Question about Whirlpool Kitchen Ranges
What's causing my Whirlpool Accubake oven to go into a self-cleaning cycle all by itself?
The first time this happened my wife was baking a casserole. The display panel showed the word "Loc" and a lock icon. The door couldn't be opened for hours. Needless to say, the casserole was burned to a crisp and the kitchen filled with smoke by the time we gave up trying to cancel the function and just killed the circuit breaker in the basement. The next time it happened, we were using the burners and my wife noticed smoke coming from the oven. There were all sorts of empty cookie sheets inside that are now ruined.
  • 46 Answers
Main mother board is going bad! Had this happen to mine too!!
Posted on Nov 23, 2014
SOURCE: whirlpool range door locked
I have had a similar problem(locked after self clean and NO display.) After much research we found the solution through telephonic advice from a master appliance repairman. Mind you that I did NOT get any help from the Whirlpool Customer Service number. Customer Service said it was probably VERY costly to repair and probably a blown circuit board. We were convinced our 2.5 yr old oven was about to cost more to repair than it was potentially worth. Then our telephonic advice from a friend, the master appliance repairman came to our rescue. It was explained to us that whenever an oven in most ANY brand locks and remains locked, it is usually due to a blown out thermal overload protector. This is the thermostatic fuse that will burn out during a self clean cycle and it's designed to help protect your oven from overheating. It is a VERY quick fix but does require a replacement part. But rest assured if I can do this fix, you too can. I am a 46 yr old female nurse without ANY electronics experience and was coached through this by my brother. Here's what to do. Move your oven away from the wall and remove the back panel (simple screws holding it in place.) Unplug your range for safety reasons. If yours is gas (and mine is) be mindful of the gas feed (mine had plenty of slack and presented no problem but worthy of mentioning.) You are looking for a part that's sort of in the 10 oclock position, it's round about the size of a quarter and held in by 2 screws. There are two wires coming into it. My part has the actual part number written on it and was the very part number I was advised to find based off the model number. You can call any appliance parts house (mine is Fox Appliance Parts in Atlanta) and give them your model number of your oven. Ask them for the part number for a "thermal fuse." They will provide the number, ship it to you or if you're local, you can pick it up. It should be around $30. Here's the cool part...you can diagnose this FIRST to see if it will fix your problem by doing this one simple thing. Remove your actual fuse by unscrewing the two screws and then slide off the two wires attached (it will slip out.) Now take the two wires still on the back of your oven and patch the two contacts together. Now plug in your oven....relax...you are merely bypassing the fuse and it will not explode or anything crazy! If the thermal fuse is your problem, your oven display will now magically reappear and the door will unlock! Now you know definitively that this is indeed your problem. Replace the part and you're back in business. You MUST replace the part though as I've been explained that it is a key safety fuse to help prevent overheating, $30 fix, even a GIRL can do it, and it takes about 10 minutes. Try it....You most likely do NOT need a new oven and do NOT need a repairman. And I was ready to replace my 2.5 yr old oven! Totally not necessary and this is something you can do!
Posted on Feb 11, 2009
SOURCE: Whirlpool super Capacity 465 gas range-Door Lock
your latch is defective. they have parts that melt when you use the self cleaning cycle. they also just go out. the door should auto latch when you start the cycle but it times out when it is not seen.
Posted on Feb 20, 2008
SOURCE: Kitchen Aid Double Convection Oven stopped during Self Cleaning
same thing happened to me yesterday took all day to figure it out was the themal fuse on the back of the oven the part number for my kitchen aid is 8300802 if you want the doors to unlock and reset the display you can take the leads off the fuse touch them together and the door will unlock however it is best to change the part took me 5 minutes once i knew what to look for
you have to remove the back panel and you will see the part with the number on it cost me 50 dollars but better than the 8o bucks to have a sevice guy come and do it next time i self clean i will pull the stove away from the wall to help keep it from ver heating
Posted on Apr 04, 2008
jyackle5
  • 8197 Answers
SOURCE: whirlpool Electric Oven RBS305 overheats while baking, locks door
The technical manual for your range doesn't show an error code of E2 F2 but all of the F2 codes pertain to the touchpad of the range.
Can you clear the E2 F3 by pressing the cancel button? If not, shut off the power to the range for a few minutes and see if the error code goes away. If the error code remains You should unplug the range from the wall and remove the back panel for the control area. Disconnect the ribbon between the touchpad and the electronic control, clean the end of it and reconnect it.
If this doesn't repair the problem you will need to replace the touchpad on the range. The parts diagram lists two touchpads, they are part numbers 8273575- bisque, and 8272702- white.
Good luck
Posted on Dec 18, 2008
  • 258 Answers
SOURCE: locked oven door
Look for a button or sensor which the door would press when closed.
If you find it hold it down for a minute, this should reset the lock
if it doesn't it may do when you let go
Posted on Jan 18, 2009
Whirlpool self-cleaning feature not available
Because the features mention utilize 220 VAC power, I do not advise you attempt any corrections. Very dangerous; unless you are a trained technician. If the unit is in Warranty, get the Whirlpool folks out to you home ASAP.
Dec 19, 2013 | Whirlpool Gold GGE388LX Double Oven...
When I was using the stove...the door locked and F-3 showed up what happened
it sounds to me like you have a self cleaning oven and may have somehow gone into the cleaning cycle
Oct 07, 2012 | Whirlpool Accubake RF362LXTT Electric...
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
Oven clicks to self cleans or f3, the door locks and food burns
Replace the oven temperature sensor.
Take your model number to any appliance parts store for a replacement sensor.
Apr 20, 2009 | Whirlpool Accubake RF362LXTS Electric...
Getting oven back on fahrenheit instead of celsius
Actually for the Whirlpool Accubake I just figured out, the bake button didn't work, but holding the broil button did the trick.
Apr 19, 2009 | Ovens
Whirlpool Accubake - Can't get out of clean mode
cannot get out of clean mode, although the oven outside is cool, but door is locked and display still says cleaning, door locked and time of 3 hrs 15 min is displayed. NOW WHAT?
Nov 16, 2008 | Kitchen Ranges
Jan 02, 2008 | Whirlpool GS460 Gas Kitchen Range
Whirlpool oven issue
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
Kitchen Ranges Logo
98 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
