Question about Panasonic Cameras
Panasonic Lumix DMC-LS75---I have put in new batteries , yet it says " Please replace batteries" as soon as I turn it on and then switches off by itself. I have cleaned the battery terminals; it stil
When I first replaced the batteries , initially it stayed on for about 30 seconds before it said " Please replace batteries". But later it switched off almost immediately. I even tried a different set of new batteries of a different brand.
    Top Expert:
  • Panasonic Master
  • 6,702 Answers
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
Check the contacts of the battery and in the battery compartment of the camera. They all should be clean and shiny. You can clean contacts with a dry cloth or cotton swabs. Never use anything sharp in or close by a camera.
Posted on Nov 25, 2014
SOURCE: Camera showing battery exhausted with new batteries
There are three battery type settings in the set up menu: Alkaline, COOLPiX(NiMH) and Lithium. Might be worth looking at. To be continued.
Posted on Feb 09, 2008
SOURCE: hello pronlem with a panasonic lumix dmc-fx7 battery
help,i have solution panasonic lumix dmc-fx7 lcd blank water damage
Posted on Mar 30, 2008
SOURCE: Advent MP82 camera settings
firstly buy NiMH battery , and do settings back to alcaline.
sss
Posted on Aug 17, 2008
smartr10U
  • 1305 Answers
SOURCE: I need the driver for my camera Panasonic Lumix DMC-LS75 can not find it anywhere, would be so kind as to send them or tell me where download it for free ... thanks
Surprise! here is where you can download your lumix driver!
Click here
let me know how it goes..
k
Posted on May 29, 2009
leepania
  • 1099 Answers
SOURCE: When I turn my camera on it stays on for a few
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Posted on Jan 14, 2010
Camera closes when turned on and says to please turn camera off and then on again.
This happens when there is a serous error in the camera. Shutting it down and switching it on, it allows the camera to start its program again.
If it does not help, try to remove the battery and after a minute or so replace it. Sometimes recharging of the battery will help too, but I can't promise that.
Jan 02, 2014 | Panasonic Lumix DMC-LS75 Digital Camera
Lumix closes when turned on from drop
The message please turn camera off and then on again appears when the camera is not operating properly. So the manual says.
If the message persists you should contact the dealer or nearest service centre. But first you could check if you can see any damage. Check if the lens is not stuck. Remove the battery for a little while before you again try to switch on. Also check if the memory card is still in place and the battery door and memory card door are closed correctly.
If nothing helps you could contact the service centre or think of buying as new camera?
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
My panasonic dmc ls75 is not recognized by the computer please what can i do
There is a very easy way to download those pictures to your PC.
Checkout this tip that I wrote about that.
How to easily download Pictures from Digital Camera
heatman101
Apr 22, 2011 | Panasonic Lumix DMC-LS75 Digital Camera
HOW DO YOU TURN THE VOLUME ON, ON THE LUMIX-LS75, I CAN'T FIND THE VOLUME CONTROL ON THE MENU
Surprising as it seems, the DMC-LS75 does not support audio in videos!
Not good news.
Feb 06, 2010 | Panasonic Lumix DMC-LS75 Digital Camera
Lumix camera dmc-ls75 memory card has locked my camera how do i unlock it
there should be a little swith on the side of the card. switch to the opposite and then try
Jun 03, 2009 | Panasonic Lumix DMC-FZ30 Digital Camera
Where can I get my Panasonic Lumix DMC-LS75 fixed?
call panasonic directly. however, your warranty doesn't cover accidental damage.
Jan 28, 2009 | Panasonic Lumix DMC-LS75 Digital Camera
NEED TO CHANGE PHOTO RESOLUTION
■ Number of pixels
Select a higher number of pixels for clearer
pictures when printing.
Select a lower number of pixels [ ] (0.3M
EZ) to store more pictures. Fewer pixels also
means it is easier to send pictures by e-mail
or use them on a homepage.
■ When the aspect ratio setting is
[h]
DMC-LS75/DMC-LS70
(7M)
3072 × 2304 pixels
DMC-LS60 only
(6M)
2816 × 2112 pixels
DMC-LS75/DMC-LS70
(5M EZ)
2560 × 1920 pixels
(3M EZ) 2048 × 1536 pixels
(2M EZ) 1600 × 1200 pixels
(1M EZ) 1280 × 960 pixels
(0.3M EZ) 640 × 480 pixels
on the menu I believe the Panasonic calls it aspect ratio
Mar 06, 2008 | Panasonic Lumix DMC-LS75 Digital Camera
Cameras Logo
46 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
