Question about Dell Precision T3500 Computer Workstation (Intel Xeon W3503 160GB1GB) (BW1S13604) PC Desktop
Code error: 3700:011b Mgs: Front fan -the Fan speed is incorrect
  • 380 Answers
It could indicate bad bearings, which means the fan needs to be replaced. It's easy and not terribly expensive. Take the fan out, google the numbers on that fan to get an exact replacement, and install the new fan. the 3500 is a heavy beast, but its not terribly tough to tame.
Posted on Nov 24, 2014
Codigo de error
List of Error Codes for Precor Fitness Equipment
Error Code List for Precor Fitness Equipment
Feb 05, 2014 | Precor Exercise & Fitness
Fan speed too high
Go to the BIOS and see if the settings have adjustable speeds for IDLE Fan.
Nov 11, 2013 | Dell OptiPlex 780 Desktop Computer 1 x...
Replaced 3 speed switch now light only works when fan is on high speed
I'm guessing that it is wired incorrectly or the is a bad ground circuit.
Light does NOT work,now?On 2 lower speeds? That's beyond me.
Sorry.
Feb 19, 2013 | Oasis Hunter 54' Ceiling Fan
How to start air conditioner in f6 mode
i need assistant , when i on my ac .after 1minute it shows f6 and off
Apr 17, 2012 | Heating & Cooling
What is the processor fan speed for Dell Vostro A860?
This could be the result of to much dirt build up in the heat sink ports blocking vital air flow. Buy a can of compressed air and blow it on fan any open ports, this should prove if the fans the issue, the speed should slow down because of increase air flow cooling the laptop. If this works the machine should be taken apart for better clean out.
Mar 06, 2012 | Dell Vostro A860 Notebook
I saw a word in the front is ER CF like error
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
CLICK
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Oct 16, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
After a power outage the ice make didn't work. We defrosted and cleaned out all of the ice in the freezer and it still didn't work. Now there is water leaking out of the freezer and the fridge is...
The E/F error code is indicating a problem with the evaporator fan motor inside the freezer. It could be caused by a failed fan motor, control board or a loose wiring connection between the two components. The control board monitors the evaporator fan motor operation and speed. If the control board does not receive information from the fan motor or receives incorrect information because the fan motor has stalled out or is not running correctly "E/F" will display. This type of error code will require a service technician in order to diagnose the failure. I recommend calling a service technician to repair your refrigerator.
Sep 24, 2011 | Refrigerators
Error code IF or 1F not making ice model #795,77562... Sears/LG
You posted under an incorrect model number, so can only give general info. IF is a code for ice room fan. It is a fan located in a plastic box in the upper left hand corner of the freezer. The IF code shows up if the control board does not get a feedback signal from the fan telling the control board that the fan is running. I'd check to see if there is some ice blocking the fan blade. If that is not the case, you will need a meter to do further diagnostics to find out if your problem is with the fan motor or the control board. (note: when you turn the icemaker off, the fan will no longer blow cold air into the ice room, and all the ice will melt. Also, when the icemaker bin is full, the same basic thing can happen. Steady use of ice or dumping the bin will prevent ice from melting in bin.) The fan runs on 12 to 16 volts DC (variable speed), and the feed back signal is about 4.5 volts DC.
Jan 11, 2009 | LG LRFD21855 Stainless Steel French Door...
Error code e000800-001
not the fan open the front door pull out number one unit check the assymbly behind the frame it will move when you move the handle if its bent tou will get that code when you close the door
Nov 08, 2008 | Canon imageRUNNER C6800 Copier
Dell Precision T3500 Computer Workstation (Intel Xeon W3503 160GB1GB) (BW1S13604) PC Desktop Logo
157 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
