very loud screech over the last week. Turning tv off and on seemed to remedy it. Today screen was only black and white, now no video only audio. Is this the picture...
This TV uses a lamp and color wheel. the color wheel is likely the problem since it is known to make noise over time and will eventually sieze. The repair is in the $400 range.
Sep 27, 2009 | GE 46GW945 46" Rear Projection Television
RCA HDTV DLP Rear Projection TV wont turn on
RCA Projection tvs are trash,should be off the market.
Mar 29, 2009 | RCA Scenium D40W20 40" Rear Projection...
2003 toyota sienna makes screeching noise when starting
I would guess that you have a stretched or loose serpentine belt. Common problem.
Mar 23, 2009 | 2003 Toyota Sienna
Loud screeching noise when it powers on
sounds like picture bulbs maby %30 i think it may need to go in for a check up they can pin point the problem hope ive been somewhat helpful thanks viper
Dec 31, 2008 | RCA Televison & Video
White noise on screen with screeching sound
white unstable lines plus screeching noise it basically due to loose contact at input 1 like antena or cable wire or socket loose. 2 loose contact some where in your tv. 3 loose contact in some electrical thing. 4 loose near tuner section. hope this will help.
Oct 01, 2007 | Toshiba CF32F50 TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
