Question about Honeywell RTH230B 5-2 Day Programmable Thermostat Large
I just replaced a t87 with a 7 day digital honeywell tstat but it will not light up, I have a 3 zone system so I bought more then one of these tstats but none light up, the t87 only had 2 wires, black
Only not the 5-2, its 7 day but same unit
  • Honeywell Master
  • 3,382 Answers
Try replacing or installing two AA batteries. or call 1-800-468-1502 for help, that number is from the manual you read.
Posted on Nov 26, 2014
koolbreezes
  • 540 Answers
SOURCE: got a honeywell t8400c thermostat
R--- rc or rh y--yellow g---green w--white red is power yellow is cool g--fan white is heat
Posted on Sep 03, 2008
koolbreezes
  • 540 Answers
SOURCE: i have a honeywell focus
W== heat which we'll call this w-1! w2== second stage!
Posted on Sep 04, 2008
  • 124 Answers
SOURCE: installing thermastat
any wire can go to any terminal. unfortunately you now have to hand trace each onre to the device it powers and hook it up accordingly. a daunting task even for a pro. having said that the installer could have used the normal colrs for the usual wiring if you were real lucky. as a general rule the red goes to the r terminal. the yellow goes to the y terminal. the white on a heat pump usually goes to w2. the green powers the fan and goes to g. usually the changeover valve is powered by the o terminal and that is usually wired with an orange wire. that only leaves two more wires. one is the auxilliary or emergency heat terminal and any color wire can be used for that. it will go back to the airhandler and tie on to the w terminal along with the white wire from the stat on most units. or they may have jumped the w and emergency terminal together and hooked the white wire to both. it will work either way. that only leaves one wire and that is the common wire to the stat taht allows it to light up and think and have power. . most stats need the red and a common to work. you may have bought a stat that works off battery power only but since you are blowing fuses it seems you have a common pulled on one wire that you have hooked up wrong and it is creating a dead short , aka a blown fuse. if you go to airhandler and finf low voltage terminal board look for terminal labeled comm . observe what color wire is connected to it and if that is the wire that goes off to the stat. if it is hooked to common and goes with the others to the stat then thats your common and should be hooked to your stat common terminal as outlined in your install sheet. you can keep replacing those fuses till you get it right or take a chance and use an amp probe and a jumper wire . only run an instant and if amps are 4, 5, 6, amps at trans your wrong. only test an instant or you will ruin transformer.probably best if you get a box of fuses.label stuff make notes and good luck. i have gotten in the habit of using a sharpie pen to make copius notes right on the service panel for me and the next guy.
Posted on Oct 30, 2008
SOURCE: Hi, I'm fitting a replacement Honeywell
We are selling a full case of 35 Aux. switch assembly for V4034 on ebay 10-31-08
if you or anyone is interested
Posted on Oct 31, 2008
SOURCE: Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Hello,You forgot to wire the O terminal w1 witch is the reversing valve.It is important to check if old stat is using O or B in witch case B terminal=w1 leaving O unused.
Posted on Apr 21, 2010
I have a Honeywell L7224U I need to know how to turn on the circulator
Assuming you have an oil fired unit. hot and neutral wires on circ should be connected to C1 and C2 respectively. Tstat should be connected to TT which will energize circ on a call for heat and boiler will run based on limits. If you boiler is set for cold start the circ will only run on a call for heat. If you have more than on tstat/zone then you probably have either a zone control box or zone valves and transformer. If that is the case I would defer to a heating professional.
Nov 16, 2017 | Honeywell Heating & Cooling
Filter light is on Honeywell thermostat and I replaced
Your filter change reminder is based on time. The tstat has no way of knowing how dirty the filter us. 30 days, 60 days, 90 etc. You have to enter the configuration menu and do away with the "filter change reminder." Honeywell makes 400 tstats, if you don't have the manual we need model number!
Jul 11, 2017 | Honeywell Heating & Cooling
On my thermostat I have this sign -AC or I am not sure if it is -RC. Please help me. My thermostat is a Honeywell
You should have r and rc. Likely have a jumper between the two. Your red wire can go to either terminal, the jumper stays in
Feb 17, 2017 | Honeywell Heating & Cooling
Honeywell Strat RTH9580 reboots continuously when connected to Taco ZVC406 transformer
Might be a load that's too heavy for your stat. Consider installing an isolation relay.
Feb 18, 2014 | Taco Zvc406-exp-4 Boiler Zone Control,6...
Yourhome honeywell com
To start, most tstats pull straight off of its base, or pull away from the bottom and lift from the top. Yours should be a touch screen and pulls straight out. Hopefully the installer secured the base well enough to the wall. At the tstat that has dehum. capability, see if it has a terminal marked D or H for dehum. If so, there is a wire connected. Now at the 1 you would like to replace, remove tstat from base, and check the number of wires you have available. If you don't have a "spare" wire for the new tstats' H(humidity) terminal, it won't work out because you'll need an extra wire. Also the existing tstat may have that option, but isn't configured for dehumidification. Might check that too. It is possible to add dehumidification to any and all zones depending on available wires. Also, at the geothermal, this "extra" wire needs to be connected.
Mar 10, 2017 | Heating & Cooling
Cannot get original Tstat wiring to work on a furnace.
The symptoms you describe make no sense at all but just connect the wires by color, R = red etc. leave the jumper between Rh and Rc, red goes to Rh, Blue would go to C. C = Common. If at any time you short Red to Common, damage can be done, usually a blown fuse or blown transformer. So unplug the furnace while doing your connections. By the way, the new t-stat you bought uses batteries and the blue wire should not be used. Good luck and comment back if you need more info.
Jan 09, 2010 | Honeywell Programmable Thermostat Heater
Thermostat will not turn on for air conditioning
Turn fan to on position to see if fan runs. Is this new tstat. Digital or manual tstat. If digital check back of tstat to see if tstat is set to gas heat. Rus
Jun 21, 2009 | Honeywell Programmable Thermostat Heater
Honeywell T8400B Thermostat Display Intermittently Blank
most likely a bad tstat i would replace I recommend honeywell focus pro 6000
Jan 29, 2009 | Heating & Cooling
Honeywell RTH230B 5-2 Day Programmable Thermostat Large Logo
108 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
